68 wagon gas tank - Satelliite, Road Runner #1263195
07/06/12 07:06 PM
07/06/12 07:06 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Is the gas tank for a Satellite wagon the same B body gas tank - 1968? Does anyone make the filler neck ? from the small rubber hose to the tank - thanks
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: mro] #1263196
07/06/12 08:17 PM
07/06/12 08:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
doesn't a wagon have the fill on the side?
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: mro] #1263197
07/06/12 08:19 PM
07/06/12 08:19 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
Same tank as 66-7 regular B-bodies.
Unsure on fill neck. Mine is 20 miles away or I'd look/compare to regular B's for you.
68 Charger R/T - #'s matching car, 499/727/3.91
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: jon01] #1263198
07/06/12 08:25 PM
07/06/12 08:25 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
This is correct. You can look through my wagon's thread and see the original and replacement gas tank.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Scott
1969 Super Bee, 383/4 speed
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: StukaJU87] #1263199
07/06/12 09:30 PM
07/06/12 09:30 PM
lake county, ca
lake71383 Offline
lake71383  Offline
lake county, ca
I don't know much about the late 60s but 70 and up is a different tank, and everything I find shows that wagon has a different gas tank except 66 and 67 show that it many have the same from car to wagon.
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: lake71383] #1263200
07/06/12 10:06 PM
07/06/12 10:06 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I have a nice tank and fill neck from a 1968 wagon I parted out if you are interested...
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: 68 wagon gas tank - Satelliite, Road Runner [Re: mro] #1263201
07/07/12 04:32 AM
07/07/12 04:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
68-70 wagon is different than passenger car hardtop/coupe, the 66-67 hardtop/coupe uses a tank that is the same as the 68-70 wagon.
