Re: So far no more fuel problems.
[Re: 383man]
#1238747
05/24/12 05:50 AM
05/24/12 05:50 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: 383man]
#1238748
05/24/12 06:53 AM
05/24/12 06:53 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Ron, Glad to hear so far so good on the issue. I just ran a 454 with dual Eddy carbs on my test stand and was seeing some issues that I could only relate to heat soak to the carbs. It would also run on during shut down if I let it go to 210 degrees but would shut down fine if it was 200 degrees or lower on the temp gauge. I think two short spacers under the carbs might cure it in this issue.
I can't remember what you said in previous posts, but did you see any effect when you put the cool can in with no other changes?
The fuel that we have been all used to from years ago is long gone and making us think twice on how we plan a fuel system for the street. and like everything else, some get away with more than others, which I can only think of altitude and quality of gas in those particular areas.
Outcast Dodge guy.
[Re: 383man]
#1238749
05/24/12 07:08 AM
05/24/12 07:08 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Ron, get rid of that horrible plastic fuel filter and put a decent flowing/filtering one on there good to hear it's ok now
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1238751
05/24/12 09:15 AM
05/24/12 09:15 AM
Posts: 1,628 anywhere@ anytime
actionange
anywhere@ anytime
Tex
And did you ever see what happens if the plastic filter melts and fuel goes onto HOT headers...
[Re: actionange]
#1238752
05/24/12 09:37 AM
05/24/12 09:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Tex
Plus the plastic filter isnt NHRA approved ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 383man]
#1238754
05/24/12 12:12 PM
05/24/12 12:12 PM
383man
Balt. Md
Here is the metal fuel filter I have been using. I just tried putting the plastic one on first to see if it helped since the metal fuel filter seemed to get pretty hot and I thought it may be holding alot of heat in it. I just tried this plastic one to see if the fuel stayed cooler since the metal filter stayed pretty hot. But I am changing it back to a metal one. I am curious if any one runs no filter before the fuel pump and just one after the pump and how it has worked out for you. Thanks for the kind replies. Ron ![](http://i338.photobucket.com/albums/n429/383-manallmopar/100_1559.jpg)
[Re: topside]
#1238756
05/24/12 04:00 PM
05/24/12 04:00 PM
383man
Balt. Md
Na its not busting my stones. ![](/ubbthreads/images/graemlins/biggrin.gif) I can honestly say that in the early 70's when I started in this hobby and even up to now I never really seemed to have enough money to build what I wanted to (being married with kids) and most of my years I build mild low budget builds. And back then no one used AN fittings on all the fuel system lines and mine were usually stock or very close. Now over the years all my buddies run the high dollar AN fittings on everything and they tell me I am stuck in the 70's when I dont use all the new high dollar stuff. A dinasour ?? Who me ? ![](/ubbthreads/images/graemlins/biggrin.gif) But honestly with a 6 lb system I have never had a problem using good clamps on good fuel line and never any leaks. I have not had any track officials say anything about the braided fuel line with clamps either. But I have not updated alot of things I still use like the MP orange ECU that still works fine for me. Even though all my friends have to run MSD or something like it. Yea I guess I am still old school on alot of things but if it still works for me it takes me a long time to change. And most of the old school is cheaper. So as long as it is still safe I stick with some of it on my budget. But dont get me wrong as I appeciate anyone's input. One day when the cash is flowing good I will most likely update to all braided line with the AN fittings. I have been waiting a long time though for the day the cash is flowing well. ![](/ubbthreads/images/graemlins/devil.gif) Ron
[Re: 383man]
#1238759
05/24/12 07:04 PM
05/24/12 07:04 PM
tex013
Sydney,Australia
Ron, i just run an Earls prefilter,80-100 micron,fitted to the fuel pump inlet.no after filter.i run pump gas no worries. i did do some flow tests on Greg's A12 a while back from one of those parts store filters to a system 1 filter,inline with barbs -6,i think there was like 1/2 to 1 litre flow difference per 30 seconds thankfully we seem to have better fuel than you guys to use Tex
[Re: lewtot184]
#1238762
05/24/12 10:19 PM
05/24/12 10:19 PM
MR_P_BODY
i was having some driving issues with pump gas last week. put some insulator gaskets under the carbs and went back to using the return line. big difference in driving. i believe a "regulated" return back to the tank is a big plus for street use.
I'm doing the fuel and brake lines on my rampage right now ... I'm running -8 supply and -8 return with a Mallory reg... with a Holley black 150 pump.. the -8 lines are the black braided lines instead of the SS braided ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 383man]
#1238764
05/25/12 12:38 AM
05/25/12 12:38 AM
MR_P_BODY
I picked up a used return reg from a member on here. I am using a stock fuel tank so I have to figure out a setup to go with the return line reg as I want to stay with my stock fuel tank. Ron
I assume you have a 3/8 line in the sending unit.. you can solder a return on it ![](/ubbthreads/images/graemlins/wave.gif)
