Brake bias, caliper BORE size and PAD recomendations...
#1233067
05/14/12 02:11 AM
05/14/12 02:11 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Today my brother in law and I finished swapping a 904 into his Duster that was a 4 speed. On the spirited test drive, we ended up "testing" the brakes as well. Years back I swapped in a front disc setup from an 88 5th Avenue. The rear brakes are 10 inch drums. The brakes on this car would rival any new car. Non power master cylinder, but the pedal feel is great and this sucker just stops as if I threw out a grappling hook. What the heck? The brakes in the Charger have been a pisser. In February I added frame connectors and torque boxes. I had to reroute the front to rear brake line. The brakes were bled afterward, but they have given me trouble ever since. Since 2006, the system was: 12" Cordoba rotors, 75 Dart calipers in the front and the 10.7" rear disc brake kit from Dr Diff. I also used a power booster with a master cylinder from a 75 Dart. Braking was excellent except at low speeds since the idle vacuum was so low. I thought that switching to a NON power master cylinder would result in improved braking. It IS a little better, but after driving the BILs Duster, I have MUCH room for improvement. I've read in Mopar Action that the slider calipers have a tendency to allow the pads steel core to DIG into the sliding mechanism, causing the braking action to be radically compromised. I'm pulling the wheels tomorrow to get a look, but the point of this post is.... What relationship does the caliper bore size have to do with brake effectiveness? This Duster flat out STOPS better than any other A body that I've ever driven. It beats the Charger by a long shot. Its probably better that my 2007 Ram, and I've always been impressed with the truck. The only difference on the Duster is the calipers. I thought that I heard that the calipers on the 76 A bodies as well as the FMJ cars had different sized pistons. Does anyone know the specs on the different single piston calipers? I am tempted to swap in a pair of these later calipers if there are gains to be had. I really need the Charger to have brakes that equal the engine! Thanks, Greg.
Re: Brake bias and caliper BORE size.
[Re: Kern Dog]
#1233070
05/14/12 04:34 AM
05/14/12 04:34 AM
Kern Dog
Granite Bay CA
Whenever I have doubts about interchange, I go to www.RockAuto.com. That site is great. I just look for part numbers that match and it really clears things up. Their site shows that the 73-75 A body cars used front calipers with 2.6" pistons. The 76 A body and ALL FMJ cars used calipers with 2.75" pistons. The Raybestos line showed those specs. Since the calipers and hoses can physically interchange, I'm inclined to just go ahead and get a pair of the 2.75 bore calipers.
[Re: Kern Dog]
#1233071
05/14/12 07:54 AM
05/14/12 07:54 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
well, a larger piston in the caliper gives you more clamping force for the same size master cylinder, so long as your master cylinder has enough stroke volume to operate the pistons without bottoming out.
I just put big brakes on my dakota, went from 10" drum brakes in the rear to 4-piston Brembo calipers on a 13" rotor. on the stock master cylinder, my pedal would go to the floor without generating any real braking effort, and I had to step up to a larger diameter master to get enough stroke volume for the big rear brakes.
I think I read on one of Andy's posts that it's not about pad size, but rather, it's all about caliper clamping force. the size of the pad only determines how fast the pad wears.
**Photobucket sucks**
[Re: Kern Dog]
#1233074
05/15/12 09:27 AM
05/15/12 09:27 AM
70Cuda383
Marysville, O-H-I-O
I always thought you wanted 1000-1200 psi at the caliper for a disc brake system. as far as front/rear bias, if you can't get it dialed in perfectly with just piston sizes, I would err on the side of caution, and go bigger on the rear, then use an adjustable proportioning valve to dial it back so they lock up evenly. you NEVER want to put any kind of prop valve or pressure limiting valve on the fronts!
Also, car suspension can greatly effect brake bias. if you have a soft or worn out suspension, all your weight will shift forward, the nose will dive down, and the rear end will get very light. this will cause the rear to lock up before the fronts as well, even if the brake system is evenly matched.
