Power Question??? #1230594
05/09/12 09:13 PM
05/09/12 09:13 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I have a 402 pumpgas smallblock. Runs 7 teens in the heat as is.Best pass to date is 7:02 with good cool weather. Has hydrolic roller cam with powerbrakes, out of the box edelbrock performer heads. I want to run the 7:0 index at our local track. I would like to run 6:90's What do i need to do to run 6:90's It is a ladderbar coilover and dead hooks traction is no problem. Thanks in advance
Re: Power Question??? [Re: bobs69] #1230595
05/09/12 09:58 PM
05/09/12 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Post up a time slip... but with porting you could
be there... maybe just bowl porting them
Re: Power Question??? [Re: MR_P_BODY] #1230596
05/09/12 10:29 PM
05/09/12 10:29 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
On the road with no way to post a time slip but The slowest pass for last sunday was 60 ft. 1.54 330 4.56 1/8 mile 7.18 @ 94.40
Re: Power Question??? [Re: bobs69] #1230597
05/09/12 10:43 PM
05/09/12 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is the stall and gear in it... what RPM do you
hit the end at
Re: Power Question??? [Re: bobs69] #1230598
05/09/12 10:50 PM
05/09/12 10:50 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
More compression in the motor or put it on Alc or spray it a little GOOD LUCK
Re: Power Question??? [Re: MR_P_BODY] #1230599
05/09/12 10:52 PM
05/09/12 10:52 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
4:56 rear 28 inch tire shift at 5500 cross at 5500. We have shifted at higher rpm but nothing changes actually ran slower. It will stall 3200. Leave the line about 2500.
Re: Power Question??? [Re: bobs69] #1230600
05/09/12 11:09 PM
05/09/12 11:09 PM
Work on the 60 ft. times, carb. squirter, ignition timing at 2500 RPM, if you run it with open headers try some collector extensions, shift it sooner in 1st and 2nd gear, in other words test, test, test and then test some more Can you take any weight out of the car? If so do that also One other thing is radial tires , if they will hook good at your track, can be worth 1/10 in the 1/8 mile, more in the 1/4 mile
Re: Power Question??? [Re: bobs69] #1230601
05/09/12 11:10 PM
05/09/12 11:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Give us all the specs on the engine... even with a
hyd roller that low rpm... you defiantly have a choke
some where... you could use more conv also
Re: Power Question??? [Re: MR_P_BODY] #1230602
05/09/12 11:21 PM
05/09/12 11:21 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Have not had the motor apart is as i bought it. Was told from last owner 4 inch crank stock bore for a 360 makes it 402 eagle rotating assembly. Around 10 to 1 compression we do run one gallon race gas with 4 gallon pump gas.
Re: Power Question??? [Re: bobs69] #1230603
05/10/12 12:02 AM
05/10/12 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that you dont know anything about the engine
other than the cubes its gonna be hard to say what
it needs but I would start with the heads
Re: Power Question??? [Re: bobs69] #1230604
05/10/12 12:11 AM
05/10/12 12:11 AM
Az
Crizila Offline
Crizila  Offline
Az
What intake and carb are you running? If you are only looking for another tenth or so, you might be able to "massage" that area a bit to get there.
Fastest 300
