holley power valve selection #1262452
07/06/12 12:19 AM
07/06/12 12:19 AM
Alton, IL
Dakota_Don Offline OP
Alton, IL
if i have 16 in vac i should use a number 8 right? but they only have 8.5 so do i go to a 7.5?
Re: holley power valve selection [Re: Dakota_Don] #1262453
07/06/12 12:54 AM
07/06/12 12:54 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'd use the lower number one 7.5". Most Holleys have 6.5" power valves which should be fine.
The Quick Fuel Power valves are about 1/2 the price of the holley power valves, and they have many in the half inch of vacuum increments.
Re: holley power valve selection [Re: 451Mopar] #1262454
07/06/12 07:51 AM
07/06/12 07:51 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The QF units are a better price but they are also the four door (high flow) units.
Note: QF has better pricing on most of the Holley type carb parts.
If your vehicle is an auto, you should go at least 2" below the in-D vacuum reading for your pv selection. I know, pv's don't allow fuel at idle, but they might if someone has a higher than normal idle rpm. This is why the 2" below the in-D vacuum reading is a good start.
Re: holley power valve selection [Re: Dakota_Don] #1262455
07/06/12 08:43 AM
07/06/12 08:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes you need your in gear vacuum number then 3 or more below that the less radical the cam the more you drop say it's 14 in gear a 8.5 will be fine!
I once had a 318 with a mild cam that I ran a two stage 10.5/8.5 worked good!
