Braking question Dodge Ram #1245289
06/04/12 01:42 PM
06/04/12 01:42 PM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
Hi guys. Question on my Dodge Ram 3/4 ton. When brakes are applied, the thing pulls to the left considerably. So I did some inspection and everything looks fine, slides fine, I took everything apart. Calipers slide freely, and the pistons move freely but only thing I noticed that was weird and seems to explain my problem is when the brake pedal is released, the driver side caliper retracts approx. a few thou, while the pass side retracts considerably more, about .040. What the heck? Why is this happening? Anyone have any insight to this? Thanks! (I also put new front brake hoses on as well and that didn't help).
Re: Braking question Dodge Ram [Re: Kelob_pie] #1245290
06/04/12 01:44 PM
06/04/12 01:44 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What year is it ?
I would look at the rubber line , it's probably collapsed internally.
Re: Braking question Dodge Ram [Re: JohnRR] #1245291
06/04/12 01:53 PM
06/04/12 01:53 PM
Kewaskum, WI
K
K
Kewaskum, WI
Truck is 1999 Ram 2500 V10 Auto tranny 4WD.
As far as the rubber line, I replaced that already thinking that it was collapsing as well, but it did not help one bit.
Re: Braking question Dodge Ram [Re: Kelob_pie] #1245292
06/04/12 02:05 PM
06/04/12 02:05 PM
Andrewh Offline
Andrewh  Offline
if it pulled left you need to look at the right side brakes not the left.
Re: Braking question Dodge Ram [Re: Andrewh] #1245293
06/04/12 03:18 PM
06/04/12 03:18 PM
Kewaskum, WI
K
K
Kewaskum, WI
Well, that is the thing, the right side piston retracts way more than the left, which seems to explain the problem, but why?
Re: Braking question Dodge Ram [Re: Kelob_pie] #1245294
06/04/12 03:30 PM
06/04/12 03:30 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That explains the pull as the right side pads are squeezing the rotor after the left side has already started squeezing.
I dunno, lots of possibilities - unequal piston friction in the calipers. unequal slider friction on the pads. Unequeal anti squeal goop on back of the pads. If you replaced both brake lines, look upstream at the hard lines and dist block. could be a kink or rust.
You could just keep throwing parts at it or buy a brake line pressure gauge and see if the pressure is equal on both sides before and after letting off the pedal.
Re: Braking question Dodge Ram [Re: Lefty] #1245295
06/04/12 03:34 PM
06/04/12 03:34 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
It could also be a bad seal in the left caliper not allowing the piston to retract like it should.
Since it sounds like most everything else has been checked, that would be the next thing I would look at. (how much is a rebuilt caliper?)
Re: Braking question Dodge Ram [Re: Kelob_pie] #1245296
06/04/12 05:18 PM
06/04/12 05:18 PM
put on a new/rebuilt passenger caliper
Re: Braking question Dodge Ram [Re: RapidRobert] #1245297
06/04/12 07:17 PM
06/04/12 07:17 PM
Kewaskum, WI
K
K
Kewaskum, WI
Yes, my gut feeling was that I was probably going to end up putting on new calipers, they aren't too expensive, we'll see what happens.
Re: Braking question Dodge Ram [Re: Kelob_pie] #1245298
06/04/12 08:21 PM
06/04/12 08:21 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
do them one at a time--and test it--tell us what happened---i think the non retracting one is at fault---bob
Re: Braking question Dodge Ram [Re: savoy64] #1245299
06/05/12 02:31 AM
06/05/12 02:31 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
FWIW,
I have the same problem on my 99 2500 B vanwagon.. pulls to the left on initial apply, seems like the left caliper has more residual pressure after braking.
I am going to try changing both calipers...
Re: Braking question Dodge Ram [Re: sthemi] #1245300
06/05/12 03:13 AM
06/05/12 03:13 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Make sure you replace both hoses, right and left sides.
Re: Braking question Dodge Ram [Re: mopars4ever] #1245301
06/05/12 09:49 AM
06/05/12 09:49 AM
Hampden, Maine
Procommuter Offline
super street
Procommuter  Offline
super street
Hampden, Maine
Could be a problem in the rear also.
Wes 73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
Re: Braking question Dodge Ram *UPDATE* [Re: Procommuter] #1245302
06/07/12 02:52 PM
06/07/12 02:52 PM
Kewaskum, WI
K
K
Kewaskum, WI
Well, I changed both calipers at the same time (I was pressed for time and couldn't really do one at a time and test drive)and a night and day difference. Truck brakes properly now and even better than I remember for a long time. Still doesn't make sense to me as both previous calipers slid nicely and pistons seemed to push in with the same force. Oh well, I am happy now.
Thanks for all the insight!
