Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247617
06/10/12 03:39 PM
06/10/12 03:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Good luck getting in there to get at much of the rust with a cordless drill.
Re: How would you clean up some rusty headers in the car? [Re: DaytonaTurbo] #1247618
06/10/12 04:17 PM
06/10/12 04:17 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Yep probably not going to get at much but i will try and go the paint on coating way i thing.
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247619
06/10/12 11:34 PM
06/10/12 11:34 PM
San Jose,CA
migsBIG Online happy
YouTube is my go-to news source
migsBIG  Online Happy
San Jose,CA
We did something like that on my friends 1970 nova couple years ago.
We lined the engine comparment with old blankets, then cardboard and finally some blue tarps.
Disconnected all plugs off the motornear the headers and put them on intake. Got some plastic wrapped around the top of the motor to pertect everything from the valve covers and up..
Had two cheapy dremel hand drill and used a combination of wire wheels and sand paper rolls to clean up the corners and medium grit sandpaper to clean up the long tubes.
Cleaned up as much surfact of rust, scale, paint and dust so the VHT had a better contact surface. Placed cardboard and masking tape behind the headers as to not get overspray on the motor. Added paint as needed and kept even coats going. Removing battery and altornator will allow you to have more room for spraying those hard to get angles.
Do about one coat every hours as directed (we did 3 coats) and was fairly warm that day. Let it cure overnite and let the paint adhere better. Next day we removed everything covering the engine, started the car, let it slowly get warmed up with the hood open to let it breath and cured better. About 15 min, we shut off the engine and did a inspection of the tubes. Everything was looking good so we started it for a couple more tries and let the paint cure nicely. Still looks decent after all the driving.
On another note, that was alot of work and my buddy earned an atomic charlie horse punch to his hind leg from me for being to hard headed about pulling headers off and having everything done off the engine which would have been easier and probably done in 1/2 the time it took us.
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247620
06/11/12 01:55 AM
06/11/12 01:55 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
So how do you suggust removing the rust? I saw about putting acid on them but maybe just a wire wheel on a cordless drill is better??
You can use the drill but in a month grill paint or whatever will be showing rust again in a month or two
Re: How would you clean up some rusty headers in the car? [Re: BulletBob] #1247621
06/11/12 10:08 AM
06/11/12 10:08 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Ya, seems like a lot of work. You must have a lot of time on your hands.
Either do it right (remove them, blast, re-coat), get new headers, or just leave 'em as-is.
Sux that TTIs get like that. Seems ridiculous for how expensive they are.
Wish they made stainless steel ones.
Re: How would you clean up some rusty headers in the car? [Re: 2fast4yourBrain] #1247622
06/11/12 10:26 AM
06/11/12 10:26 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Get a couple of the coarse Scotch Brite pads. Scuff them then paint them with the BBQ paint.
I am truckless..
Re: How would you clean up some rusty headers in the car? [Re: 340SHORTY] #1247623
06/11/12 11:39 AM
06/11/12 11:39 AM
the house on the left.
cogen80 Offline
cogen80  Offline
doesn't matter who coats them they will look the same as you have now in time.
the bbq paint is an option and i have a few friends using the stuff from eastwood. they put it on with a foam brush. if a spot pops up then they scotch brite the area and brush it up again. one of those two ways are probably best for a car that gets driven.
pretty sure this is the stuff..
http://www.eastwood.com/tlc-colorgard-black-4-oz.html
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247624
06/11/12 03:51 PM
06/11/12 03:51 PM
dogdays Offline
dogdays  Offline
Don't remove the rust. Wire brush off the thick stuff and paint with your favorite, either barbecue black or the VHT. I favor the dull barbecue black because it is not reflective so doesn't show the rough surface as much.
I have also used Ospho on rusty things but didn't have luck getting paint to stick, maybe I did something wrong.
R.
Re: How would you clean up some rusty headers in the car? [Re: dogdays] #1247625
06/11/12 09:08 PM
06/11/12 09:08 PM
Thanks for all the good advice!!!
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247626
06/11/12 09:17 PM
06/11/12 09:17 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
best advice? pay your daughters boyfriend to remove them so you can send them off to be re-coated.
or, threaten him with a bluff, and tell him that he needs to do it for free, or you'll behead him for what you saw him doing to your daughter last weekend, and when he looks at you funny, you repeat what you said, then add that you're not talking about the head on his shoulders, and that he may not have seen you, but you sure saw him, thanks to the GPS tracker you have in your daughters phone.
**Photobucket sucks**
Re: How would you clean up some rusty headers in the car? [Re: 70Cuda383] #1247627
06/11/12 09:36 PM
06/11/12 09:36 PM
Good ideas but the youngest daughter's boyfriend is so "sensitive" that he can only play video games. The oldest daughter's boyfriend is back home in NE on leave and she's on her way out to see him on Wednesday and the middle daughter likes books more than boys. So no soap on all fronts!
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247628
06/11/12 09:45 PM
06/11/12 09:45 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Not to play devil's advocate here, but, how old are those tubes???
Re: How would you clean up some rusty headers in the car? [Re: RSNOMO] #1247629
06/11/12 09:56 PM
06/11/12 09:56 PM
Good question they are about 9 years old or so. They lasted about 6 months looking like new and after that well you can see in the photo. The top parts of the tubes are like new it's just the bottom sections that look awful.
Re: How would you clean up some rusty headers in the car? [Re: MidPenMopar] #1247630
06/11/12 10:16 PM
06/11/12 10:16 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Really strange...
I'm gonna say I think you'll have adhesion problems unless you get that old 'ceramic' off...
Unless you're OK with having to touch 'em up every now and again...
What does TTI say???
Re: How would you clean up some rusty headers in the car? [Re: RSNOMO] #1247631
06/11/12 10:32 PM
06/11/12 10:32 PM
You are out of warrenty........
Re: How would you clean up some rusty headers in the car? [Re: 70Cuda383] #1247632
06/11/12 10:47 PM
06/11/12 10:47 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Stu - my suggestion is to create a couple really good oil leaks on your engine that constantly coat the headers in motor oil.. it'll keep them looking nice and black and shiny. Works for me.
Although, the oil spraying all over the underside of the car is kind of a bummer.. oh, and the smoke... oh yeah, and the mess on the garage floor too ...
