Page 1 of 3 1 2 3
The story of my car w/pics and video #1253555
06/19/12 04:56 AM
06/19/12 04:56 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
Well as some of you know and many others have asked in PM's my lowly street strip Dart has received some upgrades over the winter. The trusty 340, 904 and 8.75 served me well for many seasons. Roughly about 5 years, well over 1000 passes and immeasurable abuse on the streets. At times it served as my daily driver, I won numerous races in the car as well as a track championship. It was truly an amazing street-strip piece, but who can leave well enough alone.
The last time I raced the car down in Vegas over Thanksgiving, Went out on top.
I like everyone else I wanted to go faster! The car in its 12.60 trim was fun and competitive but again, faster is better. The 340 engine was getting long in the tooth anyways and would need replaced, or at least rebuilt. So about a year and a half ago I started preparing, purchasing parts, then selling the same parts to go a different direction, save money etc. My ADD was in full effect and at times it seemed like I would never have something to stick in the car. I spent countless hours weighing my options; small block? big block? gen 3 hemi? Until I finally came to a conclusion, sort of.
Taking it apart
Stroked small block seemed to be the simplest and best package for me. I already had headers, transmission would work, converter would work. So I set out to build a low maintenance small block engine that would run decent, still be drivable and not break the bank. My 340 was already .030 over, I have a complete standard bore 360 sitting on a stand that would make a good donor. But browsing craigslist one day I happened upon a set of rods and pistons for a “stock stroke 318, standard bore”.
They were eagle H beams and Ross pistons rings and bearings for a 396” small block stroker, brand new, never used and cheap. Who would build an entire motor around a set of rods and pistons? The same idiot writing this…. and I didn’t even end up using the pistons. I’m going to make a long story short and break down the rest of the engine combo below as it changed so many times, I can’t even keep track.
318 .030 over for 390”
BPE 4” crank
Eagle H beams
Diamond Flat tops (11.3:1)
Standard tension moly rings
Kevco oil pan
Cometics
Bullet Solid FT 263/268@.050 .656/.662 lift with 1.6’s
Howards EDM lifters
Ported Edelbrock heads [Email]280@.600[/Email]
Crane 1.6 rockers
Smith brothers push rods
Victor 340 OOTB
750HP Holley
1 5/8-3/4” TTI’s
Full 3” exhaust to the bumper
Tranzact Built 904
Pro tree brake
2.74 first gear
8” PTC converter flashes to ~4800
255/60/15 drag radial (27” tall)
4.10 gear
Inside a Kevco Pan
Knowing I was going to be putting more power to the car I pulled the old rear end out in favor of a slightly narrowed Dana. 4.10’s, spool, 35 spline axles, all the parts sourced from Dr. Diff. Truly a pleasure to do business with, and a very knowledgeable fellow. A 6 point moly rollbar was also installed along with a pair of Kirkey seats and RCI harnesses.
Future driver, my nephew, giving the car a test
The car was previously outfit with a full caltrac system, 4 shocks, bars and mono leafs, so I figured I would be good to go in the traction department, tubs were widened anyways just in case,
Obviously the stock fuel system wouldn’t be up to the task of feeding the new engine so a custom aluminum tank was purchased from www.hotrodcitygarage.com . I didn’t want to fill the trunk up with a fuel cell as I need the space for tools and other items at the track. An Aeromotive A1000 pump and regulator were acquired. I had heard lots of good things about the Earls Pro lite 350 hose so I ordered enough of that for a feed and return line as well as more fittings than I can remember. This hose is amazing to work with. No more pricked fingers trying to handle the stainless line, it cut it with a hose cutter, it’s just super easy to work with, I love it.
In typical fashion the car wasn’t complete and running until the night before the first and only test and tune of the year. That was also the only test and tune of the season before the points racing started. It being a completely new combination there have been many many headaches and hiccups the past 2 months but we seem to be approaching the light at the end of the tunnel.
Pictures of newly coated TTI's
The car only has 38 passes on it so far, and has run a best of 10.78@123.7 with a 1.47 60 foot time. 6600 shift, 6700 through the traps. It’s still a heavy pig, and I’m sure there is more left in it with tuning and playing with parts. I even drove it to work every day last week. For what it is I’m happy with it, hopefully I can do my job behind the wheel and find the winners circle soon.
I’ll conclude this by saying thanks to everyone who answered my questions, offered advice, listened to me whine about things not going according to plan, etc. There are too many people to list and I’m afraid I will forget someone. Big thanks to my brother Andrew (topfueldart), he has helped me do the majority of the work and let me use space in his garage on countless occasions to build the engine and do other tasks along the way.
Link to a time run, [Email]10.85@122[/Email] http://youtu.be/69XdA9AUdDg
Yes the mirror adjustment was needed
Well this is getting long and I'm tired, Thanks for listening.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: The story of my car w/pics and video [Re: Triple Threat] #1253556
06/19/12 05:24 AM
06/19/12 05:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow I did not realize you had it all done and raced it already. I must have missed a post or two. Looks and sounds great. Is it still pump gas ? Do you plan to still drive it on the street cause there is nothing wrong with 10.70 strreet cars. I would say she is running good. Did you hit your et goal you were looking for ? Nice job on it and congrats on 10's. Ron
Re: The story of my car w/pics and video [Re: Triple Threat] #1253557
06/19/12 07:33 AM
06/19/12 07:33 AM
BPE Offline
BPE  Offline
Dustin,
Thank you for taking the time to post your story with the pics. It's always interesting to hear how a build turns out. Good job and thank you for using my product.
