Welding a back brace on a 8 ¾, advice please?? #1239642
05/25/12 01:50 PM
05/25/12 01:50 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I’m about to try welding a back brace on my 8 ¾ and I need some advice. I’ve done some reading, and most folks agree that the right way to do it is to use a jig to keep it from warping the housing. Well….I’m a backyard mechanic, so I don’t have a jig…but this was my thought.
What if I tack weld a piece of angle iron on the opposite side of the housing from the back brace, and leave my axles and spool installed…would this be enough to keep the housing fairly strait if I space my welds (to not build too much heat) and work my way slowly around welding the brace?
Also, dose the brace need to be fully welded all the way around?
Any and all advice is appreciated,
Thanks in advance
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Welding a back brace on a 8 ¾, advice please?? [Re: FlyFish] #1239643
05/25/12 01:57 PM
05/25/12 01:57 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
You could stitch weld it. 1-1/2 in on one side, the go to the other side. If the gears and axles are out, you could use an air compressor and blow air through it to keep it from getting too hot.
Yeah, it's got a smallblock.
Re: Welding a back brace on a 8 ¾, advice please?? [Re: 340B5] #1239644
05/25/12 02:16 PM
05/25/12 02:16 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You could stitch weld it...
x2 - That's how mine was done by a friend and it turned out OK.
Re: Welding a back brace on a 8 ¾, advice please?? [Re: FlyFish] #1239645
05/25/12 02:34 PM
05/25/12 02:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All I do is stitch weld... no more than 1" at a point
and jump all around so 1 area is cooling while your
in another area... take a couple of long straight edges
and clamp them on the flanges to measure between to
make sure the ends stay square
Re: Welding a back brace on a 8 ¾, advice please?? [Re: MR_P_BODY] #1239646
05/25/12 02:56 PM
05/25/12 02:56 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
So, with stitch welding, are you talking like...weld an inch...move down 6 inches...weld another inch...etc? Also, how long do I need to let it cool before coming back to an area...like 10 minutes?
Re: Welding a back brace on a 8 ¾, advice please?? [Re: FlyFish] #1239647
05/25/12 04:10 PM
05/25/12 04:10 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Make sure that your ground path does not pass through the bearings when you weld. In other words don't hook your ground clamp to anything other than the housing or a bracket already welded to the housing
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Welding a back brace on a 8 ¾, advice please?? [Re: FlyFish] #1239648
05/25/12 05:49 PM
05/25/12 05:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I jump side to side... let it cool till you can put your
hand on it
Re: Welding a back brace on a 8 ¾, advice please?? [Re: MR_P_BODY] #1239649
05/25/12 05:59 PM
05/25/12 05:59 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Do it like you torque a head, start in the center and move slow outwards.
Like they said and inch at a time, shift sides and let it cool.
Easy but it takes time, and it's worth it
Good luck
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Welding a back brace on a 8 ¾, advice please?? [Re: FlyFish] #1239650
05/26/12 01:21 PM
05/26/12 01:21 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
The problem you have is all of the welding is being done to one side of the tubes. It's not the heat that causes the warpage. It's when the weld cools, it shrinks, pulling the metal. Hense the reason to use a jig to pull the tubes in the opposite direction.
The correct way to back brace a housing is to mount it to a jig to preload (pull) the tubes towards the mtg. face of the housing. About 3/16" is good. Ideally, you would want to weld the backbrace on then cut and reweld the bearing flanges to make sure they are on center after all the welding, using an axle jig (centerless ground shaft and sleeves that go thru the carrier, in the diff bearing bores and sleeves that go in the housing end bores).
Just because you're a backyard mechanic doesn't doesn't mean you can't doing things right. Take your chances and what ever happens, happens.
Here's a pic of my back brace jig I made when I back braced my Ford 9" housing, for my Road Runner.
Re: Welding a back brace on a 8 ¾, advice please?? [Re: STEFF] #1239651
05/26/12 02:24 PM
05/26/12 02:24 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
^^^^^^^ i like it!
Re: Welding a back brace on a 8 ¾, advice please?? [Re: STEFF] #1239652
05/26/12 04:29 PM
05/26/12 04:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You have touched on many valid seldom mentioned points, but, using a jig to try and restrict warpage seldom works, and when it does, the finished item has many and huge welded in place streeses, making an item ready to fail before any racing loads are added, not good. Short of heat stress relieving after welding, which will surely result in warpage, best option imo is good design, no welded gaps (tight fit), go slow, skip around when welding, use a jig to "check" for straightness, and add housing ends on last.
Re: Welding a back brace on a 8 ¾, advice please?? [Re: STEFF] #1239653
05/26/12 05:07 PM
05/26/12 05:07 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Very nice setup ....unfortunatly, I've been doing most of my work at night (or at least that is what I would like to blame this on) and after removing the perches and grinding things smooth I realized that the housing is indeed bent. I have no clue how I missed this the first 2 days of working on this thing .
Does anyone know if a MO875 housing with a back brace will clear a stock gas tank on a Barracuda? I think that is the route I'm heading....looks like no racing for me this Memorial day weekend.
Re: Welding a back brace on a 8 ¾, advice please?? [Re: jcc] #1239654
05/27/12 03:26 AM
05/27/12 03:26 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I just recently did a rear for someone, before I did anything I checked the housing and it was off by 3/16 and this rear was in a driving car. So this just goes to show that just cause the rear works doesn't mean its right. I cut the ends off, do your welding all at once, straighten the tubes after you're done and weld the ends back on with an alignment bar and bearing pucks. This will net you a straight rear and take the least amount of time. Any other method you use will get you close but you are just guessing if it's straight. Like I said just cause it works doesn't mean it's right.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Welding a back brace on a 8 ¾, advice please?? [Re: DemonDust] #1239655
05/27/12 10:02 AM
05/27/12 10:02 AM
Bad Axe,MI
E
EDDIEB Offline
EDDIEB  Offline
E
Bad Axe,MI
How much does it cost to have a 8 3/4 back braced?
THANKS EDDIE B
Re: Welding a back brace on a 8 ¾, advice please?? [Re: EDDIEB] #1239656
05/27/12 10:08 AM
05/27/12 10:08 AM
tboomer Offline
tboomer  Offline
How far are ya from mr.peabody? Raff is a good egg and knows his stuff!!
Re: Welding a back brace on a 8 ¾, advice please?? [Re: EDDIEB] #1239657
05/27/12 10:15 AM
05/27/12 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
THANKS EDDIE B
I get between $200-$225
Re: Welding a back brace on a 8 ¾, advice please?? [Re: MR_P_BODY] #1239658
05/27/12 10:36 AM
05/27/12 10:36 AM
STEFF Offline
STEFF  Offline
THANKS EDDIE B
I'll beat that price......Just kidding Raff. LOL!!
Re: Welding a back brace on a 8 ¾, advice please?? [Re: STEFF] #1239659
05/27/12 10:51 AM
05/27/12 10:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
THANKS EDDIE B
Thats cutting the end flanges off (IF NEEDED) to true
the housing... using a 1.250 hardened truing bar
