Re: XE274 cam
[Re: 383ramd150]
#1229292
05/08/12 09:50 AM
05/08/12 09:50 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
If you're running 4.56's, then don't hesitate to run the xe 274....but anything less and a 318, you'd be fine to stick with the 268, especially if you're running eddy heads.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
Re: XE274 cam
[Re: 383ramd150]
#1229293
05/08/12 10:43 AM
05/08/12 10:43 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
What stall? If it flashes high enough I'd go a step higher cam with a engine like yours, perhaps a XE284H.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: XE274 cam
[Re: dogdays]
#1229295
05/08/12 01:37 PM
05/08/12 01:37 PM
Posts: 32 LaFollette TN 37766
383ramd150
LaFollette TN 37766
I have a 727 with 2800 stall!Also using mp heavy duty rockers!318 was all i have but it is eventually gonna get a bigblock!
Re: XE274 cam
[Re: 383ramd150]
#1229297
05/08/12 03:21 PM
05/08/12 03:21 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Also there aint many built 318s around here but alot of 340 and 360's!Just want to see what the 318 is packing!
Just depends on how much money you want to put into it ![](/ubbthreads/images/graemlins/smile.gif)
Re: XE274 cam
[Re: 383ramd150]
#1229302
05/10/12 01:41 PM
05/10/12 01:41 PM
383ramd150
LaFollette TN 37766
The only problem i have is that eventually i gonna take it to track for some test and tune nights at and all we have close is 1/8th mile!Will 4.10 gear be enough!The stall i do have is boss hogg 2200-2800 stall
Re: XE274 cam
[Re: goldmember]
#1229305
05/22/12 10:37 PM
05/22/12 10:37 PM
383ramd150
LaFollette TN 37766
Well,I am thinking of going solid.Has anybody used comp xs268s cam with 230/236 duration @50 and 488/501 lift?Or should i go step bigger?
Re: XE274 cam
[Re: JoesMopar]
#1229307
05/23/12 10:56 AM
05/23/12 10:56 AM
Posts: 4,769 Moved to N.E. Tennessee
GomangoCuda
Look at whatever cam catalog you have decided to use. Go clear to the bottom of the list where the biggest and baddest cams live. Look at them, don't buy them. work your way up the list. Its OK to close your eyes and imagine what they would sound like but don't buy them. When you get to the one that looks too small but says it will work in a 318 truck, BUY IT.
Re: XE274 cam
[Re: DARTH V8Я]
#1229308
05/23/12 05:38 PM
05/23/12 05:38 PM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
Small motor in a pickup which by nature is heavy? Go for the smaller cam. Your heads will take care of any breathing issues there are and don't need to be crutched by a big cam.
R.
Normally I agree with you, but if hes making 300hp @ 5250 he's also making 300lbs-ft @ 5250. Remember that \6's ran these things too with realitive ease..
/6 engines made these trucks move, sure, but a ten speed bicycle is faster off of the line. With the gears, stall, and tires this guy is running my guess is he wants to go fast.
Eddie heads, big valves, small bores, an XE-274, and valve shrouding are, at least to me, a recipe for a really lazy motor. Even if it produces decent numbers up top the usable power curve down low is going to be flat.
All of this aside, you if plan on going big block later on in the life of this project, why blow $1400 on a set of heads you can't reuse on the new motor?
![](/ubbthreads/images/graemlins/Twocents.gif)
