Can't get my dana axles to adjust correctly. #1245596
06/04/12 10:38 PM
06/04/12 10:38 PM
junction city oregon
V
viperblue72 Offline OP
V
I just replaced the axle bearings on my b-body dana. Trying to seat the axles I can only get the passenger side to Preload. No matter how tight it seems I get it, the driver side still has a bunch of play. Somebody help please.
Re: Can't get my dana axles to adjust correctly. [Re: viperblue72] #1245597
06/05/12 12:24 AM
06/05/12 12:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure the end play device is still in the block inside the posi I have seen them stick to the end of the axles and fall off out of the rear end
Re: Can't get my dana axles to adjust correctly. [Re: Cab_Burge] #1245598
06/05/12 01:18 AM
06/05/12 01:18 AM
V
V
Thanks Cab,
I looked at that today and the block is there. Is there another device that goes inside it? What does it look like? I rotate the adjuster clockwise until there is no play. But I can't get it to start pushing the drivers side. The block doesn't seem like it wants to move inside the powerlok unit.
Re: Can't get my dana axles to adjust correctly. [Re: viperblue72] #1245599
06/05/12 01:28 AM
06/05/12 01:28 AM
V
V
Just looked up in the tech index how it works.
Update- The thrust button is gone. . Looks like next I gotta find one.
Re: Can't get my dana axles to adjust correctly. [Re: viperblue72] #1245600
06/05/12 09:12 PM
06/05/12 09:12 PM
V
V
Dr. Diff hooked me up with a new set.
