need quick answer, muffler length for TTI exhaust. 14"?
#1243041
05/31/12 11:54 PM
05/31/12 11:54 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I know a guy whos selling a pair of almost new dynomax ultraflows for $30. those are the mufflers I want to run with a TTI exhaust on my 71 roadrunner. the only thing is, they are 14" case length. seems like they should be 20"? would they work or not? thanks -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: need quick answer, muffler length for TTI exhaust. 14"?
[Re: mopars_1]
#1243042
05/31/12 11:59 PM
05/31/12 11:59 PM
mopars_1
Ridgeland Wi
i posted before I even thought of google.. it looks like its suppose to be 25.5"?? anyone want to confirm?
[Re: mopars_1]
#1243043
06/01/12 12:06 AM
06/01/12 12:06 AM
Posts: 1,377 Houston,Tx.
Lee446
Houston,Tx.
The Super Turbo's on my 69 Sat, TTI 2.5" are 25.5 from inlet tip to outlet tip. The muffler case is 20" long and uses an offset inlet/center outlet. The shorter mufflers will work if you add an extension to the inlet.
