Page 1 of 7 1 2 3 4 5 6 7
What do your heads flow? #1259284
06/29/12 06:44 PM
06/29/12 06:44 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Just curious what people have.
What kind of heads?
What kind of work done to them?
What's the motor combo and how much HP?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: What do your heads flow? [Re: 65 Hemi] #1259285
06/29/12 09:33 PM
06/29/12 09:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
355 at .700. 335 at .600 i think. cam around 630 lift, 493. 12to 1
indy EZs I ported to MW size. VJ and backcut by Porter
my challenger ran 6.20s at 110 at 3500 thru full exhaust
Re: What do your heads flow? [Re: sixpackgut] #1259286
06/29/12 09:58 PM
06/29/12 09:58 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Coleman/Arrington Craftsman Truck 15* W8, touched up by MBE....
403 @.800
417ci R3 420 intake....894hp @8200
Re: What do your heads flow? [Re: jim sciortino] #1259287
06/29/12 10:22 PM
06/29/12 10:22 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Square port style b1-TS heads. Modern worked on them and tried to brining the flow up but there only so much that could be done with the square ports.
2.40 intake valve.
flowed 490cfm@900
636ci engine made 1150hp
Re: What do your heads flow? [Re: Diablo] #1259288
06/29/12 10:24 PM
06/29/12 10:24 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Oval port b1-TS heads with much newer technology and porting. Koffles, Hemphil and a Local porter worked on them.
2.45 intake valve
520cfm @ 900
Made 1200-1250hp in our 640ci engine
Re: What do your heads flow? [Re: Diablo] #1259289
06/29/12 10:28 PM
06/29/12 10:28 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Diablo... you posting that this early makes us small block guys not wanna post...lol
Re: What do your heads flow? [Re: 65 Hemi] #1259290
06/29/12 10:44 PM
06/29/12 10:44 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
360@700-int, 255.5@700-ex. w9's, c&c by ryan, 440sb, est hp 700 pump gas. best 60'- 1.25. best et- 9.61.
Re: What do your heads flow? [Re: rickraw] #1259291
06/30/12 12:34 AM
06/30/12 12:34 AM
440-1 CNC ported by MCH, 370 at .600,700 and .800. 528 C.I. motor 12.8 to 1 comp. ratio with a single Holley 1050 Dominator made 845 HP at 6500 RPM with a bad set of headers that where smaller on the flanges than the exhaust port size are The motor had a small intermittent miss from 5200 RPM on The ported B1 by Koffels flow sheets show 420s at .700,800, and .900 Not on a motor yet so no power numbers.
Re: What do your heads flow? [Re: Cab_Burge] #1259292
06/30/12 12:53 AM
06/30/12 12:53 AM
Winter Park, Florida
classracer Offline
classracer  Offline
Not enough!!!!
70 Challenger A/SA 2441
Re: What do your heads flow? [Re: 65 Hemi] #1259293
06/30/12 01:42 AM
06/30/12 01:42 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
INDY 245cc raised port flow all the water in my cooling system throught the ex ports in 6.30 sec.. russ said that was normal and to go [Edited by Moparts - Family Friendly Site - Keep it clean] myself
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: What do your heads flow? [Re: WHITEDART] #1259294
06/30/12 02:35 AM
06/30/12 02:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Indy EZ heads 330 @ .600 and 348 @ .700. Ron
Re: What do your heads flow? [Re: 383man] #1259295
06/30/12 02:45 AM
06/30/12 02:45 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Don't know much about mine but what I was told.
P7 Heads, 400 range, not sure on lift would guess .700
Engine as I bought it made 856hp at 9000rpm with Legal NASCAR intake and carb.
Re: What do your heads flow? [Re: mopartony] #1259296
06/30/12 03:08 AM
06/30/12 03:08 AM
MN
hemidup Offline
hemidup  Offline
MN
Hand ported 5.7 Gen 3 Hemi heads. 320 cfm @ .575" lift on the intake and 219 cfm on the exhaust. Port velocity was 345 fps.
Jerry Williams.
Re: What do your heads flow? [Re: hemidup] #1259297
06/30/12 08:50 AM
06/30/12 08:50 AM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
My cnc'd Brewer Heads Should Flow almost 480 but I haven't had them on the bench. I'd Probably sell em if you need em.
Re: What do your heads flow? [Re: 65 Hemi] #1259298
06/30/12 09:08 AM
06/30/12 09:08 AM
gregsdart Offline
gregsdart  Offline
440-1 heads originally ported by Radar at R & J from Cedarfalls Iowa. VERY pleased with the power they made originally, but got greedy and tried to improve on the original work with 2.3 valves.
Of the two plots on the chart, the lower flow plot was with 2.25 valves, one with 2.30 valves and exhaust reduced to 1.78 to make room for them. Didn't show a bit of power improvement with the bigger valves, so I may send them back to R & J and see what they can do, if anything to make use of the extra flow.
Re: What do your heads flow? [Re: gregsdart] #1259299
06/30/12 09:26 AM
06/30/12 09:26 AM
tboomer Offline
tboomer  Offline
Greg...I saw your flow sheet at Radars.. If you send them back,don't be in a big hurry! He is way behind and they broke parts on the fuel car. My Victors have been there for a long time,I am getting close to sending them elsewhere. I want them done for the Mopar Max II race at Cedar Falls...
Re: What do your heads flow? [Re: tboomer] #1259300
06/30/12 09:29 AM
06/30/12 09:29 AM
gregsdart Offline
gregsdart  Offline
Bummer when the best guy around is swamped! Finally found the chart with the other valve flow data! (attached to previous post)
Re: What do your heads flow? [Re: gregsdart] #1259301
06/30/12 09:32 AM
06/30/12 09:32 AM
tboomer Offline
tboomer  Offline
He wanted me to help him but I can never get him on the phone. You should see the pulling tractor heads that they make from scratch..Very impressive!
Re: What do your heads flow? [Re: tboomer] #1259302
06/30/12 10:03 AM
06/30/12 10:03 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Mine on 2 different benches, one was Modern Cylinder Head and the other was Dwayne Porter. Modern flowed the exhaust with a tube where Dwayne did not, that is why the ex numbers vary. Heads are Indy -1's that were hand ported by Barton.
Motor made 850ish HP and is 557 cubes. Pushed my car to 9.ohs and a couple of 8 sec passes at 3000 lbs.
Re: What do your heads flow? [Re: Bigcube] #1259303
06/30/12 12:56 PM
06/30/12 12:56 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We're around 380 cfm @ 700 hand ported but this is on a kit type, self assembly bench (can't remember the manufacturer ) Motor makes around 850 hp, runs mid 9's @ 3850lb (W/D) so figures are probably near.
