Hemi Piston clerance #1238633
05/24/12 12:12 AM
05/24/12 12:12 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
If you have hemi build experience I have a question. Is .100 to much clerance for piston to head clearance on the squeeze side of the piston dome? thanks rob
Re: Hemi Piston clerance [Re: robnbird] #1238634
05/24/12 01:04 AM
05/24/12 01:04 AM
It depends on how much compression you want and where the clearances are, intake valve side, exhaust valve side or the front or rear sides of the pistons I'm not sure what you mean by the squeeeze side of the dome
Re: Hemi Piston clerance [Re: Cab_Burge] #1238635
05/24/12 10:05 AM
05/24/12 10:05 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
No, run it
2011 Drag Pak Challenger
Re: Hemi Piston clerance [Re: Cab_Burge] #1238636
05/24/12 12:27 PM
05/24/12 12:27 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks cab . you the man
Re: Hemi Piston clerance [Re: rickseeman] #1238637
05/24/12 12:42 PM
05/24/12 12:42 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
No, run it
thats what im going to do Rick and thanks
Re: Hemi Piston clerance [Re: robnbird] #1238638
05/24/12 01:59 PM
05/24/12 01:59 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Minimum is about .045, between .045 and .100 is pretty much undesirable, not tight enough to push the mixture out of the Quench area, not enough to ignite it without the push, .100 or more should work fine.
Be a Rebel- Break the Laws of Physics!
