383 with Stealth Heads in a 1900 lbs car #1230670
05/09/12 10:37 PM
05/09/12 10:37 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So I sold my Dart and have started collecting parts to get my old rebuilt 383 stuffed in my 32' Roadster so I can run the Mopar races. The engine ran 11.60's in my 3100 Dart with a junk 10" TCI converter back in the day. I rebuilt the engine a couple of years ago as a spare and listed it for sale but since nobody is interested I might as well use it.
I have added some 440 Source Stealth heads to replace the old 906's. Its a basic build with TRW 12.5 pistons, .557 Mopar Cam, M1 intake and a 750 Quick Fuel E85 carb.
The Roadster runs 9.70's @ 133 with a 396 BB Chevy with Steel Heads, PowerGlide, 8" 5000 stall converter, 4.77 Gears and 14.5 x 32 tires.
If the little 383 runs close to 396 I'll be thrilled. Over the winter I'd like to stroke the 383 similar to the combo I ran in my Dart (400 with 440 crank, 2.2 Chevy rods...etc...) but I'd like to get this thing together by June.
Anyway what do you guys think it'll run with the little 383? I'm guessing 9.90's.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230671
05/09/12 10:40 PM
05/09/12 10:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Ahhh: I think low to mid 10's. It depends on all the support systems. Correct gear, convertor etc.
Sheldon
Re: 383 with Stealth Heads in a 1900 lbs car [Re: RUNCHARGER] #1230672
05/10/12 08:18 AM
05/10/12 08:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
to run 9.70 in a 1900lb car it'd take what 400-425hp??? A warm 383 should come close to that. I can see 10.0's.
Coming soon!!!!
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230673
05/10/12 08:49 AM
05/10/12 08:49 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
if you make an honest 450hp and at 1900lbs, you should run 9.40's-9.60's...so high 9..no problem...
Re: 383 with Stealth Heads in a 1900 lbs car [Re: smokinwoody] #1230674
05/10/12 12:09 PM
05/10/12 12:09 PM
organ
maximum entropy Offline
organ
i smell 9s. makes me wanna git a roadster.
Re: 383 with Stealth Heads in a 1900 lbs car [Re: maximum entropy] #1230675
05/10/12 01:12 PM
05/10/12 01:12 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
My 383 with 312 heads, TRW pop-ups, a Hughes .600" solid cam, tunnel ram with a pair of Holley 750 double pumpers, Torqueflyte, 4.56 gears, 1600 lbs. ran 9.50's like clockwork.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: 383 with Stealth Heads in a 1900 lbs car [Re: Slingshot383] #1230676
05/10/12 01:57 PM
05/10/12 01:57 PM
Renton Washington
Triple Threat Offline
Renton Washington
A friend had a 72 Chevelle with your basic 355 in it. Ran 11.70 best. Sold the car roller and stuck the engine in a 225" WB hard tail dragster and its been 9.40 I believe. only change being headers obviously.
You shouldn't have any issue getting a 9 second run out of it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230677
05/10/12 03:01 PM
05/10/12 03:01 PM
AndyF Offline
AndyF  Offline
That engine should make 450 to 500 hp unless the rings are totally wasted. If the car is really only 1900 lbs then you'll easily go mid 9's if you can get it to hook up. The car will go about 140 mph thru the lights so you better have the gearing correct.
Re: 383 with Stealth Heads in a 1900 lbs car [Re: AndyF] #1230678
05/10/12 09:41 PM
05/10/12 09:41 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Its a fresh 383 at this point with new rings, bearings and heads. I hope you guys are right. I just want it run close to the 396 or I'll never hear the end of it from my Chevy buddies. The chassis on the Roadster flat hooks ...I had BondoBob redo the chassis last winter. Last weekend it went 6.15 over and over.
AndyF - I just sold my Dart with the 413 crank you turned down for a B engine and 2.2 Chevy rods that you sold me years ago. That 458' engine still runs amazing for what it was. 6.50 in the 1/8th and 10.30 in the 1/4. I don't suppose you have any more cranks like that laying around?
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230679
06/01/12 05:53 PM
06/01/12 05:53 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
The resurrected 383 is almost ready to run. Engine is now complete so I just have headers and powerglide adapter to workout.