[Re: 70Cuda383]
#1233075
05/15/12 10:03 AM
05/15/12 10:03 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No too sure your disc/drum master cylinder is the best choice for an all disc system. Lack of volume for the rear calipers.
Also, if you flipped the spindles for sway bar clearance make triply sure the bleeder valve is at the high point of the caliper bore, otherwise you will trap some air and you will have lousy brakes.
[Re: 70Cuda383]
#1233077
05/15/12 10:21 AM
05/15/12 10:21 AM
Supercuda
About to go away
About to go away
up yours
went baack an reread this thread, only mc he mentioned is from a 75 Dart, dunno what he has in it for sure
Re: Brake bias and caliper BORE size. *DELETED*
[Re: Kern Dog]
#1233079
05/15/12 11:21 AM
05/15/12 11:21 AM
Posts: 416 Franklin Co. Illinois
runinonmt
Post deleted by runinonmt
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Kern Dog]
#1233082
05/15/12 03:31 PM
05/15/12 03:31 PM
Supercuda
About to go away
About to go away
up yours
The power brake m/c for a 75 Dart looks to be 15/16".
the manual one is 1 1/32".
Either your new m/c is flaky or you need to upsize it.
[Re: Supercuda]
#1233084
05/15/12 06:48 PM
05/15/12 06:48 PM
Kern Dog
Granite Bay CA
I bought the aluminum master cylinder from Dr Diff. He has the best rep in the business, so I trust his judgement. Regarding the bore diameter of the stock stuff, it appears to me that you may have your spec's backwards. Wouldn't it make more sense for the power applications to use a LARGER bore since they have assistance to push it? Just an idea. I haven't measured the iron power M/C yet.
[Re: Kern Dog]
#1233085
05/15/12 06:50 PM
05/15/12 06:50 PM
Supercuda
About to go away
About to go away
up yours
I looked them up at Rock Auto, assuming they had it right I simply posted what they spec'd.
[Re: Kern Dog]
#1233091
05/16/12 02:28 AM
05/16/12 02:28 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If you're running a power pedal with a manual master you're losing pressure. Either find a manual brake pedal or move the brake push rod higher on the pedal.
Measure from the center of the brake pedal pivot to the middle of the brake pedal pad. Measure from the center of the brake pedal pivot to the center of the pin where master cylinder push rod connects to the pedal.
It's needs to be a 5:1 ratio for factory sized master cylinders to work. If you have a power pedal the leverage is greatly reduced. A "correct" sized master cylinder will require a lot more leg effort to get the same brake pressure.
To calculate line pressure do the math. (input force * pedal ratio) / surface area of master cylinder piston
Here's a list of master cylinder sizes and line pressures using a 4:1 pedal ratio and a 150 lbs pedal force:
3/4" = 1364 psi 7/8" = 1000 psi 15/16" = 869 psi 1" = 759 psi 1-1/8" = 606 psi 1-1/4" = 488 psi
Now, using a 5:1 pedal ratio and 150 lbs pedal force you get: 3/4" = 1705 psi 7/8" = 1250 psi 15/16" = 1086 psi 1" = 949 psi 1-1/8" = 758 psi 1-1/4" = 610 psi
Does that help?
Your 15/16" master cylinder with a 4:1 ratio and pedal effort of 172 lbs gives you 1000 psi.
Assume you weigh 172 lbs. Stand on one leg. Do a deep knee bend. The amount of force needed to stand up straight again with one leg is how hard you have to push on the pedal to get the pressure listed above.
You want a minimum of 1000 psi working pressure.
To get 1200 psi for a comfortable margin you have to push with 207 lbs of force.
Either fix the pedal or find a 3/4" master cylinder and hope it has enough travel to make up for the pistons moving.
