Re: What do your heads flow?
[Re: 65 Hemi]
#1259324
07/02/12 09:15 AM
07/02/12 09:15 AM
Posts: 617 PA
bwhackd34
PA
This has been a subject of other posts on here but I am working on a w9 port design that right now flows upwards of 445@.850" and very near 470@1.00. Velocity down the port is near 325-335 and about 260ish through the throat....port volume around 300cc....still a work in process...
[Re: Scott58]
#1259328
07/15/12 05:29 AM
07/15/12 05:29 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
245 s are 200 129 , after a touch up 300 202 215 400 260 281 500 305 323 600 334 344 700 330 349 333 with unported intake carb 230 are ported 200 163 300 233 400 300 500 330 600 340 700 340 699 hp 330 676 hp with dom ,spacer,ported intake
[Re: Ian]
#1259329
07/15/12 12:11 PM
07/15/12 12:11 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine are older KB heads. Hopefully my 496 with the help of a 10-71@12 pounds of boost and the right cam it will make around 1100 streetable hp.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: bwhackd34]
#1259330
07/15/12 08:49 PM
07/15/12 08:49 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
This has been a subject of other posts on here but I am working on a w9 port design that right now flows upwards of [Email]445@.850"[/Email] and very near [Email]470@1.00.[/Email] Velocity down the port is near 325-335 and about 260ish through the throat....port volume around 300cc....still a work in process...
Is that a typo, or are these the very best W9's in the country?!
[Re: Diablo]
#1259331
07/15/12 09:00 PM
07/15/12 09:00 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Diablo... you posting that this early makes us small block guys not wanna post...lol
So I should wait some more before posting these heads??
Our Brad 8's are right at 570 on the intake.
[Re: bwhackd34]
#1259335
07/16/12 04:16 PM
07/16/12 04:16 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
i still think you need to validate your numbers on another bench and have them post what they are here,,, nobody gets those heads to flow like that up high cause they just arent big enough,, your numbers up to .700 lift are normal or down,,, those heads flatten out past .600 and flatline at .800 usually at 420 or so if real good,,, you getting 470 is crazy good,, and you would need to be big enough to move that much air through,, 95.5 % throat which is huge again,, leaves you like a .020 wide bottom angle,, which usually doesnt work,, but you mention velocities through the throat and then the port,, implying your minimum cross section is 3.00 sq inches of area,, if you have a 2.300 valve in it,, which i dont think will fit in that head,, but you wont say like its super secret,, so ill guess its some huge valve, which is big,, but normal for min area..
i though you said this is going on a street/strip pump gas motor,, if so why focus on airflow from .800 and up?
[Re: bwhackd34]
#1259339
07/16/12 05:43 PM
07/16/12 05:43 PM
moderncylinder
detroit area
i am working on some ford d-3 heads for a drag race aplication which will have whatever lift it needs,, probably 1.000 or around there,, 2.250 valve and i need 470 or so cfm,, like what you have,, though my head has a canted intake valve so my mid numbers will be much more than yours,, my peak i hope to get what you have,, im looking to put it on a 373 inch motor that runs to 10,000 and make 1040 hp,, i need a min cross section of 3.75 to do this,, you cannot get that big due to the casting restraints you have,,
if you have airflow,, port cross section to support displacment,, and mixture motion entering the cylinder that all works,, it WILL make power between 2.2-2.4 hp per cfm,, so if you put your motor together and its serious, id expect 1040-1100 hp,, if not,, the head isnt what its supposed to be,, its that easy
that being said,, my 373 inch motor in a 2825lb car,, should go 7.70's with a liberty 5 spd,, making 1040hp at 9600-9800rpm
