Rotating torque #1236362
05/20/12 12:13 PM
05/20/12 12:13 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
What is a good rotating torque for a 4.080 x 3.580 shortblock w/ std tension 1/16 ,1/16,3mm rings. I just did mine and I think I'm doing pretty good.
Yeah, it's got a smallblock.
Re: Rotating torque [Re: 340B5] #1236363
05/20/12 01:15 PM
05/20/12 01:15 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
3mm STD tension oil ring?
I'll guess, 22 ft/lb, continuous.
Re: Rotating torque [Re: S/ST 3040] #1236364
05/20/12 02:08 PM
05/20/12 02:08 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Anyone ever had a motor stutter when turning over slow by hand has got to be rings causing it, crank turned over smooth as silk... .0025main clearance.....rings have already been broken in.....these are hellfires on a 4.030 bore with .032/.035 gap.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Rotating torque [Re: S/ST 3040] #1236365
05/20/12 02:41 PM
05/20/12 02:41 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Yeah, std tension oil ring, or at least that's what I ordered. I should have stated "break away" torque. Anyway w/ oiled up cyls. the breakaway is 16.5-17 ft lbs w/ no cam installed.
I've got to give the machinist credit for a job well done.
EDIT; Verified they are std tension.