[Re: feets]
#1233092
05/16/12 04:08 AM
05/16/12 04:08 AM
Kern Dog
Granite Bay CA
Feets, I'm impressed and honored. That post took some effort and I thank you. This car started out with manual 4 wheel drums. I converted it to Power front disc/rear drum, then to Power 4 wheel disc. Now it is a non power 4 wheel disc. It has the same brake pedal that was in the car when I bought it. I'll have to check and calc the pedal ratio, then report back. I seem to remember that some cars had 2 holes in the brake pedal lever, the top one was supposed to be for manual brakes. I don't recall seeing any 67-76 A bodies that were like this and my Charger certainly isnt.
On another note I had the idea of eliminating the combination block, thinking that there may be a better way. I was thinking of running the M/C rearmost port to a TEE which will split off to each front wheel, then run the forewardmost M/C line to the rear with an adjustable proportioning valve in line. My thinking is that THIS may be a "work around" to a possibly defective combo valve. I posted this question elsewhere and a few suggested simply gutting the combo valve and keeping it. I took a drum/drum and a disc/drum combo valve and took the parts out. I blew compressed air through both and found that even with the guts removed, the front and rear ports remained seperate! The combo valve mods are moot if my pedal ratio is waaay off. Another thought: Since the car WAS 4 wheel drum, and since drums require LESS volume to operate, maybe the existing pedal ratio is simply not compatible with a 4 disc system.
[Re: feets]
#1233093
05/16/12 04:35 AM
05/16/12 04:35 AM
Kern Dog
Granite Bay CA
5:1 pedal ratio for manual brake cars. 4:1 pedal ratio for power brake cars.
I think that's right. If not, the info was worth what you paid for it.
Okay, I'm back. Using the instructions given, my pedal ratio is quite different. I measured from the center of the brake pedal pad to the center of the point at which it swings...12 3/8" The measurement from the pivot to the center of the brake pushrod bolt is 1 7/8". This works out to a 6.6 ratio. I had a mid 70s A body pedal assembly nearby and looked at it for comparison. I got 11 1/4" and 1 5/8" for a ratio of 6.92. I measured AND did the math twice. For the Charger, the brake pushrod would've needed to be 3 1/32" away to be at a 4 to 1 ratio or 2 1/2" away to be close to the 5 to 1 number. It was worth a try.
[Re: runinonmt]
#1233098
05/16/12 02:28 PM
05/16/12 02:28 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have 74 Dart front calipers,Dr Diff 15/16" MC,11" rear drums and a factory original to my car Drum/drum prop valve and my car stops as good as anything i've ever driven with no rear lockup. My pedal and rod are also orignal manual stuff. If you want I can measure my pedal ratio. It sounds to me like my setup is identical to yours other than the rear discs.
Mopar to the bone!!!
[Re: DoctorDiff]
#1233099
05/16/12 02:52 PM
05/16/12 02:52 PM
Kern Dog
Granite Bay CA
Only pre '66 B-bodies used a different pedal for power brakes.
I have a few 7/8" bore master cylinders, but that seems kind of extreme.
You probably don't need any rear proportioning with your particular disc/disc combination. Did you try a simple drum brake distribution valve?
Can you get more aggressive front brake pads?
I have tried 2 different combination valves, a 75 Dart disc/drum and a drum/drum. The drum/drum valve is in place now. Both delivered the same feel. I may have not mentioned it, but it sorta feels as if the front end isn't getting enough line pressure. On other factory based master cylinders, the outlet fittings are different sizes to ensure the proper front/rear placement. THIS 15/16" master has similar ports front and rear. I have the rearmost reservior connected to the front brakes like a factory application.
MORE aggressive front pads? That is an idea. I also have been asked if the current new pads have been bedded in yet. Simply put, if the braking im proved by 20%, they would still suck. It really is that bad. What are the chances of having TWO combo valves with internal blockages? I have considered plumbing the lines without a factory valve.
