Page 4 of 5 1 2 3 4 5
Re: Took The Rampage Out... First Time [Re: 340B5] #1261814
07/05/12 01:09 PM
07/05/12 01:09 PM
MR_P_BODY Offline OP
What bore and stroke? Silver ghost flames would look pretty good w/ the red metalic.
Its just a 416ci with W-5 heads and a roller cam
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261815
07/05/12 02:01 PM
07/05/12 02:01 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Mike as others have stated that is a sweet sounding ride.
I do have one ? And I only ask because a friend on mine's car is doin the same thing. In the video when you whacked the throttle in front of the garage. I appears it is smoking out the right tail pipe. What do you think that might be? Jim
Re: Took The Rampage Out... First Time [Re: rt66jim] #1261816
07/05/12 03:23 PM
07/05/12 03:23 PM
Right now I'm not sure if its steam from a header
bolt (water getting in) or if its my oil leak...
I see oil right at the ball socket(joint) so it
might be getting in there... right now I have a few
other things that are higher on the list... I also
have 1 head that I had to tube the push rod hole
because I went to far on porting but I dont think
thats the problem.. gotta fix 2 oil fittings then
check it
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261817
07/05/12 05:10 PM
07/05/12 05:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Mike just a thought, I had major problems with the stock w5 3/8 guides & seals @ first, The stock w5 guide od is smaller than the rest of the worlds guides by a hair so if you use normal guide seals they want to slip off real easy, and smoke like hell
Re: Took The Rampage Out... First Time [Re: emarine01] #1261818
07/05/12 05:44 PM
07/05/12 05:44 PM
I had to drive my seals on so I'm sure thats not it
but thanks
Re: Took The Rampage Out... First Time [Re: Twostick] #1261819
07/05/12 07:20 PM
07/05/12 07:20 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Nice....
Can't wait to see it finished.
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261820
07/05/12 07:25 PM
07/05/12 07:25 PM
Lehigh Acres, Florida
rickstershemi Offline
Congrats Mike....Looking & sounding great....I'm sure you'll have those li'l gremlins that always show up sorted out in no-time
Rickster
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261821
07/05/12 08:51 PM
07/05/12 08:51 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Well I'm glad the trans works!
Congrats on getting it on the road Mike. I know it's been a ton of work and a long time coming. No better feeling then running it down the road for the first time!
Re: Took The Rampage Out... First Time [Re: dizuster] #1261822
07/05/12 11:40 PM
07/05/12 11:40 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Sounds great, very cool.....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261823
07/06/12 01:34 PM
07/06/12 01:34 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
That thing sounds wicked! I think I will duplicate that engine for my truck.
Re: Took The Rampage Out... First Time [Re: Devilbrad] #1261824
07/06/12 02:31 PM
07/06/12 02:31 PM
Thanks guys... now I need to order a couple of AN fittings,
I ran out... got the charging circuit running(holds
a nice 13.7 volts)... now to finish up the interior
(gotta put the carpet in and bolt the seats in)
EDIT
Yeah it sounds pretty good for a pump gas engine
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261825
07/06/12 07:59 PM
07/06/12 07:59 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I can't believe how fast you got that done.
Good luck and as always stay safe.
Very nice work. It sounds pretty mean. Love it.
Re: Took The Rampage Out... First Time [Re: POS Dakota] #1261826
07/06/12 09:12 PM
07/06/12 09:12 PM
LOL... I'm FAR from being done... still do the interior,
do ALL of the body work(welding in some new metal)
painting... still need to change a 4 springs on the
suspension(fronts are too stiff and the rears are weak...
but I'm getting things done daily... today was so
damned hot I only worked a half day but did get some
stuff done
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261827
07/07/12 12:04 AM
07/07/12 12:04 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Very nice
That thing sounds nasty...and it will surely be unique
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Took The Rampage Out... First Time [Re: OUTLAWD] #1261828
07/07/12 12:18 PM
07/07/12 12:18 PM
Well I fixed one oil leak(where the oil filter use
to mount, I have 2 fittings screwed into the block
to go to the remote filter) BUT both of my big dollar
#10 90% swivels are both leaking at the swivel...
changed 1 and that stopped leaking but didnt see the
other was leaking till now... gotta see if I have
some more non swivel fittings... what a bummer
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261829
07/07/12 01:02 PM
07/07/12 01:02 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Neat!!! Looks like you are having some fun
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Took The Rampage Out... First Time [Re: 6bblFLASH] #1261830
07/07/12 01:41 PM
07/07/12 01:41 PM
Looks like the leak was causing the oil out the pipe
issue... once I get the exhaust warmed up good I'll
retighten both ball sockets on the exhaust to seal
Re: Took The Rampage Out... First Time [Re: MR_P_BODY] #1261831
07/07/12 05:26 PM
07/07/12 05:26 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Sounds great !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Took The Rampage Out... First Time [Re: bigdad] #1261832
07/08/12 09:06 AM
07/08/12 09:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
That thing turned-out great Mike! Good work, it looks and sounds right.
Re: Took The Rampage Out... First Time [Re: HardcoreB] #1261833
07/08/12 11:35 AM
07/08/12 11:35 AM
Thanks Sean........ I'm not happy with the engine...
I pulled the plugs today and alot of them are some
what oily and but the thing is dog fat, I was looking
for my vac gauge but I cant find it OR my compression
gauge... I believe I loaned it out but dont remember...
but I want to do a few checks and if I'm not happy
I'll pull the engine/trans today
