Page 2 of 3 1 2 3
Re: 1st time on track little dissapointed [Re: T-bar] #1229147
05/08/12 08:09 AM
05/08/12 08:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks like your 60 foot can be better.cI'd think if you could get it down to 1.60 your et would really pick up. What were you hoping for? I'm running a turbo Action 3800 stall and it works well on the street and at the track. Did you try launching it different? Mine 60 foot is better from off idle (1500rpm) and dead stomping it than loading up on the converter. Takes time to figure all that out. You might also want to add or take out some timing..It's not something you are going to get the 1st time out, unless you get 15 runs.
Coming soon!!!!
Re: 1st time on track little dissapointed [Re: Mr.Yuck] #1229148
05/08/12 08:32 AM
05/08/12 08:32 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
My car is 3300 lbs with me in it. 5.9 magnum with a 4" crank making 406" hyd roller (limited lift with factory lifters) motor, 904 basicly stock with TA vb with 4.10 rear gear with 29" tires. I had a BTE 9.5" converter handing out a 1.58 60 ft time with a 11.50's 1/4 et in good air and 11.70's in heat. Changed to a TA 8" verter and car went (good air) 1.44 60 ft with an et of 10.92 at 122 mph, (heat / bad track prep) 1.49 / 1.50 60 ft, 11.03 1/4 mile at 119 mph. A good converter will make you think you are in someone elses car, haha. Old verter stalled around 3300 flashing at 4000 or so. 8" is stalling 4200 or so with a flash around 4900 rpm. Buy a good one and you are done with that area. If you buy 2 or 3 cheap ones, you could have had 1 good one and didn't have to pull trans many times. talk to the RB guys and find what is working with your numbers.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: 1st time on track little dissapointed [Re: StandOnIt] #1229149
05/08/12 10:07 AM
05/08/12 10:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
MPH is down. I suggest tuning before spending money, ripping the heads off, or doing any other parts swapping.
Re: 1st time on track little dissapointed [Re: T-bar] #1229150
05/08/12 10:27 AM
05/08/12 10:27 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Now that you provided some more cam info ( exactly where I was headed when asking the LSA), you do have better choices in a camshaft. Especially if its installed retarded 3 degrees? I've said it a gazillion times on here, if you dont 60', you are going to maximize your combination. Its all starts with the 60'. Your still going to have issues with the other items as noted. I still believe the carb is oversized as well.
Dont forget strokers " eat up camshaft " duration, so the larger cam specs arent always quite so detrimental, but a 114 LSA is in your case, and then in at 117(?), thats killing low end power and torque, which also kills torque converter stall and 60'.
RIP Monte Smith
Re: 1st time on track little dissapointed [Re: T-bar] #1229151
05/08/12 12:09 PM
05/08/12 12:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well advance that cam to 106 install to start should wake it up a hole bunch. Must be flat as pizz on a platter now.
Yes on the 4200 to 4500 stall.
Yes on full port on the heads and milling .050 to get the compression up to at least 11.5 to 1
better cam when possible.
Re: 1st time on track little dissapointed [Re: T-bar] #1229152
05/08/12 12:39 PM
05/08/12 12:39 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
We need to see some pics of the car!
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: 1st time on track little dissapointed [Re: CompWedgeEngines] #1229153
05/08/12 06:12 PM
05/08/12 06:12 PM
Queensland,Australia
T-bar Offline OP
T-bar  Offline OP
Is it worth the time in advancing that cam if the duration is to wide? or should i change it out? I don't have anymore info on it then what i've listed. I thought i had the tune down pretty good from the chassis dyno. I did try different launch rpm's and shift points. I do understand that the 60' is critical and until i sort that it's gonna be slow. With a correct cam for this engine wouldn't it be ideal to have the heads flowed?
Re: 1st time on track little dissapointed [Re: T-bar] #1229154
05/08/12 07:00 PM
05/08/12 07:00 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
if your going to stick with 1/8 mile...more gear would be way better.
and I have a 8 inch ATI converter 4500 stahl...drives great on the street low tranny temps too. Never over 180 F.,
Re: 1st time on track little dissapointed [Re: T-bar] #1229155
05/08/12 07:19 PM
05/08/12 07:19 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
Hi T,I want to add some things that we done.I passed a friend's car a BBC and looked at his tack.He was shifting at 5200 I asked is at all,he said yeah it didn't matter if he shifted at 5200 or 6000 same mph or et. in the 1/8. So I was shifting at 6000 and went to 5200 then 5000 down to 4700 and picked 5 mph.Both cars had 410 gears I guess it was in 3rd.
longer .The car had a .555" solid cam.Your car will come arould I think you need slicks.~~ Bent
Section 8 Racing We are nuts about racing.
Re: 1st time on track little dissapointed [Re: T-bar] #1229156
05/08/12 07:42 PM
05/08/12 07:42 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Flowing the heads would cost money that you could be putting into the cam.