[Re: Supercuda]
#1233101
05/16/12 08:33 PM
05/16/12 08:33 PM
Kern Dog
Granite Bay CA
I owe you an apology! I just removed the M/C from the power booster that I previously had on the car. The bore WAS 15/16". To confirm, I pulled the M/C from a 73 Dart power disc car. It too was 15/16". I checked my NON power A body factory disc master and it looked like 1 1/16" but it could have been 1 1/32"... hard to tell when they are that close. This is odd. Maybe the increased pedal ratio of the manual setup overcomes the bigger bore?
[Re: Kern Dog]
#1233102
05/16/12 11:05 PM
05/16/12 11:05 PM
Supercuda
About to go away
About to go away
up yours
Well, I am just a piece of carp anyway, lol.
I am running manual brakes on my 65 Cuda, 11.75" disc/11" drums. Running the M/C out of a late M body, forget the diameter offhand, but the pedal is not as firm as I would like. I think it's a bleeder on the caliper location issue but haven't gotten around to verifying it yet.
I forget, it's been years, exactly what caliper I am running, I think M body and I flipped the calipers to clear the swaybar. This might have put the bleeders in less than optimal position causing my issue. Are you 100% sure the bleeders are at the very top of the caliper bore?
[Re: Supercuda]
#1233103
05/17/12 12:34 AM
05/17/12 12:34 AM
feets
Senior Management
Senior Management
Irving, TX
The hot rod has 8 piston calipers up front. The total working area is 4.40 square inches. The rear 4 piston calipers have a working area of 2.05 square inches. I use a 1-1/8" master cylinder on the stock manual brake pedal. I don't remember the pedal ratio.
This setup have the best feeling manual brakes I've ever driven. The pedal isn't hard to push and the car slows down as soon as the pedal moves. It's a beautiful thing. Despite soft 245/45-18 and 295/45-18 tires I can lock the brakes without excessive pedal pressure.
My situation is a little different with 14.25" front rotors and 13" rear rotors.
Your front calipers have a piston area of 5.94 square inches and the rears are 2.43 square inches. Both calipers displace more fluid than mine. Your rotors are 11.75" front and 10.7" rear.
I would have to sit down and calculate the difference in brake force between my setup and yours assuming we have the same pedal ratio. I might have to step out into the shop and measure my pedal.
[Re: feets]
#1233104
05/17/12 01:10 AM
05/17/12 01:10 AM
Kern Dog
Granite Bay CA
8 piston calipers up front. The total working area is 4.40 square inches. The rear working area is 2.05 square inches. This makes the rear caliper force about 46 % of the front. Your front calipers have a piston area of 5.94 square inches and the rears are 2.43 square inches. Both calipers displace more fluid than mine. Your rotors are 11.75" front and 10.7" rear. Using the same math, my numbers show the rear calipers here have 41 % of the front
I guess this means that I would have a little less rear bias, which I call a GOOD thing!
[Re: feets]
#1233105
05/17/12 10:06 AM
05/17/12 10:06 AM
70Cuda383
Marysville, O-H-I-O
That's not bad at all! for comparison, the Gen 2 viper calipers have a combined surface area of 3.88 square inches, and used a 1 1/16" master cylinder with a power booster. I'm running those calipers with a 1 1/8" master on my power brake booster on the Dakota.
I love how they borrow parts from each other too! the 03/04 dakota master cylinder is exactly the same as the gen III Viper master cylinders, and the 97-02 Dakota master, the 92-02 Viper master, 03-12 Viper master, and 03/04 Dakota master, all have the same piston depth into the brake booster, the same bolt pattern to bolt the master to the booster, and thus, all 4 masters are interchangable! (with the exception that the gen 2 viper masters use SAE double flare fittings, and the other 3 use metric bubble flare fittings)
with my brakes on the booster, it feels really good. If I was to manual brakes, I'd probably find a disc/disc master that was 1 1/16" with these viper calipers.
