The extractor came out easily enough.
The bleeder was in for good.
It was a tiny extractor stuffed into a tiny hole inside a fat 10 mm bleeder. The extractor was bottomed in the bleeder and wedged in very tight.
I opened the hole one drill size and tried a heavier straight flute extractor. No dice.
Penetrant was no help.
I tried heating the bleeder.
I tried freezing the bleeder with aerosol.
I tried freezing the bleeder from it's center hole while the caliper was hot.
Each time something failed, I'd clean it up and take the next step.
Since it wasn't the brake caliper for my car I had no sense of urgency and took my time.
Nothing was working.
Eventually, I drilled it out and tried running a sharp 10 mm x 1.0 tap through it. No dice. The steel bleeder remains are STUCK to that aluminum. The steel was pushing the tap into the aluminum caliper. I stopped before it damaged the second row of threads.
The drill left enough meat for 75% depth on the threads according to my charts. I could see aluminum and steel spirals.
With a great deal of work I was able to use a sharp steel pick to get about 10% of the threads clear. Strangely enough, I was only able to pick out the steel in the center of the threads, not the top or bottom. The steel simply won't let go of the aluminum. I've never had that happen before. Usually, when you get to that point the old screw threads twirl out or break into pieces. Not this time.
It didn't appear to be cross threaded. What I can see of the threads does not look heavily distorted.
When I got the conical bottom part of the bleeder out of the hole the bleeder was clean but the bottom of the hole had some scarring around the perimeter.
It would take a pretty harsh environment for steel and cast aluminum to have a galvanic reaction but that's all I can assume.
The caliper is off a Porsche 964 race car. That means it's 18 to 23 years old. That's a LOT of heat cycles.
I did a quick Google search but did not find over size bleeders for a Porsche.
In a pinch, I could drill and tap the caliper one size larger and use a bolt and copper washer to plug the hole.
You could still loosen the bolt to bleed the outside pistons but it opens up a whole world of liability.
The car owner is a lawyer who just paid a bill today for hot rod work that exceeded what I paid for my daily driver. I'm sure he knows all about liability. When we spoke today he expressed a desire to get some track time in the morning but understood the situation.
At this point, the caliper is not damaged. If someone smarter than me could get the steel out it would still be a good caliper. I had my spindle stop set so the cutters would not damage the bottom of the bleed port.
I've already called the tech and told him the situation. He has a good rapport with the client and will pass the info along.
The caliper is like the red one on the left side of this pic.
