Re: why a 4 prong balast?
[Re: 67 GTX]
#123023
09/22/08 01:09 PM
09/22/08 01:09 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
You will also have two field wires for your alternator hook up if this is a Year One harness with the electronic conversion. Just a heads up when you get to that point. I went ahead and went to a two field alternator and a 4 prong ballast on my 67 GTX when I used this harness. The later alternator is supposed to be better.
Yeah I plan on using a dual field Alt..
[Re: 67 GTX]
#123024
09/22/08 09:05 PM
09/22/08 09:05 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
I too have the Year One conversion you refer to. I purchased a black regulator that is supposed to be compatible with this set up yet retains the look of the original regulator. However, the conversion harness has a push on triangular shaped connector for the '70 and later type regulators. What did you do about this situation?
James Stinebaker