[Re: Kern Dog]
#1233106
05/17/12 12:44 PM
05/17/12 12:44 PM
feets
Senior Management
Senior Management
Irving, TX
I crashed some numbers around last night but lost my internet connection and couldn't post 'em. I compared the hot rod to your car. This wasn't an attempt to make my car look good. The hot rod's brakes work well and I could find all the numbers involved. The pedal ratio on the hot rod is 7.125:1 so my guess was WAY off. I looked at the pedal ratio, MC bore size, and effective brake radius of the cars. With the hot rod, 100 lb pedal effort makes 4883 lb/ft of front brake torque. With your car 100 lb pedal effort makes 4961 lb/ft of front brake torque. The 1.5% will never be seen in the real world. Comparing master cylinder volume to brake caliper volume will show some interesting numbers. When my master moves 1 inch the front calipers move out .1129". When your master cylinder moves 1 inch the calipers move .058". The resulting pedal feel will be quite different. Brake pads are usually a few thousandths of an inch off the rotors unless the rotor is not round. If you have pad material built up on the rotor or lots of runout the pads will get knocked back away from the rotor. Shifting to the rear.. The hot rod turns 100 lb pedal effort into 2156 lb/ft of brake torque. Your car turns 100 lb pedal effort into 1355 lb/ft of brake torque. The 38% difference will be very noticeable. When my master cylinder moves 1" the rear caliper pistons move .242". When your master cylinder moves 1" the rear caliper pistons move .142". ***EDIT*** I butchered some of those numbers. oopsie. The comparisons between the two systems are the same so you can still learn what you needed to learn. See this post for more accurate info.
[Re: Kern Dog]
#1233108
05/17/12 04:58 PM
05/17/12 04:58 PM
feets
Senior Management
Senior Management
Irving, TX
The piston movement is easy to figure. You look at the bore of the master cylinder and the bore of the caliper pistons. Divide the master cylinder bore by the caliper piston bore. Take that total and divide by two since you have calipers on the left and right. Figuring one inch of movement is easy. Multiply the area by 1. Can't get much easier than that. At one inches of depth your master cylinder holds .6901 cubic inches of fluid. The calipers have 5.94 square inches of surface area. You have two of them for a total of 11.88 square inches. Take a pan with an area of 11.88 square inches and drop in .69 cubic inches of water. How deep do you think it's going to be?
[Re: feets]
#1233109
05/17/12 05:33 PM
05/17/12 05:33 PM
70Cuda383
Marysville, O-H-I-O
yup.
When calculating pressure or force generated at the caliper, that's a 2 dimensional calculation. area of master cylinder vs area of caliper pistons.
when calculating pad movement, that's a 3 dimensional calculation, master cylinder piston area times height (or stroke) vs caliper piston area times height/stroke.
as an example, I just had a rotor that was .030 out of round. that means as it rotated, it would push the pad and pistons back into the caliper. .030 of movement ends up being .060 of total displacement, because both the outter pistons would push in .030, and the inner pistons would also push in .030.
the guy I got the rotor from tried to tell me that my soft pedal that would pump up solid was not because of his out of round rotor, and that I had other problems (but agreed to send me another rotor anyway) I then pointed out to him that with a combined piston area of 7.76 in just one caliper, that I needed several inches of stroke out of the master with just 1" of area just to push the pads back out a combined distance of .060.
yes, when calculating pressures, you only use 2 pistons of the 4, because they offset and push against each other, but when you're talking about piston movement to take up the distance from them being pushed back into the caliper by the wobbly rotor, you have to account for ALL of the pistons.
anyway, despite him trying to tell me that I had 'other problems causing my soft pedal" a new rotor with nearly zero runnout fixed my issue.
[Re: DynoDave]
#1233111
05/17/12 08:37 PM
05/17/12 08:37 PM
Kern Dog
Granite Bay CA
This stuff leaves me in a fog.
I wish some of feets' math could be put into a spreadsheet with formulas...put in the value, get the ratio/value out. But I guess it's not that simple.
I thought that I was pretty decent at math. I should clarify... I am pretty decent at ARITHMETIC. The stuff Feets put up is over my head!
