Re: What do your heads flow?
[Re: bwhackd34]
#1259348
07/16/12 09:19 PM
07/16/12 09:19 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
it is no theory that minimum int cross section limits cylinder filling in the comp stroke, thus limiting the peak engine speed of the engine,, you cannot "cam" the motor to run past where the int port will peak,, though many think you can and try to do it causing you to loose power everywhere,,
i have a dyno here,, and see it,, as with talking with my friends/customers who race nhra,,, super stock,, comp,,, or pro stock
[Re: moderncylinder]
#1259350
07/17/12 03:10 AM
07/17/12 03:10 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
i am working on some ford d-3 heads for a drag race aplication which will have whatever lift it needs,, probably 1.000 or around there,, 2.250 valve and i need 470 or so cfm,, like what you have,, though my head has a canted intake valve so my mid numbers will be much more than yours,, my peak i hope to get what you have,, im looking to put it on a 373 inch motor that runs to 10,000 and make 1040 hp,, i need a min cross section of 3.75 to do this,, you cannot get that big due to the casting restraints you have,,
if you have airflow,, port cross section to support displacment,, and mixture motion entering the cylinder that all works,, it WILL make power between 2.2-2.4 hp per cfm,, so if you put your motor together and its serious, id expect 1040-1100 hp,, if not,, the head isnt what its supposed to be,, its that easy
that being said,, my 373 inch motor in a 2825lb car,, should go 7.70's with a liberty 5 spd,, making 1040hp at 9600-9800rpm
W9's were what the NHRA ProStock trucks used to run 7.50's with 358cui in truck that weighed the same IIRC. So they should be just as capable.
For all the nay-sayers has anyone gotten a hold of or talked to anyone that had first hand knowledge of the ones used in ProStock Trucks??
[Re: bwhackd34]
#1259355
07/17/12 10:16 AM
07/17/12 10:16 AM
moderncylinder
detroit area
darin is correct for the most part,, but what he said and what i said arent the same,, read it again,, i never said the intake ports go sonic,, exh ports can,, beacuse of the pressures in the cylinder when the exh valve is initially opened.. the intake port cross section will just limit how high the engine will peak at,, everybody knows that....... and pro stock trucks used w-9 heads when they were slow,, they used p-5 heads when they were fast,, also,, a "good" pro stock truck w-9 flowed just about 390-400,, which is enough to make 950hp,, he is claiming 470,,, see my point yet???
also,, i have a cnc machine,, and computer software for it,, i can see the ports on my computer screen and slice them wherever i want,, not use calipers and guess,,, plus like i said,, ive worked on engines along with others,, and witnessed peak power at a predicted rpm based on minimum int cross section and runner length
[Re: bwhackd34]
#1259360
07/17/12 02:32 PM
07/17/12 02:32 PM
moderncylinder
detroit area
the mca,,,,, will effect the ports pressure on the cylinder during filling in the compression stroke,,, when you have a port that flows extremely well,, its obvious the filling in the intake stroke will be enhanced,, therefore when the piston starts comming up, compressing that mixture there will be more charge in the cylinder, causing more pressure,, the point at which the pressure of that compressed mixture becomes equal to that of the inertia pressure in the intake runner becomes equal,, you must close the valve,, inertia increases as engine speeds comes up, or gets higher to the point that the mca restricts it, causing it to stall, and not produce anymore,, therefore anything past that speed will push charge back into the runner if the valve is open longer, loosing power
its not that "I" cant get your numbers,, nobody on the planet,, but you,,, can,,,im not saying they arent true,, id just like to see you validate them with somebody else,, its not like you got 440 out of them,, which would be a high number,, but maybe possible,, you got 470,, that number is so high,, higher than anybody has heard, got,, etc...