I would change the cam out with one that has a 106 to 108 lobe separation angle, and a duration at .050 of around 260 to 270 @ .050" lift, preferrably 260 for great mid range torque.
Advance it 4 degrees if it doesn't already come that way (advance ground in)and hang on.
You're converter will stall higher, you won't have to change gear or tire.
Re: 1st time on track little dissapointed [Re: moparmanjames] #1229157
05/08/12 08:08 PM
05/08/12 08:08 PM
T-bar Offline OP
T-bar  Offline OP
I will probaly change my tyres for the strip anyway because i got bit carried away with the burnouts and took a fair bit off my normal drive tyres. I will definately sort the cam area. It's great being a part of this forum the help is fantastic!
Re: 1st time on track little dissapointed [Re: T-bar] #1229158
05/09/12 01:26 AM
05/09/12 01:26 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I agree with everybody that the stall speed and gearing isn't optimum, but should work fine with 496 cubes. I believe the real problem lies with the camshaft.
Re: 1st time on track little dissapointed [Re: T-bar] #1229159
05/09/12 01:52 AM
05/09/12 01:52 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Hey all, i had my 70 Cuda out for the first time at an 1/8th mile track on the weekend and was a little disappointed on the results. I know this can be open ended question but can you give me some ideas on what i can do to get the times lower.
The best time was 7.57 at 92.98 mph and 60ft 1.72.
A few of the other runs were close to that area as well.
Now the combo is
496rb
10.5 compression
flat tappet .565" lift on both and .274 deg @ .50
eddy rpm performer heads with light porting (no flow numbers)
440 victor intake
1050 quick fuel carb 4150
converter stalls around 3500 (unsure)
727 full manual
3.91 diff gears
295/65r15 mickey thompson et's
So any thoughts?
Pretty amusing - all those replies about tossing a bunch of parts or changes at the car, and NOBODY asked 1 important question - what are you running for exhaust?
The ET times and chassis dyno numbers are spot on for your combo if you are still running manifolds or a restrictive exhaust. I've seen the cheap repop chrome exhaust tips with only about a 2" inlet pipe choke a healthy big block up pretty badly.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 1st time on track little dissapointed [Re: T-bar] #1229160
05/09/12 02:01 AM
05/09/12 02:01 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Ah yes, the big Auzzie burnouts eh? Showing off to the Sheila's watching?! Everyone loves a big burnout! hard on the tire life though!
I think you are headed in the right direction. A set of 28" tall tires for starters. I would look at suspension stuff too. The cam isn't perfect, but I think the combo has a bit more in it. Look at a GM LS7 in the C6 ZO6... it is running 120LSA, and it isn't a boosted or sprayed deal.
-Kenny
Re: 1st time on track little dissapointed [Re: StrokerAspen] #1229161
05/09/12 07:41 AM
05/09/12 07:41 AM
T-bar Offline OP
T-bar  Offline OP
Got to do a half decent burnout a few times lol. The exhaust is Hooker supercomp 1&7/8 into 3' full exhaust to the back bumper with 40 series mufflers. Will get a set of 90/10's and try that as well.
Re: 1st time on track little dissapointed [Re: T-bar] #1229162
05/09/12 09:10 AM
05/09/12 09:10 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The calvert front shocks would help the launch on your car, although one or two guys have tried them
on heavier cars and not liked them.
Personally i love mine.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 1st time on track little dissapointed [Re: T-bar] #1229163
05/09/12 12:27 PM
05/09/12 12:27 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
There's a lot of posts suggesting jacking the camshaft around - yet nobody has mentioned that would be foolish without seeing what kind of valve clearance you have now. Just because it should have clearance with the parts listed doesn't mean it does . Since you don't really know whats inside the motor and are going on the sellers word, I'd stick with tuning carb, timing, suspension, tire pressures etc., before I would mess with a cam degree change that may break a bunch of parts.
Re: 1st time on track little dissapointed [Re: Evil Spirit] #1229164
05/09/12 03:23 PM
05/09/12 03:23 PM
Alberta Canada
Alberta Canada
I have a brand new big solid roller for a 59 degree small block sitting on the shelf because she no fit. I knew it would be close. Turned out I had about -.005" clearance on the intake valve So, Logically, I bought a second car to build around the camshaft... it's going to be a while before I use that cam. OR we can always use it in a customer's car.
-Kenny
Re: 1st time on track little dissapointed [Re: StrokerAspen] #1229165
05/09/12 03:30 PM
05/09/12 03:30 PM
organ
maximum entropy Offline
organ
that's not enough.
Re: 1st time on track little dissapointed [Re: Evil Spirit] #1229166
05/09/12 05:41 PM
05/09/12 05:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
There is ways of checking valve clearance assembled. my guess is with uncut eddies and pistons with valve notches he could advance it a lot from where it is now 106 to 108 will be a huge power shift!
Page 2 of 3 1 2 3
