What do your heads flow?
#1259284
06/29/12 06:44 PM
06/29/12 06:44 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Just curious what people have. What do your heads flow? What kind of heads? What kind of work done to them? What's the motor combo and how much HP?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: What do your heads flow?
[Re: 65 Hemi]
#1259285
06/29/12 09:33 PM
06/29/12 09:33 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
355 at .700. 335 at .600 i think. cam around 630 lift, 493. 12to 1
indy EZs I ported to MW size. VJ and backcut by Porter
my challenger ran 6.20s at 110 at 3500 thru full exhaust
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1259286
06/29/12 09:58 PM
06/29/12 09:58 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
Coleman/Arrington Craftsman Truck 15* W8, touched up by MBE....
403 @.800
417ci R3 420 intake....894hp @8200
[Re: jim sciortino]
#1259287
06/29/12 10:22 PM
06/29/12 10:22 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Square port style b1-TS heads. Modern worked on them and tried to brining the flow up but there only so much that could be done with the square ports. 2.40 intake valve. flowed 490cfm@900636ci engine made 1150hp
[Re: 65 Hemi]
#1259293
06/30/12 01:42 AM
06/30/12 01:42 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
INDY 245cc raised port flow all the water in my cooling system throught the ex ports in 6.30 sec.. russ said that was normal and to go [Edited by Moparts - Family Friendly Site - Keep it clean] myself
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mopartony]
#1259296
06/30/12 03:08 AM
06/30/12 03:08 AM
Posts: 833 MN
hemidup
MN
Hand ported 5.7 Gen 3 Hemi heads. 320 cfm @ .575" lift on the intake and 219 cfm on the exhaust. Port velocity was 345 fps.
Jerry Williams.
[Re: 65 Hemi]
#1259298
06/30/12 09:08 AM
06/30/12 09:08 AM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
440-1 heads originally ported by Radar at R & J from Cedarfalls Iowa. VERY pleased with the power they made originally, but got greedy and tried to improve on the original work with 2.3 valves. Of the two plots on the chart, the lower flow plot was with 2.25 valves, one with 2.30 valves and exhaust reduced to 1.78 to make room for them. Didn't show a bit of power improvement with the bigger valves, so I may send them back to R & J and see what they can do, if anything to make use of the extra flow.
[Re: tboomer]
#1259302
06/30/12 10:03 AM
06/30/12 10:03 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Mine on 2 different benches, one was Modern Cylinder Head and the other was Dwayne Porter. Modern flowed the exhaust with a tube where Dwayne did not, that is why the ex numbers vary. Heads are Indy -1's that were hand ported by Barton. Motor made 850ish HP and is 557 cubes. Pushed my car to 9.ohs and a couple of 8 sec passes at 3000 lbs.
[Re: Bigcube]
#1259303
06/30/12 12:56 PM
06/30/12 12:56 PM
Posts: 2,915 A shed in England
Tig
A shed in England
We're around 380 cfm @ 700 hand ported but this is on a kit type, self assembly bench (can't remember the manufacturer ) Motor makes around 850 hp, runs mid 9's @ 3850lb (W/D) so figures are probably near.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
