Re: Dynomax Super Turbo Mufflers.!
[Re: gch]
#1254747
06/24/12 11:20 AM
06/24/12 11:20 AM
Posts: 768 Maryville tn
67coronetman
Maryville tn
I was going to do the x-pipe but under my car it would have been a little work so i did the h-pipe so far sounds great .! Quote:
And to add they sound even better with an x-pipe.
Old car are me......
[Re: 67coronetman]
#1254748
06/24/12 07:42 PM
06/24/12 07:42 PM
67coronetman
Maryville tn
I will post a video of my car now with the DynoMax Super turbo Mufflers on youtube in the next few days with my other videos of my car just to show how nice of a rummble it has now compaired to the video of it with the flowmasters.! I aint ever going back to the tin can sound again.! This video is with Flowmasters http://youtu.be/MqU-XnuUHkUhttp://youtu.be/iLMuETuCen4
[Re: 67coronetman]
#1254750
06/26/12 02:23 AM
06/26/12 02:23 AM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
Another satisfied customer here , been on my RR with 383 and 440, one of the best for over 11 years. Will use them again on my Olds when I drop that 500 Cad engine in it.....
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
[Re: 67coronetman]
#1254754
06/29/12 12:36 AM
06/29/12 12:36 AM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
I am very pleased with the way they sound is that your car if very nice.!
Yes, that was my car. I sold it a couple years ago. Thank you!
[Re: 67coronetman]
#1254755
06/29/12 02:12 AM
06/29/12 02:12 AM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
What is the difference in case lengths for? There is a 14 and a 20 inch. Is the 14 louder?
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: Mad_Scientist]
#1254758
06/29/12 12:20 PM
06/29/12 12:20 PM
67coronetman
Maryville tn
Ok after checking my are the 14" Dynomax Super turbo Mufflers. i have 3" pipe from the headers to the Mufflers with turn down that are turn outward just a little and i have a H-Pipe and its so much quieter inside & outside than the Flowmasters ever where and the drone noise is very very little.! Quote:
[Re: JohnRR]
#1254759
06/29/12 12:23 PM
06/29/12 12:23 PM
67coronetman
Maryville tn
I have the 14" Dynomax Super Turbo Mufflers with a H-Pipe and 3" to the rear of the car with turn downs and its very quiet compared to the flowmasters its night & day. Now if you have any sheet metal work that was not secured good its going to make noise i fixed mine for the most part.! Quote:
I have the short case on my Dart , it has a nasty drone , I want to try and fit the long case under the car, but against my ultimate goal of being as close to stock as possible for the PS drags, I am going to put an X pipe on the car to see if the drone goes away .
[Re: gch]
#1254761
06/30/12 04:55 PM
06/30/12 04:55 PM
67coronetman
Maryville tn
I already have the 14" ones and to be honest they are real nice sounding & for the most part queit and i really enjoy them but i should have gone with the long ones or a good set of Hemi mufflers.! Here is a video of my car now with the 14" Dynomax Super Turbo Mufflers. http://youtu.be/op9hfrhr1pAQuote:
The 14" will be louder than the longer case ones.Run the longest case muffler you can for noise reduction.
[Re: 67coronetman]
#1254762
06/30/12 08:11 PM
06/30/12 08:11 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Be carefule about the "HEMI" mufflers. I bought a pair from an advertiser here on Moparts. I figured that with 635 HP my HEMI would be louder than the originals which I remember, they sounded GREAT! Well, they must have been reproduction of Imperial mufflers. You couldn't hear the 540c.i. motor in a convertable while cruising, AT ALL! I installed 20" Dynomac Ultaflows and no drone, almost original Chrysler sound!
[Re: 67coronetman]
#1254764
07/01/12 11:33 AM
07/01/12 11:33 AM
Posts: 271 MO, USA
Tom Hand
MO, USA
On the same engine with everything the same, the 20" case Super Turbos measured about 2 dBA at idle and 3 to 5 dBa less at higher engine speeds, all at static conditions. Under load is slightly different but the 20" case version is most definitely quieter and less prone to drone. Even though they are quieter, they allow as much air to pass through due to the longer internal sections that enable the air to smooth out after the flow reversal (my theory anyway). Tom
