Re: Took The Rampage Out... First Time
[Re: 340B5]
#1261814
07/05/12 01:09 PM
07/05/12 01:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What bore and stroke? Silver ghost flames would look pretty good w/ the red metalic.
Its just a 416ci with W-5 heads and a roller cam
[Re: rt66jim]
#1261816
07/05/12 03:23 PM
07/05/12 03:23 PM
MR_P_BODY
Mike as others have stated that is a sweet sounding ride.
I do have one ? And I only ask because a friend on mine's car is doin the same thing. In the video when you whacked the throttle in front of the garage. I appears it is smoking out the right tail pipe. What do you think that might be? Jim
Right now I'm not sure if its steam from a header bolt (water getting in) or if its my oil leak... I see oil right at the ball socket(joint) so it might be getting in there... right now I have a few other things that are higher on the list... I also have 1 head that I had to tube the push rod hole because I went to far on porting but I dont think thats the problem.. gotta fix 2 oil fittings then check it
[Re: emarine01]
#1261818
07/05/12 05:44 PM
07/05/12 05:44 PM
MR_P_BODY
Hey Mike just a thought, I had major problems with the stock w5 3/8 guides & seals @ first, The stock w5 guide od is smaller than the rest of the worlds guides by a hair so if you use normal guide seals they want to slip off real easy, and smoke like hell
I had to drive my seals on so I'm sure thats not it but thanks
[Re: POS Dakota]
#1261826
07/06/12 09:12 PM
07/06/12 09:12 PM
MR_P_BODY
I can't believe how fast you got that done.
Good luck and as always stay safe. Very nice work. It sounds pretty mean. Love it.
LOL... I'm FAR from being done... still do the interior, do ALL of the body work(welding in some new metal) painting... still need to change a 4 springs on the suspension(fronts are too stiff and the rears are weak... but I'm getting things done daily... today was so damned hot I only worked a half day but did get some stuff done
[Re: MR_P_BODY]
#1261827
07/07/12 12:04 AM
07/07/12 12:04 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Very nice That thing sounds nasty...and it will surely be unique
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1261828
07/07/12 12:18 PM
07/07/12 12:18 PM
MR_P_BODY
Well I fixed one oil leak(where the oil filter use to mount, I have 2 fittings screwed into the block to go to the remote filter) BUT both of my big dollar #10 90% swivels are both leaking at the swivel... changed 1 and that stopped leaking but didnt see the other was leaking till now... gotta see if I have some more non swivel fittings... what a bummer
[Re: MR_P_BODY]
#1261829
07/07/12 01:02 PM
07/07/12 01:02 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Neat!!! Looks like you are having some fun
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1261830
07/07/12 01:41 PM
07/07/12 01:41 PM
MR_P_BODY
Looks like the leak was causing the oil out the pipe issue... once I get the exhaust warmed up good I'll retighten both ball sockets on the exhaust to seal
[Re: HardcoreB]
#1261833
07/08/12 11:35 AM
07/08/12 11:35 AM
MR_P_BODY
That thing turned-out great Mike! Good work, it looks and sounds right.
Thanks Sean........ I'm not happy with the engine... I pulled the plugs today and alot of them are some what oily and but the thing is dog fat, I was looking for my vac gauge but I cant find it OR my compression gauge... I believe I loaned it out but dont remember... but I want to do a few checks and if I'm not happy I'll pull the engine/trans today
