a-body front suspension/steering #1261071
07/02/12 10:43 PM
07/02/12 10:43 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
any input or pics you may have of the front of an abody with a altered stock kframe,suspension and steering would be great,just want ideas on what the best route would be to go in the 9s with a big block in a 74 dart sport the car already has a cage backhalved ladder bars coil overs dana rear.i been out of this awhile and i know parts always change but if i can alter the stock stuff to take the beating i would rather. thank you,jeff
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: a-body front suspension/steering [Re: jsmopar1072] #1261072
07/02/12 10:48 PM
07/02/12 10:48 PM
the car
Re: a-body front suspension/steering [Re: jsmopar1072] #1261073
07/02/12 10:48 PM
07/02/12 10:48 PM
back
Re: a-body front suspension/steering [Re: jsmopar1072] #1261074
07/02/12 11:05 PM
07/02/12 11:05 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Bob's pro fab.
Re: a-body front suspension/steering [Re: rowin4] #1261075
07/02/12 11:08 PM
07/02/12 11:08 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Bob's pro fab.
Re: a-body front suspension/steering [Re: jsmopar1072] #1261076
07/02/12 11:40 PM
07/02/12 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a set of struts on it... cheapest and lightest
way to go
Re: a-body front suspension/steering [Re: MR_P_BODY] #1261077
07/03/12 03:10 PM
07/03/12 03:10 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
BOBSPROFAB---this is the 1/2 kit,i did not get the tubulor k-frame & rack---yet
70 dart B1MC N/A 8.80s @ 155-3350lb 10.5 tire
i love it,went right together no problems
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: a-body front suspension/steering [Re: ROSSIO] #1261078
07/03/12 08:15 PM
07/03/12 08:15 PM
are you using a rack or a stock box?
Re: a-body front suspension/steering [Re: jsmopar1072] #1261079
07/03/12 11:00 PM
07/03/12 11:00 PM
My Duster runs in the low tens and the high nines occasionally, it has the 1973 and later A body stock disc brakes, upper and lower control arms and ball joints, stock bushings and so on. I replaced all the wear items like the brakes, bushings, bearings, seals and ball joints. Are you wanting to lighten it up, make it stronger or what?
Re: a-body front suspension/steering [Re: Cab_Burge] #1261080
07/03/12 11:07 PM
07/03/12 11:07 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I run a similar car, A-body duster 10.10 at 134 and the stock front end can be a pain. The control arms and the a-arms all have play in them even after replacing many of them, the stock drum brakes don't help either. All those rubber parts, play havok with reaction times if your a foot brake racer.
Running the tubular stuff in my other car I do know removes a lot of the play and increases adjustability. I would go with Bob's as well with what you can afford, and go from there.
Re: a-body front suspension/steering [Re: Dragula] #1261081
07/04/12 10:41 AM
07/04/12 10:41 AM
im really just trying to make sure the car can handle goin nines on stock stuff,side note i just bought the car and it had an alterKation set up in it but was sold before i got it. the front suspension was just put in loose to get it on trailer. so if im gonna make a move i might as well do it now.
Re: a-body front suspension/steering [Re: jsmopar1072] #1261082
07/04/12 11:00 AM
07/04/12 11:00 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I never understood the notion that it takes the spending of thousands of dollars on trick front ends in order to get a Mopar to handle. My street driven Duster (which HEMIFRED now owns) ran low 9's with mostly stock steering and front suspension components. The only exceptions were changing from torsion bars to coil overs, but that was done to increase space for the 2-1/4" headers. Also, I went with tubular A-arms for two reasons, so the coil overs could fit properly, and for the ability to dial in more positive caster. Lastly, I had the steering box rebuilt by Steer n Gear, which eliminated all of the sloppiness and made a big difference in steering feel. As far as the K-frame was concerned, it was left stock. That's it. I could drive it on the top end of a 9-teens pass with one finger on the wheel.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: a-body front suspension/steering [Re: DusterDave] #1261083
07/04/12 02:54 PM
07/04/12 02:54 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
i went 8.90s with the stock susp for the past 2 years--this past winter i got the half kit from bobs--i still use the stock str box.
i havent had time to "dial" in the coil overs yet---its been upper 90 degrees and i'm not going out to the track in this heat,we did get to got out in april and off the trailor it went 8.86--so my initial set up must have been close
Re: a-body front suspension/steering [Re: ROSSIO] #1261084
07/04/12 03:05 PM
07/04/12 03:05 PM
PA
moparacer Online content
moparacer  Online Content
PA
Been 9.16 @ 145 with a stock front.
Only aftermarket parts are shocks and strut rods.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: a-body front suspension/steering [Re: moparacer] #1261085
07/05/12 09:34 AM
07/05/12 09:34 AM
well hopefully carlisle will have what i need this weekend i do really like the coil over set up just cant swing the tab.right now. thanks guys
Re: a-body front suspension/steering [Re: jsmopar1072] #1261086
07/05/12 10:02 AM
07/05/12 10:02 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Super stock hemi cars going 8.20's@160 with stock front ends.
JAKES AUTOMOTIVE
Re: a-body front suspension/steering [Re: JAKE68] #1261087
07/05/12 03:18 PM
07/05/12 03:18 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
I personally like the appearance of the stock front end too. Can you tell me from your experience do you need to make the mods to the spindles like they show in the 68 SS Dart book?
Re: a-body front suspension/steering [Re: jsmopar1072] #1261088
07/05/12 04:29 PM
07/05/12 04:29 PM
The key to good handling is to have good parts in the front end and a good alignment I like to see as much postive caster as I can get and zero camber with the front end raised up one inch from static, all alignments made with the drivers weight in the front seat and a full tank of fuel, car ready to race also, tire pressures and all the little details laike that. I like to have no more than 1/16 inch toe in with the front end raised up one inch also. Do the research on toe patterns for your frontend and correct it if needed Good luck
Re: a-body front suspension/steering [Re: Hemi SS] #1261089
07/05/12 04:33 PM
07/05/12 04:33 PM
Finland
mafo Offline
mafo  Offline
Finland
run as much caster you can get, stock 6 cyl suspension ,158 mph no problem
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: a-body front suspension/steering [Re: mafo] #1261090
07/07/12 10:39 AM
07/07/12 10:39 AM
i took every thing out and apart to just rebuild it and the kframe is now welded up and i just added some loops to pull it up onto trailer. i do have the small block torsion bars already.so i guess just making the stock parts a little stronger is what ill do.
