larger dist cap on Accel dual point?? #1235528
05/18/12 05:56 PM
05/18/12 05:56 PM
Kent, WA
triple_green Offline OP
Kent, WA
using an aftermarket dualpoint with the 69 hemi. It is an Accel, it was with the motor when I got it. The Distributor cap is larger than what I can find for dual points caps at parts store. I cannot see a part number of the cap. Any idea of where I can get one of these?
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: larger dist cap on Accel dual point?? [Re: triple_green] #1235529
05/18/12 06:16 PM
05/18/12 06:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The accel dual point does not use a stock chrysler cap ... but you already new that .
Check with Joesixpack/Bill Cowger , he might have one .
Re: larger dist cap on Accel dual point?? [Re: JohnRR] #1235530
05/18/12 09:28 PM
05/18/12 09:28 PM
scratchnfotraction Offline
I have a old mallory duel point dist with the flat 2-piece cap,I got a change over cap with female terms for it.
Napa looked it right up in the books and had it on the shelf. in another town though.
I have orderd accell tune up stuff from them also,may give them a shot if they have a good counter clerk and not a counter jerk.
Re: larger dist cap on Accel dual point?? [Re: scratchnfotraction] #1235531
05/19/12 10:43 AM
05/19/12 10:43 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
My 69 GTX had an Accel 30300 dual point when I got it, MP electronic now. Local parts store found the Accel parts in 1996:
Points 110128 (two required)
Rotor 130116
Cap 120123
Condensor 100107
Re: larger dist cap on Accel dual point?? [Re: 63stabamatic] #1235532
05/21/12 07:09 PM
05/21/12 07:09 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Accel dual point distributors used a 1955-1956 Chevrolet V8 distributor cap.....get one with brass/copper inserts,do not use aluminum(silver)contacts.I have black,red and tan ones in stock.
Re: larger dist cap on Accel dual point?? [Re: Joesixpack] #1235533
05/21/12 08:01 PM
05/21/12 08:01 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
top
