Page 1 of 3 1 2 3
Ok so my car is 5 tenths slow (update ) #1252233
06/16/12 09:36 PM
06/16/12 09:36 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Sounds like someone put a two barrel carb and a set of mufflers on it. 3 carbs-2 MSD boxs-2 fuel pumps-3 sets of plugs-cap&rotor. all been change. check valve lash 5 times ! springs look ok not that old-Just took the front of the motor apart everything on the timing chain looks great. also change it from e-85 to gas no change. timing is rock solid. 18-34 .
nothing in the oil filter. compression test good 100-170 . will not rev up..not crisp and clean. What else to check- ideas..split them out !
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252234
06/16/12 09:49 PM
06/16/12 09:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is the cable pulling the carb open and I would pull
the spring and check the pressure... has the balancer
moved
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252235
06/16/12 10:07 PM
06/16/12 10:07 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
You might want to check your muffler bearing!
Re: Ok so my car is 5 tenths slow [Re: 440charger500] #1252236
06/16/12 10:10 PM
06/16/12 10:10 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
carb coming all the open. ATI bal- still looks great has not moved
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252237
06/16/12 10:25 PM
06/16/12 10:25 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
fuel regulator? Are you running hoses and not tubing? could be colapsing the hose, no fuel then. But if you had E-85 in it. Rebuild the carb and clean it out. Mine would not idle, revved fine, idle = crap. rebuilt carb = charm.
E-85 is kind of nasty stuff. you will see a gray/black/silver sediment in the bowls of the carb.
If it doesn't work can get my back?
Re: Ok so my car is 5 tenths slow [Re: mopartony] #1252238
06/16/12 10:37 PM
06/16/12 10:37 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
well I have 3 three pieces of 2" long rubber hose on the car all the rest is steel. I have taken them all off and looked at them. and flow tested both pumps 3/4 gal in 30 sec. checked the vent on the tank also.both carbs are clean. both been check 2 times now. siting at Idle with 7 psi of fuel pressure it just don't rev up quick and clean.
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252239
06/16/12 11:19 PM
06/16/12 11:19 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
KeithVern,
I would check to make sure you have good 12+ volts to the MSD box and a good ground. Also check the resistance at the pick up coil and check the reluctor gap.
Probably something simple,if it were valvesprings,I would think it would rev okay and pop and bang at high rpm.
Keith
Re: Ok so my car is 5 tenths slow [Re: Dunnuck Racing] #1252240
06/16/12 11:24 PM
06/16/12 11:24 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I have check the gap. do you know what the resistance should be. it is a old stock style. Yep that what I thought on the springs in fact I just told my wife this LOL.. she is reading !!
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252241
06/16/12 11:27 PM
06/16/12 11:27 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
You have a PM. Jake
JAKES AUTOMOTIVE
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252242
06/16/12 11:28 PM
06/16/12 11:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it runs smooth with no miss,I'd be suspecting the converter.
Doug
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252243
06/16/12 11:29 PM
06/16/12 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The one set of springs I had did pop or miss... it
was just super lazy ... it was in valve float on the
whole run.... it was just a suggestion... but you
changed out most everything
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252244
06/16/12 11:31 PM
06/16/12 11:31 PM
Northern Indiana
Northern Indiana
ll the pickups I tested that were Mopar units or aftermarket replacements measured between 150-400 ohms. MSD units are around 750 so unless something else is bad,it should still run with that much.
Maybe a bad spot on one of the wires going to or from the box?
Keith
Re: Ok so my car is 5 tenths slow [Re: Dunnuck Racing] #1252245
06/16/12 11:55 PM
06/16/12 11:55 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Maybe a bad spot on one of the wires going to or from the box.
You mean power or ground to the MSD.? I will load test them tomorrow.
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252246
06/17/12 12:03 AM
06/17/12 12:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You should be able to stick a pin in the hot lead
(big red wire)and see if you have 12+ volts...
do it close to the box with the engine running
EDIT
I was just thinking Jamie... the big red and the black
ground come on the box so that would be a waste to
test it there(at the box) so test it where you hook
the red lead up at
Re: Ok so my car is 5 tenths slow [Re: MR_P_BODY] #1252247
06/17/12 12:15 AM
06/17/12 12:15 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Converter? Where is it slow? 60'? ET? MPH? Did it go away all at once or just gradually slow down? When mine looses .5 sec all at once, it's usually carrying a cylinder? Another question, if it lost it all at once, what changed? Possibly has a lobe down on the camshaft?
Brian Dunnigan
Re: Ok so my car is 5 tenths slow [Re: '72CudaRacer] #1252248
06/17/12 02:12 AM
06/17/12 02:12 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
You drove rather than Jenni? Yea I know f u.
Re: Ok so my car is 5 tenths slow [Re: ksj] #1252249
06/17/12 03:20 AM
06/17/12 03:20 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Had the exact same thing once. Changed EVERYTHING. Had the motor half tore apart twice. No help...
Turned out the COIL was going away. Well changed ALMOST everything. New coil and bada bom, bada bing! All of my lost ET and MPH back.
Re: Ok so my car is 5 tenths slow [Re: cudadoug] #1252250
06/17/12 03:35 AM
06/17/12 03:35 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
had similar problem. it was a wire comming out of my bulkhead connector. i did everything you did at least twice
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252251
06/17/12 04:51 AM
06/17/12 04:51 AM
Arizona
Chris'sBarracuda Offline
Arizona
What? 100psi is barely enough to fire a cylinder..
Chris..
Re: Ok so my car is 5 tenths slow [Re: Chris'sBarracuda] #1252252
06/17/12 10:14 AM
06/17/12 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris..
I sure didnt see that 100... in my mind it was 160-170
but your right... 100 will barely light the cyl
Page 1 of 3 1 2 3
