Page 2 of 3 1 2 3
Re: Foot braking with Caltracs and preload? [Re: dodge340dart] #1249023
06/12/12 08:01 PM
06/12/12 08:01 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
CAL-TRAC SETTINGS
* Bottom hole – Softer Hit, moves IC forward
I don't think changing hole location changes IC... moving the spring eye mount up and down does though.
Mopar Performance
Re: Foot braking with Caltracs and preload? [Re: moparniac] #1249024
06/12/12 08:40 PM
06/12/12 08:40 PM
Menomonie,wi
menomoniemopars Offline
Menomonie,wi
Subscribing..
Re: Foot braking with Caltracs and preload? [Re: menomoniemopars] #1249025
06/12/12 08:54 PM
06/12/12 08:54 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
This is good stuff here. Now I have to figure out what my car likes. With a 1/4 turn preload, and launch from idle, I was getting a 1.55 60 foot. With a 3000 rpm launch, my 60 went down to 1.589. That's why I asked the question to begin with. I still think from my ET and my MPH, I should be getting a better 60.
Chris from New Jersey
Re: Foot braking with Caltracs and preload? [Re: fig426] #1249026
06/12/12 09:47 PM
06/12/12 09:47 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
foot braking,
with the driver in the car, I have the pin just touching the spring, no preload. the shocks are on 5. both side adjusted the same
Re: Foot braking with Caltracs and preload? [Re: nss guy] #1249027
06/12/12 10:22 PM
06/12/12 10:22 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
i run the caltracs on my satellite with XHD springs,small block t bars.
rancho rear shocks and QA1 single adjuster fronts.
set the caltracs as per instruction,i think 2 turns preload with driver on both sides,lower hole
front shocks full loose.i tried starting off rear shocks at 3-5 but found a lot of separation and wheel spin just off the line,topping out shock?.for the last 12 months have run the rancho's at #9,full tight extension,rarely have traction issues now.
1.52 60'best
never played with preload after that as it pulls straight
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Foot braking with Caltracs and preload? [Re: tex013] #1249028
06/12/12 10:51 PM
06/12/12 10:51 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
1.44 best 60' footbrake, launch at bout 2500, havent really loaded the convertor, driver side 1/4" form touching, pass side touching, top hole
best time in my sig
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Foot braking with Caltracs and preload? [Re: Stroker Scamp] #1249029
06/12/12 11:04 PM
06/12/12 11:04 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Not as good an angle, but this is the old springs with about .085 gap, it still has some separation during staging but not as much as it does with the spring touching the pin. The rpms should be near the same as the April 7 video. This was a 1.403 sixty foot.
Go about 1:05 in
http://www.youtube.com/watch?v=I_RGmcnTYJA&feature=youtu.be
Next time out we plan to experiment with moving the shocks to 9, upping the launch rpms, and adding air pressure.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Foot braking with Caltracs and preload? [Re: menomoniemopars] #1249030
06/12/12 11:09 PM
06/12/12 11:09 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Subscribing..
For your Bird?
I have a set-up for my Duster, but thought about trying them on my Dart 1st.
this is a good topic.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: Foot braking with Caltracs and preload? [Re: clovis] #1249031
06/13/12 08:38 AM
06/13/12 08:38 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
No, the first is about 3,000 and the second is about 2,000. The two are not really apples to apples on rpm nor springs/shocks, as the second video is on the monos with the shocks set at 8. The first is 6 cylinder springs/shocks set at 6 and spring just touching the pin. I will try to post a video with the old springs and a gap (no pre-load) to get a truer apples to apples. Even with the same spring/shocking setting and rpm, the difference in separation prior to launch is pretty significant. The preload really seems to make a difference.
Thanks for the info . I'm getting ready to tune my CalTracs again...first outing broke my spring perches and bent the rear housing. I almost have it back together again, but this time with a MO875 and a back brace.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Foot braking with Caltracs and preload? [Re: FlyFish] #1249032
06/13/12 09:13 AM
06/13/12 09:13 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We foot brake with the Duster, and I have the bars just touching the spring. Its been 1.29 at thompson but the norm is 1.31, 1.32. I dont leave on the verter, it seems to slow the car down. Dont ask why but when I leave at a idle it seems to hit harder. I really have played around with more gap in the bars yet.
Re: Foot braking with Caltracs and preload? [Re: moparniac] #1249033
06/13/12 09:54 AM
06/13/12 09:54 AM
Montgomery, PA
dodge340dart Offline
Montgomery, PA
Sledgehammer, you are correct; I found more information from Dave Morgan and this is what he said:
Before I say anything, I should begin by saying I have no doubts that the CalTrac bars offer an improvement in the traction of a car. The results are too widespread and too common to say otherwise. However, they do not improve the traction because they relocate the Instant Center (IC).
We define Instant Center as the center of the arc the rear axle moves around as it travels vertically. In this application, we also define the IC as a lift point (there are other ICs in the car that are also the center of an arc, but don't function as a lift point.)
In the case of the CalTrac bar, the front mount of the bar is on a pivoting shackle, which by it's nature means that the rear axle still rotates around the front eyelet of the leaf spring, which was and still is the IC of the rear suspension.
