drum brake pad upgrades-who sells? Recommendations? #1234443
05/16/12 02:39 PM
05/16/12 02:39 PM
Kent, WA
triple_green Offline OP
Kent, WA
68 charger..is it worth upgrading the brake pads? what have you had success with? Don't want to go to disks right now.
Thanks!
68 Charger, 383 HP console auto, spring green, stock restoration
Re: drum brake pad upgrades-who sells? Recommendations? [Re: triple_green] #1234444
05/16/12 03:33 PM
05/16/12 03:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I get mine at NAPA or Carquest.
Drums have shoes and disc have pads.
Re: drum brake pad upgrades-who sells? Recommendations? [Re: MoparforLife] #1234445
05/16/12 04:56 PM
05/16/12 04:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
really depends on you. you can get some good shoes for drums. only downside i've found is they will want a power assist and don't work real good cold. i have a set of 11" carbon metallics that love heat and will stop as good anything i've owned, including discs. i think to get a real good disc set-up you'll need 12" or larger calipers with a power assist. i use 15" wheels so that puts a limit in size for what i do. i have an a-body disc conversion on my 65 coronet and as far as i'm concerned it isn't worth two dead flies!
Re: drum brake pad upgrades-who sells? Recommendations? [Re: lewtot184] #1234446
05/16/12 04:59 PM
05/16/12 04:59 PM
Kent, WA
Kent, WA
sorry I am asking about alternate material brake shoes. I think the carbon metallics is what I was looking for.
Mark
Re: drum brake pad upgrades-who sells? Recommendations? [Re: triple_green] #1234447
05/16/12 05:08 PM
05/16/12 05:08 PM
Kent, WA
Kent, WA
how bad are the carbon metallics when cold? Are we talking about first driving cold or cold weather cold? Also can you just put CM shoes on the front?
thanks!
Re: drum brake pad upgrades-who sells? Recommendations? [Re: triple_green] #1234448
05/16/12 05:19 PM
05/16/12 05:19 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
