Re: Got our late 5.7 Hemi heads today!
[Re: Brian Hafliger]
#1229940
05/30/12 10:42 PM
05/30/12 10:42 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Did all the flow testing today. Now the 6.1 heads I have, someone has done some mild cleanup to the ports...doesn't look like any carbide work just some flashing removal and blending with a cartridge roll. Other than that, all theads are untouched OOTB.
First is the pre '09 5.7 head with stock 2.00x1.55 valves and factory VJ: Lift Int. Ex. 100 72 54 200 151 120 300 223 158 400 256 177 500 265 186 600 267 190 700 268 190
Late 5.7 Hemi with 2.03x1.55 factory valves and VJ: Lift Int. Ex. 100 72 52 200 155 116 300 233 156 400 283 182 500 303 192 600 308 195 700 311 196
6.1 Hemi with factory 2.08x1.6 valves and factory VJ: Lift Int. Ex. 100 72 61 200 146 122 300 221 170 400 278 200 500 315 205 600 334 209 700 338 210
So what does it all mean? Haaaa....I think any of these heads will work awesome but they do have drasticly different port shapes and sizes. I'll post pics tonite so you can see them next to one another. I really like the later 5.7 head with the smaller chambers. And they have much longer valves than the other heads have as well.
The early 5.7 had much faster intake ports since the ports are much smaller than the late 5.7 and 6.1 so they should work best with smaller cid engines and lower rpm strokers especially with some mild port work. I'm hoping we start doing some testing here within a couple of months and anything we do I'll post it up. Brian
Just got my set flowed 5.7 stock head intake ............. exhaust .100 72.2 ............ 56.6 .200 150.4 ............ 112.4 .300 217.3 ............ 148.9 .400 272.5 ............ 176.3 .500 299.2 ............ 183.6 .600 302 ............ 185
not bad for a STOCK HEAD. Matt
I don't think I remember to put the putty on.
[Re: MattW]
#1229941
05/31/12 01:51 AM
05/31/12 01:51 AM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
I used a 2" pipe on all the exhaust ports when I flowed them. Without a flow radius on the intake, the air shears at the opening and skews the results.
Brian Hafliger
[Re: AlexP]
#1229945
06/04/12 03:29 PM
06/04/12 03:29 PM
MattW
Ontario Canada
On the car or off the car?
C CLAMP. off the car. I know about all the different types. Just thought my simple manual C Clamp type would work better. Maybe its me but never had a problem with regular heads. Eventually I will make one that site on the heads and you scew the spring to compress it.
[Re: AlexP]
#1229947
06/05/12 10:28 AM
06/05/12 10:28 AM
MattW
Ontario Canada
Hey its back Brian let's keep this going . I have a new set of Apache heads I will flow soon. Man the valve and port are big. Really looking for a set of OFF THE SHELF piston and rod combo for the factory 3.72 stroke crankshaft. Matt
[Re: MattW]
#1229951
06/05/12 04:52 PM
06/05/12 04:52 PM
Posts: 2,826 NY usa
540challenger
NY usa
Well I just got my 6.4 heads in the mail today
http://s1265.photobucket.com/albums/jj501/540Challenger/GenIII%20Hemi%20build/
My Alum. block should be here tomorrow i will have pictures up tomorrow
Which block did you get . Same place as the heads? Will be keeping an eye on you. Lol
The block i got through jegs. Since the block and heads are going to sit for at least a year while i gather funds to finsh the build. Since i tapped out my car fund between the hemi parts and Vet's bills
4500 cost for the block
1300 for the heads
2000 for the Vet bills b/c my 5 pound dog ate Chocolate so there goes the rotating assemble money
[Re: 540challenger]
#1229952
06/05/12 05:00 PM
06/05/12 05:00 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
No port volumes as of yet. Ahhhh a 6.4 deal would be very nice. I would love to work with the aluminum block too. I'm so buried here at work who know's when I'll have time to get to the Hemi builds. I'm having some difficulty keeping up.
On a different note...I hope to be building a stroker 6.1 for my Duster by the end of the year so let's keep this going!!
Brian Hafliger
[Re: 540challenger]
#1229953
06/05/12 05:37 PM
06/05/12 05:37 PM
MattW
Ontario Canada
1300 for the heads
Nice had a 145 lbs rotty that ate a big green caterpillar. Stupid thing almost died. $$$$$$$ What block did you get? I think the one that is bored to 4.114 is the better one because if the amount of rebuilds you can get. Thx for the info.
#1229954
06/05/12 05:50 PM
06/05/12 05:50 PM
MattW
Ontario Canada
Brian I think their is only 3 ways to make the Apache head work. Force induction, spinning.it to the moon in small CID form or large cubes. The second one I'm concern about possible oiling issues. The last ,and this is my avenues, is using the 4.25 crank. Apparently BES had to sink the valve .070 to make this work.
I could be totally wrong in saying this so don't take it personal. I don't think you need any expertise to port this heads. The port is a straight shot at the valve. No short turn to worry about.
