Brake bias, caliper BORE size and PAD recomendations...
#1233067
05/14/12 02:11 AM
05/14/12 02:11 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Today my brother in law and I finished swapping a 904 into his Duster that was a 4 speed. On the spirited test drive, we ended up "testing" the brakes as well. Years back I swapped in a front disc setup from an 88 5th Avenue. The rear brakes are 10 inch drums. The brakes on this car would rival any new car. Non power master cylinder, but the pedal feel is great and this sucker just stops as if I threw out a grappling hook. What the heck? The brakes in the Charger have been a pisser. In February I added frame connectors and torque boxes. I had to reroute the front to rear brake line. The brakes were bled afterward, but they have given me trouble ever since. Since 2006, the system was: 12" Cordoba rotors, 75 Dart calipers in the front and the 10.7" rear disc brake kit from Dr Diff. I also used a power booster with a master cylinder from a 75 Dart. Braking was excellent except at low speeds since the idle vacuum was so low. I thought that switching to a NON power master cylinder would result in improved braking. It IS a little better, but after driving the BILs Duster, I have MUCH room for improvement. I've read in Mopar Action that the slider calipers have a tendency to allow the pads steel core to DIG into the sliding mechanism, causing the braking action to be radically compromised. I'm pulling the wheels tomorrow to get a look, but the point of this post is.... What relationship does the caliper bore size have to do with brake effectiveness? This Duster flat out STOPS better than any other A body that I've ever driven. It beats the Charger by a long shot. Its probably better that my 2007 Ram, and I've always been impressed with the truck. The only difference on the Duster is the calipers. I thought that I heard that the calipers on the 76 A bodies as well as the FMJ cars had different sized pistons. Does anyone know the specs on the different single piston calipers? I am tempted to swap in a pair of these later calipers if there are gains to be had. I really need the Charger to have brakes that equal the engine! Thanks, Greg.
Re: Brake bias and caliper BORE size.
[Re: Kern Dog]
#1233070
05/14/12 04:34 AM
05/14/12 04:34 AM
Kern Dog
Granite Bay CA
Whenever I have doubts about interchange, I go to www.RockAuto.com. That site is great. I just look for part numbers that match and it really clears things up. Their site shows that the 73-75 A body cars used front calipers with 2.6" pistons. The 76 A body and ALL FMJ cars used calipers with 2.75" pistons. The Raybestos line showed those specs. Since the calipers and hoses can physically interchange, I'm inclined to just go ahead and get a pair of the 2.75 bore calipers.
[Re: Kern Dog]
#1233071
05/14/12 07:54 AM
05/14/12 07:54 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
well, a larger piston in the caliper gives you more clamping force for the same size master cylinder, so long as your master cylinder has enough stroke volume to operate the pistons without bottoming out.
I just put big brakes on my dakota, went from 10" drum brakes in the rear to 4-piston Brembo calipers on a 13" rotor. on the stock master cylinder, my pedal would go to the floor without generating any real braking effort, and I had to step up to a larger diameter master to get enough stroke volume for the big rear brakes.
I think I read on one of Andy's posts that it's not about pad size, but rather, it's all about caliper clamping force. the size of the pad only determines how fast the pad wears.
**Photobucket sucks**
[Re: Kern Dog]
#1233074
05/15/12 09:27 AM
05/15/12 09:27 AM
70Cuda383
Marysville, O-H-I-O
I always thought you wanted 1000-1200 psi at the caliper for a disc brake system. as far as front/rear bias, if you can't get it dialed in perfectly with just piston sizes, I would err on the side of caution, and go bigger on the rear, then use an adjustable proportioning valve to dial it back so they lock up evenly. you NEVER want to put any kind of prop valve or pressure limiting valve on the fronts!
Also, car suspension can greatly effect brake bias. if you have a soft or worn out suspension, all your weight will shift forward, the nose will dive down, and the rear end will get very light. this will cause the rear to lock up before the fronts as well, even if the brake system is evenly matched.
[Re: 70Cuda383]
#1233075
05/15/12 10:03 AM
05/15/12 10:03 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No too sure your disc/drum master cylinder is the best choice for an all disc system. Lack of volume for the rear calipers.
Also, if you flipped the spindles for sway bar clearance make triply sure the bleeder valve is at the high point of the caliper bore, otherwise you will trap some air and you will have lousy brakes.
[Re: 70Cuda383]
#1233077
05/15/12 10:21 AM
05/15/12 10:21 AM
Supercuda
About to go away
About to go away
up yours
went baack an reread this thread, only mc he mentioned is from a 75 Dart, dunno what he has in it for sure
Re: Brake bias and caliper BORE size. *DELETED*
[Re: Kern Dog]
#1233079
05/15/12 11:21 AM
05/15/12 11:21 AM
Posts: 416 Franklin Co. Illinois
runinonmt
Post deleted by runinonmt
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Kern Dog]
#1233082
05/15/12 03:31 PM
05/15/12 03:31 PM
Supercuda
About to go away
About to go away
up yours
The power brake m/c for a 75 Dart looks to be 15/16".
the manual one is 1 1/32".
Either your new m/c is flaky or you need to upsize it.
[Re: Supercuda]
#1233084
05/15/12 06:48 PM
05/15/12 06:48 PM
Kern Dog
Granite Bay CA
I bought the aluminum master cylinder from Dr Diff. He has the best rep in the business, so I trust his judgement. Regarding the bore diameter of the stock stuff, it appears to me that you may have your spec's backwards. Wouldn't it make more sense for the power applications to use a LARGER bore since they have assistance to push it? Just an idea. I haven't measured the iron power M/C yet.
[Re: Kern Dog]
#1233085
05/15/12 06:50 PM
05/15/12 06:50 PM
Supercuda
About to go away
About to go away
up yours
I looked them up at Rock Auto, assuming they had it right I simply posted what they spec'd.
