I ran a Hughes Performance 2,500 stall torque converter with 3.23 gears back some years ago. You can purchase one from Summit Racing. Good product and price. Performed just like a stock converter but would flash to 2,500 RPM from a stop. Personally I wouldn't go any higher in a stall with 3.23 gears.
Hughes Engines (not to be confused with Hughes Performance) has the Whiplash cam that was designed for low compression, stockish engines. Performs very good and sounds lumpy. I run one now in my 383 with 3.73 gears and a converter that flashes to 2,500. I also run headers. Give Hughes Engines a call.
