car stereo install issue, no dash or tail lights #1256574
06/24/12 06:01 PM
06/24/12 06:01 PM
mn
N
nates69b Offline OP
nates69b  Offline OP
N
mn
hi, can anyone give me any ideas about a issue i am having with my 69 superbee. I just put a pioneer stereo in and thought everything was fine. until i had to turn on my headlights and thats when I lost the stereo, dash lights, and tail lamps. The fuse blew, i replaced it however everytime the lights and stereo are on at the same time this occurs. any help would be appreciated. thanks
Re: car stereo install issue, no dash or tail lights [Re: nates69b] #1256575
06/24/12 06:09 PM
06/24/12 06:09 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
You have that circuit overloaded. Move the stereo to a relay,triggered
by an ignition switched 12V.,keep the yellow wire on a constant 12V.
source.
Re: car stereo install issue, no dash or tail lights [Re: Dan Halen] #1256576
06/24/12 08:34 PM
06/24/12 08:34 PM
mn
N
nates69b Offline OP
nates69b  Offline OP
N
mn
ok i thought thats how i had it, I wired yellow to the cig lighter, red to the ignition switch using the old stock plug and grounded the other. what does this relay look like?
Re: car stereo install issue, no dash or tail lights [Re: nates69b] #1256577
06/24/12 08:58 PM
06/24/12 08:58 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The red wire from the new radio should use the red wire that originally went to the factory radio. That is a 20A circuit. The backup power (often yellow) needs to go to a constant power circuit and this is usually a low current need so I usually use the cig lighter circuit as that is close by. If you are blowing the dash light fuse you have somehow tied into that circuit, BUT if you have, the radio should not work if the lights are off.
You need to go back and look at every wire you touched and see where you crossed things...
Re: car stereo install issue, no dash or tail lights [Re: Jim_Lusk] #1256578
06/25/12 01:20 PM
06/25/12 01:20 PM
mn
N
nates69b Offline OP
nates69b  Offline OP
N
mn
thanks all for the help, im going to try to get to it this week and will reply back with results
Re: car stereo install issue, no dash or tail lights [Re: nates69b] #1256579
06/25/12 06:08 PM
06/25/12 06:08 PM
mn
N
nates69b Offline OP
nates69b  Offline OP
N
mn
well i just found out what i think is the cause. one of the wires came out of the plug on the passenger side tail lamp, i dont know how or why, maybe it got bumped by a lawn chair or cooler that might have shifted or something, i put it back and now everythings working FOR NOW. kinda wierd, maybe its just coincidence that it happened the 1st time the lights and radio were on at the same time so thats what led me to think of the stereo. thanks for the help
