Page 2 of 5 1 2 3 4 5
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237624
05/22/12 02:04 PM
05/22/12 02:04 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
Had a minute to run to O'Reilley's to pick up a new set of feeler gauges and run back home.. checked the gap, I was able to easily get the .016 gauge in there, .020 fit, but it was tight.
Yeah, I'd say the gap is too big. I'll be adjusting it tonight.. gotta run to work now.
Re: help me ID the inside of this distributor... [Re: OzHemi] #1237625
05/22/12 02:29 PM
05/22/12 02:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Notice the old pickup in my newer MP distributer, the one's that came in it was crap. It ohmed diffrently than other pickups I had on hand and have been using a used pickup because the MP pickup would break up and misfire with any kind of load no matter what the gap was, happen to me on 3 MP distributers.
Re: help me ID the inside of this distributor... [Re: Challenger 1] #1237626
05/22/12 05:06 PM
05/22/12 05:06 PM
Sacramento, CA
Sacramento, CA
I am really hoping that this may be part of my problems with the rough idle, timing mark jumping around when shining the timing light on it, etc... can't wait to get home tonight and adjust it and see what happens.
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237627
05/22/12 06:44 PM
05/22/12 06:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: help me ID the inside of this distributor... [Re: Challenger 1] #1237628
05/22/12 10:58 PM
05/22/12 10:58 PM
Sacramento, CA
Sacramento, CA
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237629
05/22/12 11:28 PM
05/22/12 11:28 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: help me ID the inside of this distributor... [Re: OzHemi] #1237630
05/23/12 02:07 AM
05/23/12 02:07 AM
Sacramento, CA
Sacramento, CA
Well, I adjusted the air gap between the reluctor and pickup.. tightened up the gap to where it should be ... started it up.. no noticeable difference .. I tried adjusting the idle mixture screws, didn't see any improvement.
I turned off all the lights in the garage, and looked for any arcing, didn't see any .. was hoping something might be obvious.
I swapped out all the plugs with brand new plugs (same kind, the Autolite AL65's, gapped to .040).. this seemed to help.. I was able to reduce the idle speed down to where it was ROUGHLY idle around 600 rpm and stay there... but it was bucking around in the engine bay like a PO'd bull, and the vacuum dropped to about 5 ... also noticed some smoke coming out the breather on the valve cover.. is that because I had the PCV disconnected and plugged?
The exhaust was really pungent too...
10pm came around quickly (I didn't get home from work until 8pm, and then had dinner), so that's about where I wrapped up. The VERY interesting thing, is that according to my dial-back timing light, the best idle I was able to get was with about 25 degrees of initial timing.
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237631
05/23/12 03:16 AM
05/23/12 03:16 AM
Sacramento, CA
Sacramento, CA
forgot to mention.. still seeing the same erratic behavior on the timing mark on the harmonic balancer... it jumps around every now and then.
I think I'll pick up a new cap and rotor tomorrow just for S&G's.
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237632
05/23/12 04:22 AM
05/23/12 04:22 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Well, I adjusted the air gap between the reluctor and pickup.. tightened up the gap to where it should be ... Set to .008, right?
I swapped out all the plugs with brand new plugs (same kind, the Autolite AL65's, gapped to .040) Using a factory distributor, the plug gap should be at .035. ... also noticed some smoke coming out the breather on the valve cover.. is that because I had the PCV disconnected and plugged?
All street engines need some sort of PCV system. Even zero mile engines produce blow-by. The PCV evacuates pressure from the crankcase AND creates a suction that PULLS the rings outward, helping ring seal. The smoke coming from the breather will occur unless you run a PCV system. It shouldn't be dismissed as "Smog crap" since it actually helps performance while making the engine run cleaner.
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237633
05/23/12 10:21 AM
05/23/12 10:21 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
What timing light are you using? Many dial back lights are confused by MSDs.
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237634
05/23/12 10:41 AM
05/23/12 10:41 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
for reference, here's a better shot of the top of the distributor.
I'll swing over to the auto parts store on my way in to work in a bit, and pick up some brass feeler gauges. I'm guessing my steel ones won't work accurately with the magnet
I don't think that is a stock pickup. The factory ones are a black molded plastic, yours apprears to be shrink wrapped or electrical tape. Maybe it is an early Pertronix? Also the white wires are not what you would see on an original or aftermarket. I'd be tempted to install a stock one in there and see how it acts. My buddy went through 2 Pertronix before getting a good one the third time.
