ROUGH IDLEING 340 #1248754
06/10/12 09:30 PM
06/10/12 09:30 PM
NJ
gregsgscuda Offline OP
NJ
Hi Guys I just got a 70 cuda 340 last week. Idled real bad because it had not run much in 5 years. I had the carb rebuilt new wires plugs dist cap roto new tank and all lines and still not running. The idel is about 1500-1800 and if i lower it stalls,I put my hands over the top of the carb slowly till its covered and the idle gets less. I dont think I have a vacume problem, but there is a lot of gas going in the carb when its at idle. The plugs are all wet with gas when I take then out but on the highway it runs good. I would be interested in knowing were number 1 is on the cap maybe its off by a tooth. Has anyone ever ran across this if PLEASE HELP.
Thanks Greg
Re: ROUGH IDLEING 340 [Re: gregsgscuda] #1248755
06/10/12 10:04 PM
06/10/12 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What carb is it
Re: ROUGH IDLEING 340 [Re: MR_P_BODY] #1248756
06/10/12 10:52 PM
06/10/12 10:52 PM
NJ
NJ
sorry for the down time, I see anything on it but I think the guy said somthing like AVC it was stock for the car.
Re: ROUGH IDLEING 340 [Re: gregsgscuda] #1248757
06/11/12 03:36 PM
06/11/12 03:36 PM
P
Paul_Fancsali Offline
P
Start with completly fresh gas and new set of plugs check the cap and wires and change the fuel filter
