Re: What parts would U like to see repro'd that are N/A yet
[Re: OLD318]
#1242278
06/08/12 03:35 PM
06/08/12 03:35 PM
OLD318
I'd like to add 2 other parts to this list... 68-70 B-Body with Factory A/C : 1) reproduce the water heater control valves (especially 1970) 2) reproduce the two ferrules that go on the copper drain tubes to retain the thick neoprene washers when the unit is mounted through the firewall...
[Re: OLD318]
#1242279
06/15/12 06:35 PM
06/15/12 06:35 PM
OLD318
1 more part for a 70 Coronet: The plastic(metal?) drains for a 70 SuperBee Bulge Hood. The hood with the scoops in the middle not on the sides (Ram Air)..
[Re: OLD318]
#1242280
06/15/12 07:27 PM
06/15/12 07:27 PM
Posts: 6,101 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
E-body stuff:
- rear interior 'vert panels (c'mon Metro!)
- Gran Coupe interior wood door panel trim
- convertible quarter panels (wouldn't take much for dies to be modified)
- power window harnesses
- AM/FM thumbwheel radios with modern innards
- BF Goodrich space saver spares
- Shaker base plates for single four-barrel cars with 5 1/8" size opening.
[Re: SattyNoCar]
#1242282
06/16/12 01:02 PM
06/16/12 01:02 PM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
68 Barracuda grille surrounds, parking lights and truck trim.
[Re: ScottSmith_Harms]
#1242286
06/18/12 09:25 PM
06/18/12 09:25 PM
OLD318
66/67 B-body Plymouth & Dodge full quarter panels
Isn't AMD going to build those?
[Re: Al_Alguire]
#1242287
06/18/12 10:33 PM
06/18/12 10:33 PM
Posts: 27,558 So Cal
autoxcuda
So Cal
PG Classics lists that headlight buckets are sceduled for some time now.
Parking light lenses and chrome surrounds have been availible for some time now. So that's not an issue on availibility.
Trunk trim I believe is still availible from Laysons? I think it's in Stainless though. And IIRC, they have the same piece for upper and lower even though the contours are slightly different.