Re: help me ID the inside of this distributor... [Re: Dave Watt] #1237635
05/23/12 11:22 AM
05/23/12 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's not a factory pickup that is for sure and it's definitely not a pertronics as they don't use a reluctor wheel like that.
Mark as far as your idle 600 is TOO low , car is an automatic it's going to stall as soon as you put it in gear. set your idle speed to 900 .
As you noticed the timing dropped but the one thing you have to remember is the MSD fires multiple times on each fire of a cylinder below 3000 rpms and as mention some timing lights don't like that .
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237636
05/23/12 12:19 PM
05/23/12 12:19 PM
Sacramento, CA
Sacramento, CA
OK.. so one issue resolved - as it turns out, I had the timing light pick-up backwards on the plug wire... I turned it around, and the timing mark isn't bouncing any more... hallelujah for one issue being resolved.
I adjusted the idle some more this morning... here's a video of it idling right at 1000 rpm, along with vacuum gauge readings.
http://www.youtube.com/watch?v=8PJFZTCcdfo
It's still not idling as smooth as I would expect, especially based on some other videos I've seen posted of 360's with this same cam. Also, I'm not understanding how/why it will idle the BEST with 30 degrees advance
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237637
05/23/12 01:00 PM
05/23/12 01:00 PM
Sacramento, CA
Sacramento, CA
Frankenduster - thanks.. I thought the plug gap was supposed to be .035, but I had read on another thread somewhere on Moparts (in all my Google searches for ignition problems I've been doing) to set it at .040 ... I still need to re-do my compression test.. so when I pull the plugs out for that, I can re-gap the new plugs.
I do remember reading that this cam (Comp Cam XE268H) will have a more noticeably rough idle in an engine with stock compression.. since this is a reman. engine, it does have stock compression - around 8.4:1 I think is what was stock.
Gonna swing in to NAPA today and get a cap/rotor for the distributor.. .just part of the process of throwing money at it, hoping to make a difference
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237638
05/23/12 01:21 PM
05/23/12 01:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to bring the RPM up and see what the timing is doing! If it keeps advancing you are going to have a huge problem when it tries to run with almost 60 degrees advance , nevermind when the vacuum can starts adding more ...
heres something dumb I didn't ask , can you see the springs on the advance weights when you look down inside the distributor ?
Re: help me ID the inside of this distributor... [Re: RobX4406] #1237639
05/23/12 01:23 PM
05/23/12 01:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
plus get that timing dialed back once you get the gap set.
WRONG!!!
Fix/weld the mechanical advance plate so the engine can have the proper initial.
Carry on
No , not really.
That is something he could/should eventually do but for right now to figure out what is going on he needs to keep it no higher than 5-8 .
Re: help me ID the inside of this distributor... [Re: cal_gecko] #1237640
05/23/12 01:26 PM
05/23/12 01:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Do you have a vacuum gauge?
If so, stick it on the engine. Get your idle up to 900 rpm as suggested. Diddle with your timing until you have the highest vacuum signal. It needs to be as steady as possible despite the rough idling cam.
Once that is set, turn your idle mixture screws in until the rpm begine to drop. Then turn them out until you have the highest steady vacuum signal.
If you still have issues other than a lumpy cam idle let us know.
- Stu Harmon
Re: help me ID the inside of this distributor... [Re: feets] #1237641
05/23/12 01:29 PM
05/23/12 01:29 PM
Sacramento, CA
Sacramento, CA
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237642
05/23/12 01:35 PM
05/23/12 01:35 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
WRONG!!!
Carry on
No , not really.
How much total it has right now don't mean jack shyat...
He needs to get his idle issue sorted out and TOTAL plays absolutely no part in that area of the equation. Time that car at 5-8* initial and it will run worse than he could ever imagine.
Re: help me ID the inside of this distributor... [Re: JohnRR] #1237643
05/23/12 01:35 PM
05/23/12 01:35 PM
Sacramento, CA
Sacramento, CA
When I bring the RPM's up, it does increase the total timing, I believe it went up to around 42 or so...
I didn't see the springs.. this was the view...
