Page 3 of 5 1 2 3 4 5
Brake bias and caliper BORE size. More clues inside! [Re: feets] #1233107
05/17/12 02:38 PM
05/17/12 02:38 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I crashed some numbers around last night but lost my internet connection and couldn't post 'em.
Comparing master cylinder volume to brake caliper volume will show some interesting numbers.
When my master moves 1 inch the front calipers move out .1129".
When your master cylinder moves 1 inch the calipers move .058".
W O W !! Is this because of the small bore master cylinder moves LESS volume or is it a combination of master cylinder AND pedal ratio?
NOT doubting you, I just wondered about the math involved.
Re: Brake bias and caliper BORE size. [Re: Kern Dog] #1233108
05/17/12 04:58 PM
05/17/12 04:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The piston movement is easy to figure.
You look at the bore of the master cylinder and the bore of the caliper pistons. Divide the master cylinder bore by the caliper piston bore. Take that total and divide by two since you have calipers on the left and right.
Figuring one inch of movement is easy. Multiply the area by 1. Can't get much easier than that.
At one inches of depth your master cylinder holds .6901 cubic inches of fluid.
The calipers have 5.94 square inches of surface area. You have two of them for a total of 11.88 square inches.
Take a pan with an area of 11.88 square inches and drop in .69 cubic inches of water. How deep do you think it's going to be?
- Stu Harmon
Re: Brake bias and caliper BORE size. [Re: feets] #1233109
05/17/12 05:33 PM
05/17/12 05:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yup.
When calculating pressure or force generated at the caliper, that's a 2 dimensional calculation. area of master cylinder vs area of caliper pistons.
when calculating pad movement, that's a 3 dimensional calculation, master cylinder piston area times height (or stroke) vs caliper piston area times height/stroke.
as an example, I just had a rotor that was .030 out of round. that means as it rotated, it would push the pad and pistons back into the caliper. .030 of movement ends up being .060 of total displacement, because both the outter pistons would push in .030, and the inner pistons would also push in .030.
the guy I got the rotor from tried to tell me that my soft pedal that would pump up solid was not because of his out of round rotor, and that I had other problems (but agreed to send me another rotor anyway) I then pointed out to him that with a combined piston area of 7.76 in just one caliper, that I needed several inches of stroke out of the master with just 1" of area just to push the pads back out a combined distance of .060.
yes, when calculating pressures, you only use 2 pistons of the 4, because they offset and push against each other, but when you're talking about piston movement to take up the distance from them being pushed back into the caliper by the wobbly rotor, you have to account for ALL of the pistons.
anyway, despite him trying to tell me that I had 'other problems causing my soft pedal" a new rotor with nearly zero runnout fixed my issue.
**Photobucket sucks**
Re: Brake bias and caliper BORE size. [Re: 70Cuda383] #1233110
05/17/12 08:23 PM
05/17/12 08:23 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
This is a good read. I'm sorry it's at Frankenduster's expense, but I'm learning quite a bit. And some o fit, honestly, leaves me in a fog.
I wish some of feets' math could be put into a spreadsheet with formulas...put in the value, get the ratio/value out. But I guess it's not that simple.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Brake bias and caliper BORE size. [Re: DynoDave] #1233111
05/17/12 08:37 PM
05/17/12 08:37 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This stuff leaves me in a fog.
I thought that I was pretty decent at math. I should clarify... I am pretty decent at ARITHMETIC. The stuff Feets put up is over my head!
I finished the RETURN to power brakes. The car has brake DIVE once again! WOW! All the cussing and frustration.... GONE.
I had another couple of posts in the standard Q&A forum. In one of them, a helpful member listed a link to a vacuum can from Summit racing equipment. It was suggested to me a while back. I should have listened.
Its sad that I didn't figure it out. I looked at the distribution block that I had with the manual setup. I couldn't find anything wrong with it. All this speculation about pedal ratios and caliper force is good diagnostic efforts, but at this point, the problem remains a mystery!
Re: Brake bias and caliper BORE size. [Re: DynoDave] #1233112
05/17/12 11:04 PM
05/17/12 11:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's really simple math. I've pretty good with numbers but when they started putting letters in there I got lost.
The most difficult thing to do is find the area of a circle. It's the radius of the circle multiplied by the radius of the circle then multiplied by 3.14.
If the circle is 3 inches across, the radius is 1.5 inches.
1.5 inches times 1.5 inches times 3.14
2.25 inches times 3.14
7.065 square inches.
Other than that, you're simply playing with numbers.
I really thought about putting them into a spreadsheet just to play with later.
To be perfectly honest, getting too hard core into the numbers can leave you chasing a perfection that you will never find.
As for Frankenberry, I'm glad he got the brakes worked out.
- Stu Harmon
Re: Brake bias and caliper BORE size. [Re: feets] #1233113
05/18/12 08:48 AM
05/18/12 08:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Or, in my case, you could run all the numbers, calculate that you need a 7/8" bore master cylinder for that perfect pedal effort on a manual setup, only to have the "expert" at the brake store tell you that you're wrong, and that every manual disc combo really needs a minimum of a 1" bore for fluid volume.
I had a pedal that was too stiff, and I never could lock up the fronts, although I was able to make it stop very hard, so I wasn't too concerned about it.
just annoyed that I allowed myself to be talked out of what I wanted because the guy posed himself as an expert who deals with this all the time
Re: Brake bias and caliper BORE size. [Re: 70Cuda383] #1233114
05/18/12 03:46 PM
05/18/12 03:46 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
It seems as if there are enough variables in NON stock brake setups that there are no hard and fast rules. This reminds me of why "crate" engines became so popular. Sometimes it simplifies things to have a self contained, well engineered system for people that have more money than expertise!
