Re: 318 and 360 pistons
[Re: Dakota_Don]
#1256551
06/24/12 06:33 PM
06/24/12 06:33 PM
Posts: 2,177 ill
dennismopar73
ill
ummm no
some one may say yes,, BUT I WONT!! HI DON!
[Re: Clayton]
#1256556
06/24/12 07:55 PM
06/24/12 07:55 PM
RapidRobert
Not likely a 318 would take that much oversize plus the compression height of the 318 and 360 pistons is different & will not interchange
[Re: Baxter61]
#1256558
06/24/12 09:06 PM
06/24/12 09:06 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Comparison pic with 360 piston in the middle. It will probably be a low compression dog...
[Re: Reggie]
#1256559
06/24/12 10:11 PM
06/24/12 10:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Some have taken the old POLY 318 out that far and put a 3.58" stroke crank in them too.
But an LA 318? I would say no.
[Re: Supercuda]
#1256560
06/25/12 09:52 AM
06/25/12 09:52 AM
Posts: 15,487 Florida
scratchnfotraction
Some have taken the old POLY 318 out that far and put a 3.58" stroke crank in them too. But an LA 318? I would say no.
I have an old magazine artical that did this with a poly block 318,.120 over bore,3.58 stroke crank. forgot what pistons,I will dig it up and re-read it.
seems I have saw LA 318s bored for sleeves to go to .120 overbore at my local machine shop,said it was the only way unless a LA 318 was sonic checked to see if it was thick enuff for a large bore. very few but a couple have been found from what he said.
a few have said you can cut a 360 crank to fit the LA 318,then use early lopo 318 pistons with some clearceing on the piston pin boss and skirts, which will also help on the balanceing. makes a 346 stroker IIRC.
what I am doing is a cut down 3.58 stroke crank,.030 318 roller cam block, 349 stroker pistons, should be plenty torque for my truck and I had all of it exept pistons.
[Re: Clayton]
#1256564
06/27/12 11:14 AM
06/27/12 11:14 AM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
If my math is right I would only have to bore the 318 to 40 over, a 318 won't take a 40 overbore?
stock 318 bore is 3.91. .030 over 360 is 4.030....re-do your math. I get .120" over (or about 1/8")
then you have the compression height problem. a 318 has a 3.31 stroke, with pistons about 1.72" compression height stock. a 360 has a 3.58" stroke with ~1.6" compression height pistons, so if you used the stock 318 crank, you'd be like .2" down in the hole, and have no compression....
