Page 2 of 4 1 2 3 4
Re: Dodge Stratus...so close but so far away [Re: W9 Dart] #1256179
06/24/12 11:50 AM
06/24/12 11:50 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Sweeeeeet!
Re: Dodge Stratus...so close but so far away [Re: Bigcube] #1256180
06/24/12 12:54 PM
06/24/12 12:54 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
X 2, nice job. Did you set up the chassis for a small block and a big block?
Big block will be easy swap and then minimal work to mount a powerglide behind it...
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256181
06/24/12 12:59 PM
06/24/12 12:59 PM
tboomer Offline
tboomer  Offline
Looks great!!
Re: Dodge Stratus...so close but so far away [Re: tboomer] #1256182
06/24/12 01:24 PM
06/24/12 01:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I know what you are saying. I have a similar project.
Keep on keeping on.
Re: Dodge Stratus...so close but so far away [Re: FastmOp] #1256183
06/24/12 01:35 PM
06/24/12 01:35 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Very nice! Keep us posted on the build and tell us about the engine.
Bill
Re: Dodge Stratus...so close but so far away [Re: 340Cuda] #1256184
06/24/12 01:51 PM
06/24/12 01:51 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Bill
The motor is 408 in a R3 block and Indy 360-1 heads. Pretty mild combo that I used in my Dart.
Went 10.62 at 3,418 lbs, so Im hoping with some up-grades and a more areo 1,000lb ligter car it'll run ok for now...
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256185
06/24/12 02:37 PM
06/24/12 02:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Very nice
Re: Dodge Stratus...so close but so far away [Re: MR_P_BODY] #1256186
06/25/12 01:42 AM
06/25/12 01:42 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I cannot make up a word for how awesome this car is. Hands down one of the coolest cars I have seen!
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256187
06/25/12 07:25 AM
06/25/12 07:25 AM
Guitar Jones Offline
Very nice! I love it.
Re: Dodge Stratus...so close but so far away [Re: Guitar Jones] #1256188
06/25/12 07:59 AM
06/25/12 07:59 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Love it!
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Dodge Stratus...so close but so far away [Re: Jacob Pitt] #1256189
06/25/12 10:21 AM
06/25/12 10:21 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Thanks everyone for the kind words!!!
I have a Mopar buddy that came over yesterday while it was outside and he said "Dang this is the first new car I actually like."
Thanks again, now I just need to get it to the track THIS year.
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256190
06/25/12 11:29 AM
06/25/12 11:29 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
VERY NICE!!!Maybe I missed the details but more info on the engine-trans would be nice
Re: Dodge Stratus...so close but so far away [Re: DavidDean] #1256191
06/25/12 12:39 PM
06/25/12 12:39 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
For now its is my 408 that I used to bracket race in my Dart.
Its a R3 block, 408, 13 to 1, .630" solid with Schebuck lifters, Indy 360-1's slightly touched up by Dwayne Porter, 950 HP. 727 w/ griner brake and a 8" PTC converter.
This motor ran 10.62 iun my 3,420 lb Dart with smaller TTI headers, and exhaust system, and no vacuum pump.
Im hoping in a more areo 1,000lb lighter car it will run ok untill I can do something like 540-572. When I do a real motor some day I will also put a powerglide behind it. The chassis is set up for the big block and will only need a slight re-work to the trans crossmeber for a powerglide.
Here is a few more shots of the car. The chassis is all 4130 chromoly and certified to 6.0 in the 1/4.
Re: Dodge Stratus...so close but so far away [Re: tboomer] #1256192
06/25/12 12:55 PM
06/25/12 12:55 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
That is a Killer Job!!!!!!!!!!!
Re: Dodge Stratus...so close but so far away [Re: Mroctober] #1256193
06/26/12 07:47 AM
06/26/12 07:47 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Great Looking ride there. Looks like a lot of fun.
Just curious, why all steel except for the hood?
Re: Dodge Stratus...so close but so far away [Re: SCDaytona] #1256194
06/26/12 08:16 AM
06/26/12 08:16 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
Awesome build! Can you show pictures of how the chassis is mounted to the body? I always wondered how they mount them... Thanks
Re: Dodge Stratus...so close but so far away [Re: SCDaytona] #1256195
06/26/12 10:04 AM
06/26/12 10:04 AM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
Nobody makes parts for these cars...I guess because they make carbon/fiberglass bodies for Pro Stock?
Unless someone knows of a company that does I am unaware of anyone that makes parts for them.
Doors would be my best investment right now, they are about 40lb each after ALOT of work...
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256196
06/26/12 11:07 AM
06/26/12 11:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
wow, very nice!
Re: Dodge Stratus...so close but so far away [Re: Forest] #1256197
06/26/12 11:32 AM
06/26/12 11:32 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i am not a huge fan of big tire cars,however that looks outstanding!!! i really love the low stance and craftsmanship...great job you did mopar proud
Re: Dodge Stratus...so close but so far away [Re: stevet340] #1256198
06/26/12 01:08 PM
06/26/12 01:08 PM
SE Washington
Forest Offline OP
Forest  Offline OP
SE Washington
It may be hard to see but I bent hoops out of 3/8" & 1/2" chromoly tubing that rest in pinch welds etc. Then I welded them to the car body after it was mounted. I mounted the rocker panel to the rocker bar of the chassis in the same way...
Page 2 of 4 1 2 3 4
