Re: What do your heads flow?
[Re: mistress]
#1259306
06/30/12 02:13 PM
06/30/12 02:13 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Chapman CNC 285 Max Wedge Stage VI's: .400 285 .500 335 .600 362 .700 374 .800 381 Makes the 12:1 517 like a mega torque wedge below 4500 but pull more like a Hemi all the way to 6800+ I've had a couple sets of -1's over the years that flowed close to these up top, but they were not as torquey as far as roll on power as these. On a race that doesn't matter a bit but on a mid 3 geared 3700lb street driven car they were a real game changer in terms of broad torque and driving satisfaction
[Re: Maximus_Wedges]
#1259308
06/30/12 03:41 PM
06/30/12 03:41 PM
Posts: 1,019 Finland
mafo
Finland
more than 403... Cfe w8
391 ci R3 small block
around 900 @ 9000
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: racerx]
#1259310
06/30/12 07:45 PM
06/30/12 07:45 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Indy/Canfield 2.25/1.94 CNC'd by Indy, flowed 361.2@.700. Flowed by MCH, Jeff opened up the bowls now 386.2@.700. On my 605 pump gas street/strip motor. Best so far is 817hp/752ftlbs. We'll see how fast it can push a barn door before anymore work on them. Dave
[Re: mafo]
#1259311
06/30/12 09:08 PM
06/30/12 09:08 PM
Posts: 2,026 Trumbull,CT.
jim sciortino
Trumbull,CT.
around 900 @ 9000
Spill the beans.
[Re: 65 Hemi]
#1259313
06/30/12 11:39 PM
06/30/12 11:39 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Stage V replacement Hemi Not yet raced or dynoed. 572"
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1259315
07/01/12 11:35 AM
07/01/12 11:35 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Mine are same, and same size motor. Not yet raced nor dyno'd either
[Re: DJVCuda]
#1259317
07/01/12 08:23 PM
07/01/12 08:23 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Diablo... you posting that this early makes us small block guys not wanna post...lol
So I should wait some more before posting these heads??
[Re: Diablo]
#1259318
07/01/12 08:42 PM
07/01/12 08:42 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
my indy 572-13,s 365 cnc'd flowed 388@ .800"
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: WHITEDART]
#1259320
07/01/12 10:20 PM
07/01/12 10:20 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
INDY 245cc raised port flow all the water in my cooling system throught the ex ports in 6.30 sec.. russ said that was normal and to go [Edited by Moparts - Family Friendly Site - Keep it clean] myself
lol my 245-1 are 349 @ 700 and flowed enuff water in the intake ports to empty the Mississippi river
[Re: 65 Hemi]
#1259321
07/01/12 11:13 PM
07/01/12 11:13 PM
Hemi Allstate
Mt. Eden Ky.
This is not mine. I saved this from a Moparts post from 2009.
FHO CNC Ported Stage V Replacement Heads. For mild to wild street strip engines. FHO CNC Replacement Head- Notes- application Blown Pro-Street Hemi - Use 45 degree wide seats for durability. Note - Use stock intake and exhaust port openings. Exhaust Port with 1.90" Valve Intake Port with 2.30" Valve Flowed at 28" without tube. Flowed at 28" .100" 61 .100" 75 .200" 135 .200" 159 .300" 187 .300" 248 .400" 230 .400" 315 .500" 258 .500" 384 .550" 267 .550" 412 .600" 279 .600" 435 .650" 287 .650" 453 .700" 295 .700" 467 .750" 298 .750" 469 .800" 301 .800" 471 Stage V Replacement Head with FHO CNC Porting. Tests performed on Superflow 600 with FlowCom. 4.500" Bore Plate Combustion Chamber 168cc Intake Volume 241cc Exhaust Volume 118cc Intake Valve 2.30" Ferrea Titanium Tulip 11/32" Stem Exhaust Valve 1.90 Ferrea Inconel TF Stainless Tulip 11/32" Stem
[Re: Hemi Allstate]
#1259322
07/02/12 03:43 AM
07/02/12 03:43 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
B1 MC's, 2.35" intake valves, 411 cfm at 0.8" lift, 970 hp at 6800 rpm on a 588 short block.
Plynouth VIP '67 TT IC EFI
