440 external oil pump question #1250976
06/14/12 02:51 PM
06/14/12 02:51 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
i am needing to order a new fitting for the external oil pump and i dont have the original one that was taken off of the motor. I know the
-12 an fitting will fit the braded hose but not sure what size for the oil pump it self. i believe i can us a -12 an fitting for this but not sure if i should use this or order a pipe X an fitting. if so the pipe size i think is 3/4". any help on this issue would be greatly appreciated, thanks.
Re: 440 external oil pump question [Re: mkbubs] #1250977
06/14/12 04:38 PM
06/14/12 04:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My milodon is all 12 AN not pipe.
Re: 440 external oil pump question [Re: mkbubs] #1250978
06/14/12 07:36 PM
06/14/12 07:36 PM
Are you talking about the fitting in the rear or on the top of the Mildon pump cover that one of the oil lines hooks to? If so, you need a male 12 AN fitting that is 12 AN O ring on one end and #12 AN male hose end on the other If not that fitting which other one are you talking about?