Re: Brake bias and caliper BORE size. [Re: Kern Dog] #1233115
05/18/12 06:54 PM
05/18/12 06:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You realize that with the power setup you lessen leverage and increase stroke for a given amount of pedal movement.
Your fluid volume was too little with the manual setup, ergo my recommendation to upsize the MC. You get more volume one of two ways, longer stroke, or larger bore.
Don't be the exception.
Re: Brake bias and caliper BORE size. [Re: 70Cuda383] #1233116
05/18/12 07:08 PM
05/18/12 07:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It's kinda funny. As your master cylinder size goes up your pedal effort goes up but the brake pressure goes down.
- Stu Harmon
Re: Brake bias and caliper BORE size. [Re: feets] #1233117
05/18/12 07:11 PM
05/18/12 07:11 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yup! which is why I was so hesitant after doing my own calculations and decided a 7/8" was what I needed, but started to doubt myself when the "expert" told me I needed a 1" bore.
then once I started driving it, I was annoyed that my pedal effort was harder than I wanted, but not annoyed to the point of wanting to change it
Re: Brake bias & caliper BORE size. Problem found? [Re: 70Cuda383] #1233118
05/19/12 02:34 AM
05/19/12 02:34 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This is the last manual master cylinder that I used. I got it from Dr Diff.
Nice looking piece... 15/16", Aluminum with plastic reserviors, very light. The fitting sizes were sorta small though.
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233119
05/19/12 02:37 AM
05/19/12 02:37 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The 3/8" fittings posed a small problem. The combo block used a larger inlet fitting for the front line. I had to use an adapter.
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233120
05/19/12 02:39 AM
05/19/12 02:39 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This is the inlet of the adapter. I'm wondering if this thing caused some sort of restriction...?
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233121
05/19/12 02:41 AM
05/19/12 02:41 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Outlet
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233122
05/19/12 02:51 AM
05/19/12 02:51 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
As stated, the facts elsewhere just dont add up to explain the problems with the manual setup. Pedal ratio would have been the same with the 4 wheel drums that the car had long before.
The front brake line needed to be 3/8" at the master and 9/16" at the combo valve. I am terrible at flaring such small tubing, so I paid a guy to put a 9/16" fitting into a new brake like that had 3/8" fitting on the other end. HIS flaring skills were not any better than mine and the line leaked. THAT is why I used that adapter.
Feets, 383Cuda.... ANYONE have an opinion on the chance that THIS is the problem?
I just can't seem to let this one go.....!
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233123
05/19/12 02:55 AM
05/19/12 02:55 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Many master cylinders use larger fittings on one line. However, the lines themselves are the same size. It keeps people from installing the lines incorrectly.
If the adapter you used did not reduce the fluid passage below the size of the line I don't see where it would have been a problem.
- Stu Harmon
Re: Brake bias & caliper BORE size. Problem found? [Re: feets] #1233124
01/26/14 05:09 AM
01/26/14 05:09 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I really wish that I had an answer for this. Its been almost 2 years since I started this thread and I still think about it.
Some thought my pedal ratio was wrong for manual brakes to work.
I responded, saying the pedal ratio is identical to what the car had when I bought it with 4 wheel drums.
I tried 4 different non power master cylinders with different bore sizes and every one sucked. Hard pedal and poor stopping.
I thought of taking a spare brake pedal and drilling a new hole, higher toward the pivot point. This would increase the ratio. This would make for less effort, but would it be enough?
Re: Brake bias & caliper BORE size. Problem found? [Re: Kern Dog] #1233125
01/26/14 04:30 PM
01/26/14 04:30 PM
IN
ahy Offline
ahy  Offline
IN
In part it comes down to weight and size. Your B body is heavier than the A you are comparing to so that gives the A an advantage.
On line pressure, making the master bore smaller increases pressure but risks running out of volume. In the spirit of being a bit conservative I wouldn't want to go smaller than recommended and maybe sometime run out of volume. Also I wouldn't personally modify the linkage. Lots of design and testing went into it to make it robust.
Also pads. For around town driving with cool brakes, the low cost organic pads have more bite than anything. The higher end DD type pads also have good bite (think parts store "gold").
Standard grade semi-metallic and performance pads have the least bite when cool... but hang in there well when hot.
Also vacuum. Sounds like you have a bigger cam and lower vacuum. PB work best with 18+ vacuum. Anything over 10 or 12 is usually enough for putting around but max assist needs more vacuum. One test would be to get up to speed and downshift so the engine is spinning>2000 RPM with throttle closed. At that point it should be making good vacuum. Are the brakes noticeably better?
In your case, I'll suggest maybe a pad change would help or more boost. An 8" double booster would give roughly 50% more boost compared to a 9" single. Or hydroboost which would also take vacuum out of the equation.
I've got a similar opportunity. I've got 13" Baer brakes up front. Piston area is smaller than OE and the 9" booster does not have enough "oomph". The brakes work very well but I run out of boost before I run out of brakes. I'll likely do the double booster or hydroboost. My preference is the hydroboost as its lighter, more compact and provides more pressure. It's just spendy.
Re: Brake bias & caliper BORE size. Problem found? [Re: ahy] #1233126
01/26/14 05:56 PM
01/26/14 05:56 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
At speed, the brakes work fantastic. While rolling along at parking lot speeds, they are not good. I'm sure is related to engine vacuum. It is exactly because of this that I am still curious as to how I could make a manual brake combination work.
