Re: new Moparts fastest car list, post yours!
[Re: gregsdart]
#12655
09/13/04 09:51 PM
09/13/04 09:51 PM
Currently 11.40 at 119.18 1.608 60' uncorrected at LACRs 3000 ft alt,weight w/o driver 3020 lbs. 360 w2 71 duster(no N.O.S)
[Re: tazmaniac]
#12656
09/13/04 10:29 PM
09/13/04 10:29 PM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide & 1050 Dominator on gasoline
Atco 15/Nov. '03: 8.178 @ 167.12 mph, 1.139 60', 132.7 mph @ 1/8
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor
Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
Guys, please update this, i have done a couple, but not all! My main objective is to get a baseline of the engine combos that are on the board, so age of the run not important,body type is only weight related.
[Re: gregsdart]
#12657
09/13/04 10:38 PM
09/13/04 10:38 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#12658
09/13/04 10:44 PM
09/13/04 10:44 PM
Posts: 826 Georgia
66coronet
Georgia
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 66coronet, SRheaded 440, auto, 3670lbs, mufflers and 10.5's 10.71 at 126 in the heat of summer
[Re: gregsdart]
#12659
09/13/04 10:47 PM
09/13/04 10:47 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
'Edit'
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: Rapid588]
#12660
09/13/04 11:27 PM
09/13/04 11:27 PM
How come we're doing a new list ? B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@13712.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446, stock 4bbl intake, 452 heads w/ stock size valves, .484 purple cam , street tires, through full length exhaust, pump gas, all motor. Passes state emissions test. Idles in traffic in 110° weather. As usual I'm the slowest
#12661
09/14/04 01:07 AM
09/14/04 01:07 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Does it count if you haven't driven your car yet ? The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: quickd100]
#12664
09/14/04 05:28 PM
09/14/04 05:28 PM
Posts: 803 Texas
Beeracuda
super gas
super gas
Texas
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: Beeracuda]
#12665
09/14/04 08:12 PM
09/14/04 08:12 PM
Posts: 192 LEBANON;PA
daron
LEBANON;PA
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446 daron 73 duster 10.50 et @ 127.00 sb street car
[Re: daron]
#12666
09/14/04 08:15 PM
09/14/04 08:15 PM
CokeBottleKid
Detroit, MI
guys please put your cars in order, not necessarily on the bottom of the list... unless you want to be slower The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: CokeBottleKid]
#12667
09/14/04 08:50 PM
09/14/04 08:50 PM
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car 12.466 @ 108.98 (1.764 60') Greg J, 69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12669
09/14/04 08:59 PM
09/14/04 08:59 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: StrokerPost]
#12670
09/14/04 09:02 PM
09/14/04 09:02 PM
Posts: 2,275 Kissimmee, Florida
aarlucas
Kissimmee, Florida
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12671
09/14/04 09:50 PM
09/14/04 09:50 PM
Posts: 16,925 NC
440Jim
NC
I already have the Dart at 9.83, this adds my 440 Barracuda at 11.72 at 113 mph, 1.59 sixty with 4.30 gears; it went 11.77 at 116, 1.66 sixty with the 3.91 gears. The hydraulic cam gave up with the 4.30 gears on the top end. The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
[Re: aarlucas]
#12672
09/14/04 09:52 PM
09/14/04 09:52 PM
Posts: 754 Longview, Texas
marvo451
Longview, Texas
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam, 3220 lbs.
[Re: marvo451]
#12673
09/15/04 04:01 AM
09/15/04 04:01 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph, 3000 lbs, 2780 den altitude. NA 6/26/04 Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
