Re: Brake bias and caliper BORE size.
[Re: Kern Dog]
#3059550
07/15/22 10:48 PM
07/15/22 10:48 PM
Posts: 30,995 Oregon
AndyF
If you were closer I'd just have you drive my Coronet so you could see what you think. I can tell you that my Coronet stops better than my Toyota 4Runner which has factory power 4 wheel disc brakes. I can exit the freeway at 80 mph in the Coronet and it will immediately pull down to 35 or 25 as I approach stopped traffic. With the 4Runner I have to be careful to leave plenty of stopping distance when slowing down from anything over 70 mph.
My Coronet has 13 inch front rotors with Porsche calipers. I added a rear disc kit a few years back but I think the factory drum brakes that I had on there before worked better than the disc brakes. I had the big station wagon drums out back and they really worked.
[Re: BDW]
#3059931
07/17/22 01:53 PM
07/17/22 01:53 PM
Posts: 19,355 north of coder
moparx
and speaking of pads, how do the ceramic types compare to the semi-metallic of back in the day, as compared to "red stuff", "yellow stuff", etc that EBC offers ? this is in relation to the small rotor size needed to fit 15" wheels. i have read all the descriptive attributes of the above mentioned pads, as well as what is offered by Hawk and other race type pad manufacturers, but i am hesitant to pull the plug on a set of pads, only to find out they may or may not, work to my expectations.
[Re: BDW]
#3059980
07/17/22 04:41 PM
07/17/22 04:41 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I think the newer cars can use smaller calipers because of the larger rotors. Can't underestimate the leverage adder.
Just think of how easy it is to break a bolt free after you slide a pipe on the rachet to extend it..... Excellent point. Could it be that simple?
[Re: Kern Dog]
#3060263
07/18/22 03:23 PM
07/18/22 03:23 PM
Posts: 6,225 nowhere
Sniper
nowhere
Just think of how easy it is to break a bolt free after you slide a pipe on the rachet to extend it..... Excellent point. Could it be that simple? ABS probably has an effect as well. While I can no longer remember the details I do recall an article Eberg wrote comparing the brakes on his Green Brick vs sports cars of the time it was written. Can't seem to google it though. I don;t recall it being real fancy though it might have has one of AndyF's Viper caliper setups on it.
Re: Brake bias, caliper BORE size and PAD recomendations...
[Re: Kern Dog]
#3060359
07/18/22 08:18 PM
07/18/22 08:18 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
How much does that Duster weigh? How much does your Charger weigh? Bigger cars need more brakes(bigger contact area) to stop as good as lighter smaller cars do, basic physics
[Re: moparx]
#3060887
07/20/22 11:16 AM
07/20/22 11:16 AM
Posts: 1,232 Chicago, IL
PLUM_72
Chicago, IL
and speaking of pads, how do the ceramic types compare to the semi-metallic of back in the day, as compared to "red stuff", "yellow stuff", etc that EBC offers ? this is in relation to the small rotor size needed to fit 15" wheels. i have read all the descriptive attributes of the above mentioned pads, as well as what is offered by Hawk and other race type pad manufacturers, but i am hesitant to pull the plug on a set of pads, only to find out they may or may not, work to my expectations. This pad part of the thread seems to be getting lost and may need a thread of its own...
1972 Dodge Challenger