I finished the RETURN to power brakes. The car has brake DIVE once again! WOW! All the cussing and frustration.... GONE. I had another couple of posts in the standard Q&A forum. In one of them, a helpful member listed a link to a vacuum can from Summit racing equipment. It was suggested to me a while back. I should have listened. Its sad that I didn't figure it out. I looked at the distribution block that I had with the manual setup. I couldn't find anything wrong with it. All this speculation about pedal ratios and caliper force is good diagnostic efforts, but at this point, the problem remains a mystery!
[Re: DynoDave]
#1233112
05/17/12 11:04 PM
05/17/12 11:04 PM
feets
Senior Management
Senior Management
Irving, TX
This is a good read. I'm sorry it's at Frankenduster's expense, but I'm learning quite a bit. And some o fit, honestly, leaves me in a fog.
It's really simple math. I've pretty good with numbers but when they started putting letters in there I got lost.
The most difficult thing to do is find the area of a circle. It's the radius of the circle multiplied by the radius of the circle then multiplied by 3.14.
If the circle is 3 inches across, the radius is 1.5 inches. 1.5 inches times 1.5 inches times 3.14 2.25 inches times 3.14 7.065 square inches.
Other than that, you're simply playing with numbers. I really thought about putting them into a spreadsheet just to play with later.
To be perfectly honest, getting too hard core into the numbers can leave you chasing a perfection that you will never find.
As for Frankenberry, I'm glad he got the brakes worked out.
[Re: feets]
#1233113
05/18/12 08:48 AM
05/18/12 08:48 AM
70Cuda383
Marysville, O-H-I-O
Or, in my case, you could run all the numbers, calculate that you need a 7/8" bore master cylinder for that perfect pedal effort on a manual setup, only to have the "expert" at the brake store tell you that you're wrong, and that every manual disc combo really needs a minimum of a 1" bore for fluid volume.
I had a pedal that was too stiff, and I never could lock up the fronts, although I was able to make it stop very hard, so I wasn't too concerned about it.
just annoyed that I allowed myself to be talked out of what I wanted because the guy posed himself as an expert who deals with this all the time
[Re: Kern Dog]
#1233115
05/18/12 06:54 PM
05/18/12 06:54 PM
Supercuda
About to go away
About to go away
up yours
You realize that with the power setup you lessen leverage and increase stroke for a given amount of pedal movement.
Your fluid volume was too little with the manual setup, ergo my recommendation to upsize the MC. You get more volume one of two ways, longer stroke, or larger bore.
[Re: 70Cuda383]
#1233116
05/18/12 07:08 PM
05/18/12 07:08 PM
feets
Senior Management
Senior Management
Irving, TX
It's kinda funny. As your master cylinder size goes up your pedal effort goes up but the brake pressure goes down.
[Re: feets]
#1233117
05/18/12 07:11 PM
05/18/12 07:11 PM
70Cuda383
Marysville, O-H-I-O
Yup! which is why I was so hesitant after doing my own calculations and decided a 7/8" was what I needed, but started to doubt myself when the "expert" told me I needed a 1" bore.
then once I started driving it, I was annoyed that my pedal effort was harder than I wanted, but not annoyed to the point of wanting to change it
Re: Brake bias & caliper BORE size. Problem found?
[Re: Kern Dog]
#1233123
05/19/12 02:55 AM
05/19/12 02:55 AM
feets
Senior Management
Senior Management
Irving, TX
Many master cylinders use larger fittings on one line. However, the lines themselves are the same size. It keeps people from installing the lines incorrectly.
If the adapter you used did not reduce the fluid passage below the size of the line I don't see where it would have been a problem.
[Re: ahy]
#1233126
01/26/14 05:56 PM
01/26/14 05:56 PM
Kern Dog
Granite Bay CA
Also vacuum. Sounds like you have a bigger cam and lower vacuum. PB work best with 18+ vacuum. Anything over 10 or 12 is usually enough for putting around but max assist needs more vacuum. One test would be to get up to speed and downshift so the engine is spinning>2000 RPM with throttle closed. At that point it should be making good vacuum. Are the brakes noticeably better?