Rod
Re: The story of my car w/pics and video [Re: BPE] #1253558
06/19/12 07:55 AM
06/19/12 07:55 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Very nice. The car looks and runs great.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The story of my car w/pics and video [Re: BPE] #1253559
06/19/12 07:59 AM
06/19/12 07:59 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Great work and good post
Re: The story of my car w/pics and video [Re: Tig] #1253560
06/19/12 08:37 AM
06/19/12 08:37 AM
tboomer Online work
tboomer  Online Work
Looks good,Dustin!
Re: The story of my car w/pics and video [Re: tboomer] #1253561
06/19/12 10:38 AM
06/19/12 10:38 AM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Nice numbers, thanks for posting all that. Its nice to see home builds. I've always been impressed with your accomplishments, a true hot rodder/racer.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: The story of my car w/pics and video [Re: Tig] #1253562
06/19/12 10:44 AM
06/19/12 10:44 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
X2 Really enjoyed reading it
Re: The story of my car w/pics and video [Re: 73swinger] #1253563
06/19/12 10:46 AM
06/19/12 10:46 AM
Northampton Pa
65 NSS 500 Offline
65 NSS 500  Offline
Northampton Pa
Nice Build,,Enjoy..
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: The story of my car w/pics and video [Re: Triple Threat] #1253564
06/19/12 11:29 AM
06/19/12 11:29 AM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Nice!!
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: The story of my car w/pics and video [Re: 65 NSS 500] #1253565
06/19/12 11:38 AM
06/19/12 11:38 AM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
outstanding! thanks for sharing your story with us, you are a true hotrodder
Re: The story of my car w/pics and video [Re: mopar400] #1253566
06/19/12 11:41 AM
06/19/12 11:41 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Very nice....
Re: The story of my car w/pics and video [Re: jim sciortino] #1253567
06/19/12 11:48 AM
06/19/12 11:48 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Nice
Re: The story of my car w/pics and video [Re: sixpackgut] #1253568
06/19/12 12:04 PM
06/19/12 12:04 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Nice man!
All these stout LA builds are making me rethink the RB route...
How are the street manners with that cam?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: The story of my car w/pics and video [Re: sixpackgut] #1253569
06/19/12 12:08 PM
06/19/12 12:08 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
SWEEEEEEEEEEEEEEEEEEEET! I was wondering why you commented on a post saying you went 1.49 in the 60'...I was thinking either you're on the bottle, or you changed your setup, because I have never seen a mid 12 second car 60' like that . Nice combo!! Now I'm getting the itch again to pull this little cam out of my stroker....
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: The story of my car w/pics and video [Re: FlyFish] #1253570
06/19/12 12:48 PM
06/19/12 12:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dustin I'm happy for you now that it is doing what you wanted it to do. Congrats on the license stuff as well. I know you will have a good year racing as you seem to everyyear no matter the car. Look forward to you guys coming down here again for the turkey race. Best of luck with the rest of the season!!
Re: The story of my car w/pics and video [Re: Al_Alguire] #1253571
06/19/12 01:02 PM
06/19/12 01:02 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Now you just need to bring it east!
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: The story of my car w/pics and video [Re: 383man] #1253572
06/19/12 01:04 PM
06/19/12 01:04 PM
Renton Washington
Renton Washington
Is it still pump gas ? Do you plan to still drive it on the street cause there is nothing wrong with 10.70 street cars. Did you hit your et goal you were looking for ? Nice job on it and congrats on 10's. Ron
Yep, still runs on 92 octane. Pump gas is the only thing I have ever run the car on this allows me to enjoy the car more. I drove it to work everyday last week, cruise it around when the weather is decent. As for my goals yes I would say it reached them, there are things that need upgraded still to get more power out of it, the carb, bigger header, bigger exhaust etc. But for now I am pleased with the way the car runs. Not many legitimate 10 second street cars running around up here.
Dustin,
Rod
Rod,
Thanks for providing the small block world with a great product at an affordable price. My machinist loved the crank, asked me multiple times where I got it so he could recommend them in the future.
Nice man!
Livable, but compared to the baby hydraulic that I'm used to it is a bit of a change. You hear the valvetrain noise, and the car sort of rumbles until about 2500 rpm. Doesn't bother me at all, other drivers on the road get a kick out of it and everyone I've taken for rides in the car enjoys it as well. This cam wasn't really designed with street driving in mind though, I told him pick the cam you would for a racecar, and I'll deal with the street manners.
Yeah there have been a few hints dropped before making this post. I dare you to put a cam in it!
Thanks Al, I look forward to coming down again as well. I'll take this time as well to thank another moparts member Jess for giving me the opportunity to license in his car this past weekend. Its a great working piece and really makes my car seem slow! [Email]9.02@142[/Email] lifting early was a ton of fun and I do appreciate him trusting me with his car.
You Indiana guys are bullies! All kidding aside I would love to, hopefully Chris and I can make it happen, or find rides over there and fly in
Thank you for the kind words everyone, There is something rewarding about building it all yourself and watching things develop. Thanks again!
-Dustin
Re: The story of my car w/pics and video [Re: Triple Threat] #1253573
06/19/12 01:09 PM
06/19/12 01:09 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Congrats in your racing life Dustin.. you sure have moved up in the world and if there's 1 driver that deserves it.. Its you..
Keep us low lifes up to date on how the car performs for you.. I think its safe to say we all get a kick out of your posts and stories..
Re: The story of my car w/pics and video [Re: Jeepmon] #1253574
06/19/12 01:13 PM
06/19/12 01:13 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
great post!
Page 1 of 3 1 2 3
