Sudden slight smoking during warm-up?
#1248105
06/09/12 11:00 PM
06/09/12 11:00 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I recently changed out some Delvac diesel oil (either 15W-40 or 10W-40, I forget) for Quaker State's new "Defy" high-zinc oil at a 10W-30 mix.
Yesterday I noticed some light blue smoke out of my left pipe while I was letting it fast idle from cold.
I tried again just now and I still got some smoke, only out of my left pipe. It doesn't start immediately, only after the engine running at 1800 rpm for long enough to get the temp gauge up off the peg. After I knocked it down to regular idle, I was able to get a bit of smoke to appear from revving it but it seemed to go away altogether after a few more minutes. It's never very bad, I only noticed it from the smell at first and then the light haze, and it only seems to be coming from the right bank of cylinders.
I'm not too concerned since this engine doesn't seem to burn oil like it has bad rings or anything (I rarely need to top up more than once every six weeks or so) but I'm wondering where it could be coming from.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Sudden slight smoking during warm-up?
[Re: MNobody]
#1248108
06/10/12 02:12 PM
06/10/12 02:12 PM
Secret Chimp
Eugene, Oregon
Pull the breather on the valve cover and see if there's blow-by, compare with the other side. Probably valve seals, how many miles?
106,000 (more because of running with a slow speedo gear for awhile) but I changed the valve seals less than a couple thousand ago when I changed out my springs and camshaft. I pulled the breather on one side and valve on the other and not a wisp came out.