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230680
06/01/12 06:13 PM
06/01/12 06:13 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
I sold my old arrow with a tired 383,trw 11.5's,mp590,ootb eddy's,glide and 456's no tune up at all and goes 10 teens in phoenix@2100 lbs
Re: 383 with Stealth Heads in a 1900 lbs car [Re: stockerbill] #1230681
06/01/12 06:35 PM
06/01/12 06:35 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
You guys are making me want to lose some weight. About a 1000 pounds would make a good start. beep
Re: 383 with Stealth Heads in a 1900 lbs car [Re: Bigbeep] #1230682
06/03/12 11:25 PM
06/03/12 11:25 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
Our slightly lighter 207"wb nostalgia FED ran 8.70s at just shy of 160mph in the heat/humidity of south Georgia (SGMP Cecil) with a .060" over 383 (395"). We ran a 4.30 gear and a Powerglide with a 5000rpm, 8" PTC converter and 33" M/T slicks. The motor had the same TRW 2293F pistons (flycut) and stock rods with ARP2000 waveloc bolts. We ran "915" iron heads, ported and polished by www.killiansportingservice.com and a Lunati solid flat tappet cam just a touch bigger than the .557" (265/271@.050", .576/.563", 108LSA) with Crane roller rockers and pushrods. 2 x 660 Holleys on an old Offy tunnel ram and "zoomie" headers gave it that retro look. AND it was one of the baddest SOUNDING cars wherever it went! Shifted @7200. Have fun!!!
Re: 383 with Stealth Heads in a 1900 lbs car [Re: Bighead440] #1230683
06/04/12 09:36 PM
06/04/12 09:36 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Shifted at 7200 running 8.70's on a stockish bottom end 383 - that's awesome! I doubt I'll zing mine that high - probably 6400 tops but you give me high hopes. I'm a bracket racer through and through so I just want something consistent that I can run the piss out of.
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230684
06/05/12 10:45 AM
06/05/12 10:45 AM
Bighead440 Offline
Bighead440  Offline
I still have the motor, I want to put a Reed solid roller I have in it, with a valvespring swap and a TM6 with a single 850 Holley, then stuff it in a straight axle Gremlin I have...
BTW: We swapped this motor for a 471" B stroker with ported Eddy RPM heads and a mild solid-roller cam (274@.050", .645" lift) and only went 8.10s/170mph with the same carbs and intake. Now we have a M1 tunnel ram and 2 x 850 Holleys and it just runs in the 7s, needs more CAMSHAFT...
The 3.38" stroke motors love to rev, so my advice is put a set of rods in it and zing it appropriately!!!
Re: 383 with Stealth Heads in a 1900 lbs car [Re: Bighead440] #1230685
08/24/12 03:12 PM
08/24/12 03:12 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
The engine swap is almost complete and I hope to post pictures later today as I pick the car up from the fab guy here in a bit. The guy is flat-out a welding Jedi-Master - he re-worked the aluminum engine plates, fabricated valve-covers, built the headers, re-routed the steering shafts and the welds are just amazing.
If I can get everything buttoned up tonight I'm hoping for some track results tomorrow.
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230686
09/08/12 12:37 AM
09/08/12 12:37 AM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Finally got out to Test n Tune and it was mostly a success. Only 3 runs but ran 6.44 @103 and seems like alot more left. That MPH is way low because it just didnt want rev as I found the valves were lashed too tight and not fully closing once it got hot. Tomorrow I'll be busy re-tightening head bolts, lashing the valves and giving everything a once over. Heading back to the track on Sunday to see what it runs with the correct valve lash and hoping to go some rounds. This little 383 sounds just nasty in the burnout box and instantly revs up.
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230687
09/08/12 06:05 AM
09/08/12 06:05 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
That translates to a 10.o
Re: 383 with Stealth Heads in a 1900 lbs car [Re: viperblue72] #1230688
12/30/12 05:03 PM
12/30/12 05:03 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So my little roadster is getting a full make over this winter including new engine, trans, wheels and paint. The lil' 383 had some major issue and ended up spinning a rod bearing after just a few more runs. The fact that it ran 6.40's is amazing because the cam had wiped lobes, 2 rings were messed up during install which gouged the block and the head gaskets were leaking. It was just a big mess and all as a result of rushing to get it together. The new engine is being machined and assembled at Mann Performance. Its still a 383 but this time it has eagle rods, billet main caps and a slightly larger cam. The builder expects it to run low 9's but I'll be happy with 9.70's.
I have finished the new paint and have a few more hours of polishing before we can start putting it back together. Hopefully everyone appreciates the retro muscle-car theme inspired by the amazing art work of Bruce.
68 Dart - 340
66 Belvedere - 400
Re: 383 with Stealth Heads in a 1900 lbs car [Re: 69dart] #1230689
12/30/12 06:07 PM
12/30/12 06:07 PM
That looks Wicked!! I love it!!!
Lets see a pix of that FED
Light Weight Cars--gotta love them!
