Protecting shift cable from direct contact w/ header... #1229411
05/08/12 11:40 AM
05/08/12 11:40 AM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Melted cable. BB w/ Hedman Hedders, B&M Pro Ratchet. Tube is very, very close to cable bracket on pan. Will one of the slip-on sleeves protect it if it slips again and comes into direct contact for a while? Would a longer cable (6-8-10 ) help with routing?
I know the best thing to do would be to bite the bullet and buy a different shifter that shifts from the back but trying to work with what we have.
TIA
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Protecting shift cable from direct contact w/ header... [Re: I_bleed_MOPAR] #1229412
05/08/12 12:06 PM
05/08/12 12:06 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Maybe a piece of header wrap somehow taped around the cable to either side of the potential contact point?
Re: Protecting shift cable from direct contact w/ header... [Re: POS Dakota] #1229413
05/10/12 08:08 AM
05/10/12 08:08 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I hooked a couple large ty-wraps together and pulled the cable away from the header. Not pretty but works.
Re: Protecting shift cable from direct contact w/ header... [Re: I_bleed_MOPAR] #1229414
05/10/12 08:54 AM
05/10/12 08:54 AM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
I used one of these:
http://www.summitracing.com/parts/THE-11620/
They come in different lengths. Worked well for me.
Re: Protecting shift cable from direct contact w/ header... [Re: bill440rt] #1229415
05/10/12 09:16 AM
05/10/12 09:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Run the cable through a length of heater hose and tie it away from the header..
I am truckless..
Re: Protecting shift cable from direct contact w/ header... [Re: 63stabamatic] #1229416
05/10/12 10:00 AM
05/10/12 10:00 AM
Andrewh Offline
Andrewh  Offline
http://www.extremeheatprotection.com/
this stuff should have something for you.
I use the fire sleeve myself. only good for 500 F continuous, but I only expect incedental contact.