At speed, the brakes work fantastic. While rolling along at parking lot speeds, they are not good. I'm sure is related to engine vacuum. It is exactly because of this that I am still curious as to how I could make a manual brake combination work.
[Re: Kern Dog]
#1233128
01/27/14 09:13 PM
01/27/14 09:13 PM
feets
Senior Management
Senior Management
Irving, TX
I don't understand why you had a problem with manual brakes.
I've got large diameter multi-piston manual brakes and the pedal feel is equivalent to that of the modern performance cars I deal with at work.
[Re: feets]
#3058760
07/13/22 03:02 AM
07/13/22 03:02 AM
Kern Dog
Granite Bay CA
It's kinda funny. As your master cylinder size goes up your pedal effort goes up but the brake pressure goes down. [/quote] Here I am, ten years later and I'm revisiting this same issue. I have the engine, trans, K member and suspension out of the car. I pulled the power brake booster and MC and swapped in another 15/16" MC from Dr Diff but I have a drum-drum distribution block. A video online featuring a crash involving a 64 Mercury Comet really shed light on the importance of upgraded brakes for high performance cars. I'm also looking into the Dr Diff 13" front brake kit.
[Re: Kern Dog]
#3059279
07/14/22 07:04 PM
07/14/22 07:04 PM
Posts: 6,215 nowhere
Sniper
nowhere
I am starting to understand it a little better but it still seems strange that a smaller surface area in terms of piston caliper sizing can provide more clamping force. It doesn't, in the caliper. Andy said in the Master cylinder though.
[Re: Sniper]
#3059290
07/14/22 08:48 PM
07/14/22 08:48 PM
Kern Dog
Granite Bay CA
I am starting to understand it a little better but it still seems strange that a smaller surface area in terms of piston caliper sizing can provide more clamping force. It doesn't, in the caliper. Andy said in the Master cylinder though. Here is where I am hung up.. My car currently has the Cordoba 11.75 rotors and 2,75" single piston front calipers. Going to a larger rotor makes sense regarding leverage. I am trying to understand how a caliper with less surface area could provide equal to or greater clamping force IF the master cylinder size is the same for both.
[Re: Kern Dog]
#3059366
07/15/22 09:58 AM
07/15/22 09:58 AM
Sniper
nowhere
I am starting to understand it a little better but it still seems strange that a smaller surface area in terms of piston caliper sizing can provide more clamping force. It doesn't, in the caliper. Andy said in the Master cylinder though. Here is where I am hung up.. My car currently has the Cordoba 11.75 rotors and 2,75" single piston front calipers. Going to a larger rotor makes sense regarding leverage. I am trying to understand how a caliper with less surface area could provide equal to or greater clamping force IF the master cylinder size is the same for both. Not sure where you got the idea a smaller bore caliper will have more clamping force.
[Re: Kern Dog]
#3059372
07/15/22 10:42 AM
07/15/22 10:42 AM
Posts: 30,989 Oregon
AndyF
I am starting to understand it a little better but it still seems strange that a smaller surface area in terms of piston caliper sizing can provide more clamping force. It doesn't, in the caliper. Andy said in the Master cylinder though. Here is where I am hung up.. My car currently has the Cordoba 11.75 rotors and 2,75" single piston front calipers. Going to a larger rotor makes sense regarding leverage. I am trying to understand how a caliper with less surface area could provide equal to or greater clamping force IF the master cylinder size is the same for both. It won't. The smaller pistons will reduce clamping force. You need to reduce the MC bore size to rebalance the system and then you need to change the rear wheel cylinder size so it isn't isn't out of whack. Most people fail at either step one or step two of this process. You at least are thinking about it so you're a step ahead of most.
