Speed pro hellfire rings #1255238
06/21/12 07:17 PM
06/21/12 07:17 PM
Finland
Hessu Offline OP
Hessu  Offline OP
Finland
Hi.
4,375 speed pro hellfire rings and not sure which one is top and which second.
One have less tension two white stripe and dot and bevel facing down.
http://kuvaton.com/k/YouX.jpg
Another have more tension(is stiffener than another) two red stripe and two white stripe dot and bevel facing up.
http://kuvaton.com/k/Youf.jpg
Re: Speed pro hellfire rings [Re: Hessu] #1255239
06/21/12 10:04 PM
06/21/12 10:04 PM
Delray beach, Florida
P
Performance Only Offline
P
Hi.
bevel faces up on the top ring, it faces down on the 2nd ring.
machine shop owner and engine builder
Re: Speed pro hellfire rings [Re: Performance Only] #1255240
06/22/12 02:31 AM
06/22/12 02:31 AM
I think the main question is which one of those two is the top ring, I would bet the stiff one goes on top where the most heat is, hence the Hellfire name I thought Childs and Albert owned that name, "Hellfire" piston rings
Re: Speed pro hellfire rings [Re: Cab_Burge] #1255241
06/22/12 12:53 PM
06/22/12 12:53 PM
Out of the State of Confusion
blue_stocker Offline
According to the Flatlander racing site, the 'Hellfire' ring is the second ring, NOT the top. Might be best to trust Dan's post above or if in doubt, contact the mfg for info.
