Re: What is the voltage spec for 2008 Avenger
[Re: 383man]
#1261863
07/05/12 04:31 PM
07/05/12 04:31 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I found it as it uses the full time clutch which means the clutch is always engaged. It has a break away clutch as they call it in case the comp locks the clutch will break the pins in it and still turn but the comp will not turn. It will still look normal when you look at it. You may have to remove the belt and spin the comp by hand to make sure the comp is turninmg and not just the clutch hub. Also the voltge may be low as the voltage is pulse witdh modulated by the PCM which controls it. The more volts to it the more the solenoid opens an orfice which puts more freon on the wobble plate head and gives it more stroke to pump more freon and cool more I cant get the wire diagrahm to work for some reason. . I will try it again later. Ron
[Re: 383man]
#1261864
07/05/12 04:39 PM
07/05/12 04:39 PM
Posts: 27,728 places
79powerwagon
places
[Re: 79powerwagon]
#1261868
07/06/12 12:18 PM
07/06/12 12:18 PM
Posts: 473 MI
Blown69
mopar addict
mopar addict
MI
The A/C compressor is controlled by the powertrain control module (PCM) or engine control module (ECM), depending on engine application. The PCM/ECM calculates compressor displacement required by A/C system load and demand by monitoring vehicle speed, A/C high side pressure, engine speed, evaporator temperature, accelerator pedal position, ambient temperature and A/C-heater request signals. The PCM/ECM then sends a pulse width modulated (PWM) signal to the A/C compressor control solenoid to increase or decrease refrigerant flow through an orifice located within the compressor housing. The amount of refrigerant allowed to pass through the orifice in the compressor determines the head pressure which controls the angle of the swashplate, which in turn, determines the amount of compressor displacement. When there is no demand for A/C, the swashplate is adjusted to nearly a zero degree angle, which removes compressor torque drag from the engine.
Is the check engine light on? You might want to bring it in to a dealer and have them try to cycle the A/C compressor with the scan tool.
[Re: Blown69]
#1261869
07/06/12 01:05 PM
07/06/12 01:05 PM
79powerwagon
places
Yes, the CEL is on, but that's a "Minor EVAP Leak Detected" per the scan, and that comes and goes, plus a new Mopar gas cap didn't correct it. I think the two problems are unrelated, but who knows these days? I have the car at the little shop down the street from me. They are simply going through the AC system to check components and levels (as well as attach their scanner to it), and once they've finished, they will give me a report, and I'll determine what, if anything, I want to do further. I was hoping that just getting that compressor attached back to the wiring harness would do the trick, but alas, with Murphy as my guardian angel, that ain't gonna be the case!
