Page 7 of 7 1 2 3 4 5 6 7
Re: What do your heads flow? [Re: bwhackd34] #1259404
07/18/12 10:24 PM
07/18/12 10:24 PM
detroit area
moderncylinder Offline
detroit area
ok you gave "us"
470cfm
260fps at throat
330fps at short side
95-96% throat of valve size
you dont see that by figuring back from the velocity at the throat, and the airspeed,, that some relation can be made to the area at the short side? it can...
must be all voodoo top secret spy porting suff going on here,, magic..
your ca formula doesnt work to real world data,, it gives a ca that is larger than what is actually seen
Re: What do your heads flow? [Re: moderncylinder] #1259405
07/18/12 10:34 PM
07/18/12 10:34 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
No.....the 330ish was a rough average through the port....at SSR wasn't stated......
Re: What do your heads flow? [Re: moderncylinder] #1259406
07/18/12 10:36 PM
07/18/12 10:36 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
ok you gave "us"
470cfm
260fps at throat
This is what I was saying the other ay regarding we as humans and the airflow 'seeing' the CA from different perspectives....
Goodnight