This idea was tried before in the '70s. Chrysler engineers designed a rear suspension called a leaf-link suspension which really did relocate the IC. It had a pair of upper control arms that were rigidly fastened to the differential housing and the chassis. The front of the leaf spring then functioned the same as the lower pair of bars on a fourlink, while the new upper bars did the same as the upper bars on a fourlink. In that design, there was no pivoting shackle for the front mount.
I had no idea the tuneable IC aspect was part of the CalTrac Bar patent, but I have had students and racers show me the instruction sheets that come with the bars.
Competition Engineering created a similar product called a Slide-a-Link which works on the same principle as the CalTrac bar. In this design, the lower bar has an inner tube and an outer tube that can be tightened to reduce the amount of sliding, or extension that these telescoping bars permit.
In both cases, I think all they do is reduce wheel hop by reducing, or eliminating, the spring wrap that occurs when a bunch of torque hits the pinion gear in a rear end.
I hope this helps.
Sorry, if my previous statement confused anyone.
Chris
2011 & 2012 Beaver Springs Dragway Outlaw Street Champion 2012 BSD Friday Street Racer Driver of the Year 3-time Jr. Stock Eliminator 2-time Mean Street Eliminator '69 340 Dart 1.500 60ft, 11.359et, 117.08mph
Re: Foot braking with Caltracs and preload? [Re: dodge340dart] #1249034
06/13/12 01:56 PM
06/13/12 01:56 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
70dusterjohn
Can you post some details on your car/setup/timeslips? Going 9.80's with a 1.31/1.32 60 ft is getting it done. Whatever you are doing seems to be working very well-school is now in session.
Thanks for any input.
'75 Plymouth Duster
Re: Foot braking with Caltracs and preload? [Re: clovis] #1249035
06/13/12 05:07 PM
06/13/12 05:07 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Headed to Island in a bit. Gonna try with an air gap and just touching without preload. See how it goes. Hopefully I'll be able to get 4 or 5 runs in.
Re: Foot braking with Caltracs and preload? [Re: fig426] #1249036
06/13/12 05:20 PM
06/13/12 05:20 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My E-body has Calvert's mono-leaf springs and the older 5-way adjustable Rancho shocks. The car weighs 3750#s w/ driver and 60-fts in the 1.45-1.46 range on 275/60R15 MT ET Street Radials.
Going by leaky memory (I don't have my notes on hand) I started w/ the 1/2 turn preload L&R that Calvert suggested, then only needed to increase preload on the right side 1/3 turn (also, as suggested by Calvert) to keep car from pulling to right slightly when coming off the line.
I don't launch any higher than about 2000 RPM from the foot brake to avoid pre-loading the chassis, either.
Re: Foot braking with Caltracs and preload? [Re: fig426] #1249037
06/13/12 11:01 PM
06/13/12 11:01 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Gonna have to wait for another day. Started the car to pull it out of the trailer,.... clackity clackity clackity.... and #6 intake valve is broken and through the piston. No good.
Re: Foot braking with Caltracs and preload? [Re: fig426] #1249038
06/14/12 01:49 PM
06/14/12 01:49 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
Oh wow that sucks lots of good info shared on this thread though
Re: Foot braking with Caltracs and preload? [Re: lowbudget] #1249039
06/14/12 04:08 PM
06/14/12 04:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Take this fwiw(on limited testing so far on new setup) cause I had later found out my shocks were topping out.... but during the issue prior when I added more preload the 60fts went worse... ( I run MT radials)
This would have been my best pass ever If I didn't get out of it early like a sissy from getting squirly up top
Mopar Performance
Re: Foot braking with Caltracs and preload? [Re: moparniac] #1249040
06/14/12 05:52 PM
06/14/12 05:52 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
As has been sort of implied... every combination is different.
Remember, the key to controlling tire spin, is finding a way to waste energy that would normally be used to overpower the traction to do something else. Sometimes it's body seperation, wheelies, spring deflection, etc...
What a caltrak is doing is managing that tire spin energy through spring deflection. If the spring is very stiff (lots of preload), there is no deflection left in the spring to "waste". If the car doesn't have the traction to use that energy, it will spin.
On the flip side, if the car already has enough traction and you let the spring "wind up" you're wasting energy that could be moving the car forward.
Ultimately on any given combonation, ALL of the energy eventually goes through the spring. It's the only thing that connects the body to the axle right? But what changing the preload does, is changes when that energy is applied. If the car is busy spending horsepower winding the spring up, it can't be spinning right?
That is basically how it works. Changing the bar location in the caltrac effects the above scenario. Putting the bar in the lower hole applys more pressure, at a slower rate to the front spring segment. Putting the bara in the upper hole applies less pressure at a quicker pace.
If the car doesn't spin, more pre-load will usually be quicker. The more pre-load you put in it, the stiffer the front spring segment becomes, and acts more like a ladder bar in the top hole at that point.
Re: Foot braking with Caltracs and preload? [Re: dizuster] #1249041
06/14/12 08:16 PM
06/14/12 08:16 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks for making it simple enough for ME to understand .
Fastest 300
Re: Foot braking with Caltracs and preload? [Re: fig426] #1249042
06/15/12 12:31 AM
06/15/12 12:31 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
If anyone cares to see the carnage ... https://board.moparts.org/ubbthreads/show...e=0#Post7249503
Page 2 of 3 1 2 3
