Need Pics - Early B Clutch Linkage #1248261
06/10/12 09:24 AM
06/10/12 09:24 AM
dart1962_440 Offline OP
Looking to see where the torque shaft brackets mount on the frame and bellhousing. Converting from Auto to Stick. Anyone have pics?
Re: Need Pics - Early B Clutch Linkage [Re: dart1962_440] #1248262
06/12/12 07:48 PM
06/12/12 07:48 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
The outter bracket actually mounts to the inner fender on my 64 Polara. I converted it from pushbutton to 4 spd. When I pulled the gauge cluster I found there were dimples already in the firewall in the correct places to drill the holes for the stick shift pedals. SOMEBODY at Chrysler was thinking back then!
Jeff Adams 64 426 Polara
Re: Need Pics - Early B Clutch Linkage [Re: Ledman_70] #1248263
06/12/12 09:39 PM
06/12/12 09:39 PM
Thanks!
Any pictures or other references?