[Re: Kern Dog]
#3059441
07/15/22 03:14 PM
07/15/22 03:14 PM
AndyF
I am trying to understand how and why a switch from a 12 inch setup to the 13 inch setup would provide a gain. If the larger rotor provides more leverage but the smaller caliper size isn't as effective, why wouldn't they increase the caliper size ? Is there so much gain in the leverage that it greatly offsets the loss from a smaller caliper? You are mixing and matching parts so there is no logic to the question. If you look at a late model car with 13 inch rotors you'll see that the MC bore size and the piston caliper sizes are all on the small size. The engineers figured out a few years back that if everything was smaller then it could all be lighter but still provide the clamping forces required to stop the car. The old 2.75 caliper used by Mopar back in the 70's doesn't really exist anymore. Now everything uses multiple pistons and small bore sizes.
[Re: Kern Dog]
#3059550
07/15/22 10:48 PM
07/15/22 10:48 PM
AndyF
If you were closer I'd just have you drive my Coronet so you could see what you think. I can tell you that my Coronet stops better than my Toyota 4Runner which has factory power 4 wheel disc brakes. I can exit the freeway at 80 mph in the Coronet and it will immediately pull down to 35 or 25 as I approach stopped traffic. With the 4Runner I have to be careful to leave plenty of stopping distance when slowing down from anything over 70 mph.
My Coronet has 13 inch front rotors with Porsche calipers. I added a rear disc kit a few years back but I think the factory drum brakes that I had on there before worked better than the disc brakes. I had the big station wagon drums out back and they really worked.
[Re: BDW]
#3059931
07/17/22 01:53 PM
07/17/22 01:53 PM
Posts: 19,307 north of coder
moparx
and speaking of pads, how do the ceramic types compare to the semi-metallic of back in the day, as compared to "red stuff", "yellow stuff", etc that EBC offers ? this is in relation to the small rotor size needed to fit 15" wheels. i have read all the descriptive attributes of the above mentioned pads, as well as what is offered by Hawk and other race type pad manufacturers, but i am hesitant to pull the plug on a set of pads, only to find out they may or may not, work to my expectations.
[Re: BDW]
#3059980
07/17/22 04:41 PM
07/17/22 04:41 PM
Kern Dog
Granite Bay CA
I think the newer cars can use smaller calipers because of the larger rotors. Can't underestimate the leverage adder.
Just think of how easy it is to break a bolt free after you slide a pipe on the rachet to extend it..... Excellent point. Could it be that simple?
[Re: Kern Dog]
#3060263
07/18/22 03:23 PM
07/18/22 03:23 PM
Sniper
nowhere
Just think of how easy it is to break a bolt free after you slide a pipe on the rachet to extend it..... Excellent point. Could it be that simple? ABS probably has an effect as well. While I can no longer remember the details I do recall an article Eberg wrote comparing the brakes on his Green Brick vs sports cars of the time it was written. Can't seem to google it though. I don;t recall it being real fancy though it might have has one of AndyF's Viper caliper setups on it.
Re: Brake bias, caliper BORE size and PAD recomendations...
[Re: Kern Dog]
#3060359
07/18/22 08:18 PM
07/18/22 08:18 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
How much does that Duster weigh? How much does your Charger weigh? Bigger cars need more brakes(bigger contact area) to stop as good as lighter smaller cars do, basic physics
[Re: moparx]
#3060887
07/20/22 11:16 AM
07/20/22 11:16 AM
Posts: 1,231 Chicago, IL
PLUM_72
Chicago, IL
and speaking of pads, how do the ceramic types compare to the semi-metallic of back in the day, as compared to "red stuff", "yellow stuff", etc that EBC offers ? this is in relation to the small rotor size needed to fit 15" wheels. i have read all the descriptive attributes of the above mentioned pads, as well as what is offered by Hawk and other race type pad manufacturers, but i am hesitant to pull the plug on a set of pads, only to find out they may or may not, work to my expectations. This pad part of the thread seems to be getting lost and may need a thread of its own...
1972 Dodge Challenger
